36hp corrosion: is this case savable?
thom
thom is offline
PostPosted: Sat Sep 27, 2008 4:36 pm    Post subject: 36hp corrosion: is this case savable? Reply with quote
Is there a way to repair this damage? There's a ton of corrosion around the oil sump mounting area, but the rest of the case is decent.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Sep 27, 2008 5:05 pm    Post subject: Reply with quote
Toss it into a fire.
Glenn
Member #1009
#BlueSquare
craigman
craigman is offline
PostPosted: Sat Sep 27, 2008 6:09 pm    Post subject: Reply with quote
Would make a good plant pot for the wife!
perello
perello is offline
PostPosted: Sun Sep 28, 2008 1:59 am    Post subject: Reply with quote
Well, I am doing an experiment using this
http://www.castolin.com/wCastolin_com/products/coating/Surfacing_Polymers.php?navid=64
I'll try to post pictures of the recovering process, which looks promising. Again this should be taken only as an experiment... Wink
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
tstracy39
tstracy39 is offline
PostPosted: Sun Sep 28, 2008 6:12 pm    Post subject: Reply with quote
Blast off the crust with walnut shells and see if there's enough case left over afterwards to use. After it's clean maybe fill in the craters with JB weld. It MIGHT just work.
Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
I like your fork.
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sun Sep 28, 2008 7:53 pm    Post subject: Reply with quote
Considering it's a 36HP case, and they no longer "grow on tree's" like the 1600 cases do, use it. I have a similar AK dual relief cased 1776 in my car now, and although it may not have been quite as bad, its been going strong since 95. I've seen many off-road buggy engines with similar corrosion in the sump area that have been patched with JB Weld that are doing fine. Blast, or grind off the worst of it, and have at it with the JB Weld. The long curing stuff is good to 600 degrees. If your case is getting hotter than 600 degrees you'll have other things to worry about other than your JB Weld patch comming off. If the case has bad corrosion in other areas, that may be a different story. If that's the only bad place, use it.
L378
L378 is offline
So what causes this type of corrosion? The original case to my oval (still running in the car) has the same type of corrosion.
mikemck
mikemck is offline
PostPosted: Sun Sep 28, 2008 7:55 pm    Post subject: Reply with quote
I have a little bit of this kind of corrosion on my trans.
How can it be arrested and prevented?
Thanks.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sun Sep 28, 2008 8:27 pm    Post subject: Reply with quote
They don't seem that hard to find and are actually selling for less ( in some instances) than 40 hp or 1600 cases.
I do wish I had all the complete 36er engines I saw get tossed back in the 80's though Mad Shocked
This will take you to every one in the classifieds at this posting... not telling you to go search... it IS the search ready to go...
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
I have seen corrosion like that from water that got into the engine when it sat for years... the oil floated on the top allowing the case to corrode right there at that spot.
If it has not "encroached" the studs for the drain plate that bad ( looks like it has not) then as stated... Clean it up... JB WELD and if the rest of the case is good then you might get some service out of it. I have seen it done on other cases. You might always have a pesky (er than normal Laughing ) oil leak at the drain plate too...
If your sinking big bucks into all the other new 36er parts then I would opt out for a better case.
[email protected]
PostPosted: Sun Sep 28, 2008 8:36 pm    Post subject: Reply with quote
Tranny cases are a little easier to come by than 36 HP engine cases, but you could do the same thing with the JB weld. If this corrosion is just around the drain plug, and you are not using this trans in a high performance application, it's mainly cosmetic. Performance trans have the possibility to crack stemming from the drain plug area. If you are going to be abusing the trans, I would look for another case. To prevent any further corrosion, about all you can do is paint the case to seal out any corrosion elements from the magnesium.
[email protected]
PostPosted: Sun Sep 28, 2008 8:50 pm    Post subject: Reply with quote
keifernet wrote:
They don't seem that hard to find....
Where abouts are you located? Considering that all but about a few of the 36 HP classified listings you linked are located on the Westcoast, if you're in Western PA like me, 36HP cases are pretty difficult to find. Thank God for resorces like thesamba were you can get in contact with people that have older hard to find parts, but I can probably locally find you 100+ dual relief 1600 cases for every 1 36 HP case in PA. I do agree that if you ar restoring a 100 point 50's showcar, it would be nice to have a cleaner case.
gt1953
gt1953 is offline
PostPosted: Sun Sep 28, 2008 9:12 pm    Post subject: Reply with quote
A 36 HP case like well I don't think that I would use in that condtion.
http://www.thesamba.com/vw/classifieds/detail.php?id=631555
I would use one of these above.
72 type 1
72 Squareback
keifernet
PostPosted: Mon Sep 29, 2008 6:10 am    Post subject: Reply with quote
That is what I meant and what I linked too. I mean some cases are 50 bucks... some even say shipped for 100 or 110.00... some are priced higher so either they are exceptional or like so many some don't really need the sale that bad.
I agree they your not going to trip over them local like you will the later cases but they are not "rare" IMHO or that hard to find.
Those prices are as cheap or cheaper than most of the 1600 OG cases listed.
I would of course ask for tons more pics and check the buyer out first.
For example the man that just blatantly post whored his own ad Shocked Razz Laughing has 3 for sale Exclamation
[email protected]
roy@mofoco.com is offline
PostPosted: Mon Sep 29, 2008 1:20 pm    Post subject: Reply with quote
I have 30 or 40 good 36hp cases for sale at any one time. Please pm me with any specific questions. I'd sell one, depending on if it's standard or align bored for $200-$350.
keifernet
PostPosted: Mon Sep 29, 2008 5:52 pm    Post subject: Reply with quote
Shocked
Middle child
Middle child is offline
PostPosted: Wed Oct 21, 2009 11:48 am    Post subject: corrossive issues with a transporter trans Reply with quote
Just for the fun of it (?) I may take the suggestion and fix my transmission case...it sat for years on the ground and I'm assuming this could have corroded from the inside out? Water in the unit slowly taking it's toll...until there's a major problem. My engine also shows some pitting issues but it should run as is....fun buying stuff in a yard where stuff has been sitting forever. Atleast 20 years in my case I'm guessing. Somebody on here suggested the longer curing JB Weld is better than JB Qwik?
the2ndcashboy
the2ndcashboy is offline
PostPosted: Wed Oct 21, 2009 12:19 pm    Post subject: Reply with quote
In aviation we use dilute chromic acid to neutralize corrosion in magnesium. After its neutralized, you put an epoxy coating on it to seal out moisture. If you just brush off the loose stuff and slap JB on it the corrosion is just going to keep eating the part underneath.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Oct 21, 2009 1:16 pm    Post subject: Reply with quote
Exactly. Conformal coatings (when applied correctly) do an excellent job of keeping corrosion at bay, especially when the part in question will be exposed to salt spray like cars in the midwest always are. In Naval Aviation, we use poly based paints a lot. Same goes for conversion coatings, to neutralize the corrosion before it gets painted.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
fastinradford
fastinradford is offline
PostPosted: Wed Oct 21, 2009 4:53 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=863640
this case looks ok from here, ohio isn't far from pa, depending on where your traveling from.
for the price though, it may be worth a drive.
95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK]
DONT
DONT is offline
PostPosted: Thu Oct 22, 2009 10:39 am    Post subject: Reply with quote
I have a case that just has cosmetic corrosion on the outside. Do coatings like POR 15 do ok on magnesium?
