Porsche Space Saver Spares, two valve stems???
keithwwalker
keithwwalker is offline
PostPosted: Thu Sep 25, 2008 5:02 pm    Post subject: Porsche Space Saver Spares, two valve stems??? Reply with quote
Why do some Porsche Space Saver wheels have 2 valve stems instead of one?
Is one stem to suck down the tire snug to the rim, and the other to inflate?
kww
allsierra123
allsierra123 is offline
PostPosted: Thu Sep 25, 2008 6:11 pm    Post subject: Reply with quote
no I thought one was used to power something on the old ones maybe the washer fluid or something like that.
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
mightyart
mightyart is offline
PostPosted: Thu Sep 25, 2008 6:15 pm    Post subject: Reply with quote
Slow is the new fast.
McVanagon
McVanagon is offline
PostPosted: Fri Sep 26, 2008 3:26 am    Post subject: Reply with quote
Confusion is the new clarity.
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
jackbombay
jackbombay is offline
PostPosted: Fri Sep 26, 2008 6:14 am    Post subject: Reply with quote
extremely dark gray is the new black.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
bmwmango
bmwmango is offline
PostPosted: Fri Sep 26, 2008 12:16 pm    Post subject: Reply with quote
Rust is the new seam
1990 Westy converted to a Syncro Westy
2009 BMW R1200GS
1990 BMW K75
1986 BMW K75 Parts (Deer 1, Beemer 0)
Alan Brase
Alan Brase is offline
PostPosted: Fri Sep 26, 2008 11:11 pm    Post subject: Reply with quote
It seams like extremely dark gray rust might be the new black confusion, but for fast clarity can we slowly ANSWER THE GUY'S QUESTION?
Actually, I'm clueless as to the two valve stems. My 911 has a space saver spare, but looking at it is WAY down the list of important things to fix.
I say maybe.
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
[email protected]
mdetro4660@aol.com is offline
PostPosted: Sat Sep 27, 2008 6:13 am    Post subject: Reply with quote
the space saver I just picked up has one valve stem, but its a really odd valve stem. its metal and almost look like its maybe a an overpressure release or or something to that effect???? Only worry I have is can I take it out oand jsut pur a regular stem on there when I put the regular tire on for the vanagon?
Too bad the space saver is not really sufficent for the vanny. the tire on mine looks to have been recently replaced because the wheel has been used but the tire has definitly not and looks fresh, the "donor" car is undergoing an electric conversion so the spare had to go.
Markus
mightyart
PostPosted: Sat Sep 27, 2008 10:31 am    Post subject: Reply with quote
Why can't you use a stock sized tire for a spare?
Then you don't have to worry about inflating it.
Alan Brase
PostPosted: Sat Sep 27, 2008 10:56 am    Post subject: Reply with quote
I think he just want to use the steel Porsche rims, including the spare rim.
Al
Al Brase
Vanagons:
mightyart
PostPosted: Sat Sep 27, 2008 11:06 am    Post subject: Reply with quote
Al
Ah, I see.
keithwwalker
PostPosted: Sat Sep 27, 2008 1:16 pm    Post subject: Reply with quote
Yeah, I wasn't asking about the rubber tire, I was asking about the rim. I have collected 3 rims so far (which happen to have the space saver tire which I won't be using), and two of the rims have two valve stems and one rim has only one valve stem.
What gives?
Alan Brase
PostPosted: Sat Sep 27, 2008 4:12 pm    Post subject: Reply with quote
Is there anything special about those rims or are they just 15x6j or something like that? I have a 72 parts car that came with steel rims. I think they are a bit wider than the 15's on the early cars. Or are these 16's? later cars in the 80's went to the red alloy special rims. I don't know what year exactly.
Al
Al Brase
Vanagons:
keithwwalker
PostPosted: Sat Sep 27, 2008 5:35 pm    Post subject: Reply with quote
I have been buying the red aluminum cast alloy rims. They come in 15, 16, and 17 inch sizes.
Mine are 16x5.5. I want some wheels that fill out the well a bit more, but don't want or need wider wheels.
I like them as they are cheap, don't have problems with the center hole dimension being too small, and the with the right K&N adapters, they bolt right in.
The older rims were either painted or anodized and they are very nice too:
http://www.thesamba.com/vw/forum/viewtopic.php?t=117735&highlight=
mightyart
PostPosted: Sat Sep 27, 2008 5:56 pm    Post subject: Reply with quote
Is that your van?
Do you have a picture of the whole van with those rims and tires on?
JBange
JBange is offline
PostPosted: Sat Sep 27, 2008 6:20 pm    Post subject: Reply with quote
Are you seriously driving around on thse little pizza cutters?
John Bange
'90 Vanagon non-GL
'90 Vanagon GL
ProvoCyclist
ProvoCyclist is offline
PostPosted: Sat Sep 27, 2008 6:51 pm    Post subject: Reply with quote
Its a spare tire, mang. Rolling Eyes
Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A
mightyart
PostPosted: Sat Sep 27, 2008 7:36 pm    Post subject: Reply with quote
Sure looks like this one.
http://www.conti-online.com/generator/www/de/en/co...es_en.html
Are you running on four spare tires?
Dogpilot
Dogpilot is offline
PostPosted: Sun Sep 28, 2008 12:16 am    Post subject: Reply with quote
It would seem with those skinny tires and rims one could make a set of thin duelies! Boy that would be different.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
[email protected]
PostPosted: Sun Sep 28, 2008 6:05 am    Post subject: Reply with quote
Al
Al, I heard that the steel ones are desireable for 356's or something like that because they are a little wider than what they came with and make a good track wheel IIRC
I got one just to use as a spare for my vanagon as I have switched to Porsche wheels and it will be alot easier to just change the tire and not the tire and adapter on the side of the road (hopefully I never have to find out)
Those look pretty good on that DC!
Markus
