OvalDude54 Samba Member
Joined: July 15, 2005 Posts: 215 Location: SoCal- San Diego area (high rent)
Posted: Tue Sep 23, 2008 4:36 pm Post subject: Which throw out bearing? |
If I have an original 65 type 1, and going to install an original 6v 40 horse, which TO bearing do I use? I see too mnay advertised for sale!
Sorry, don't want to pull the motor if not needed.
Thanks men!
Mark |
Posted: Tue Sep 23, 2008 7:01 pm Post subject: Which TO bearing........correction |
Ooooooooops. I meant that I didn't want to pull the motor twice, since I might install the incorrect TO bearing.
TY |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Sep 23, 2008 7:24 pm Post subject: |
Many thanks Keifernet!!!!!! |
clay ford Samba Member
Joined: July 21, 2008 Posts: 1120 Location: Cheyenne, wy
Posted: Tue Sep 23, 2008 7:51 pm Post subject: |
are you serious what would happen if i bolted a 6volt trans to a newer style clutch without a pressure plate |
Posted: Tue Sep 23, 2008 7:55 pm Post subject: |
209slushee209 wrote: |
HUH? WTF do you mean and what does it have to do with his question?
I took it as he wants to know what style he should have before he pulls his engine? |
Posted: Tue Sep 23, 2008 8:09 pm Post subject: |
sorry i just looked at the link and it said that the old style throwout bearing need a centering ring on the clutch is that centering ring necessary i saw that and got a little scared because i have an old style trans bolted to a newer motor without a centering ring . as for his question it made me wonder what type of damage would happen if you had the wrong combination (old throw out bearing to a new clutch that doesn't have a centering ring . |
Posted: Tue Sep 23, 2008 9:02 pm Post subject: |
Ahhhhh.... okay... well the info is in that sticky all through out... bad things happen when you mis match early and late PP and TO bearings etc either way. |
