Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Fri Oct 03, 2008 1:44 pm Post subject: caster in a BD front beam |
why not fit some kind of spacer (caster shims) on the upper beam bracket bolt and between the top tube and the frame support to slightly tilt the front beam (while still supporting it safely) and create some useful caster?
the only slight complication i foresee is the slight tilt in steering arm that could be easily rectified.
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Oct 08, 2008 6:51 am Post subject: Re: caster in a BD front beam |
| Lowdown Dirty Rat wrote: |
you need bottom beam moved towards front of bus not top beam. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
sled Samba Member
Posted: Wed Oct 08, 2008 8:12 am Post subject: |
he meant put a shim between the top tube and the frame to move the top tube BACK, which is the same thing as moving the bottom one forwards.
if you used a small shim, you wouldnt have any issues with the steering arm changing angle too much....and any caster is better than no caster. _________________ drive your split. |
Posted: Wed Oct 08, 2008 8:32 am Post subject: |
| sled wrote: |
if you used a small shim, you wouldnt have any issues with the steering arm changing angle too much....and any caster is better than no caster. |
i have only worked on newer bus. i looked and found that early bus is opposite of beetle beam. he is correct and i was wrong. sorry..  _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Scotty Samba Member
Joined: July 02, 2003 Posts: 1553 Location: Northampton - Uk
Posted: Thu Oct 09, 2008 5:07 am Post subject: |
I am in the process of getting some shims made _________________
| EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
streetwagens Samba Member
Posted: Thu Oct 09, 2008 8:42 am Post subject: |
We made some up for the '55 panel out of narrowed beam offcuts - did the job!  _________________ To catch a fish, you must first think like a fish.... |
