69 Jim Samba Member
Joined: September 27, 2004 Posts: 6265 Location: Chickengeorge's Neighbor
Posted: Wed Oct 01, 2008 1:48 pm Post subject: No replies in the Wheel forum |
Any ideas on the maximum rear wheel backspacing without any rubbing issues for an irs Bug? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Oct 01, 2008 3:30 pm Post subject: |
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
69 Jim Samba Member
Posted: Wed Oct 01, 2008 3:33 pm Post subject: |
Thanks Russ, but I'm looking for the maximum offset without any clearence problems. |
Posted: Wed Oct 01, 2008 3:44 pm Post subject: |
Are you wanting to go out or in??
T-1 wheels have the least offset. T-3 wheels have the most.
T-3's use the same IRS control arm as a bug.
So you can use at least 46mm offset without it rubbing on the inside. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
69 Jim Samba Member
Posted: Wed Oct 01, 2008 3:59 pm Post subject: |
I am looking for the max backspace I can go on the rear. Right now I have original Sprint stars that have an 88mm backspace. I am hoping to see if someone has ran 4.5" or approx 114 mm's of backspace. It looks like it might fit, but I would like to be sure before the wheels are made. |
Mark33563 Samba Member
Joined: November 13, 2005 Posts: 1667 Location: Tampa Bay. FL
Posted: Wed Oct 01, 2008 7:39 pm Post subject: |
69 Jim wrote: |
Get a junk steel rim, start cutting and welding. Sooner or later it will rub. Keep in mind that the tire bulges out a bit, so take that into account. _________________ -—--------—-------
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24 |
