Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Fri Aug 14, 2009 3:19 pm Post subject: |
bill may wrote: |
Nor_AL_67 wrote: |
Type 3 transaxle installed. New shift rod bushings, brake hoses, mounts, etc.
a gasket does not go between the backing plate and end casting. it goes between the backing plate and bearing retainer. 2 gaskets are in the kit because type 2 bus uses 2 gaskets and no big O ring. beetle uses 1 gasket and the big O ring. |
Ok, great thanks for the correction. Should have read my manual. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
jeremy57ride Samba Member
Posted: Fri Aug 28, 2009 9:37 am Post subject: |
Nor_AL_67 wrote: |
jeremy57ride wrote: |
Here's a little flash back to a previous post and I was hoping for some help. This area on my bus is gone, and I don't know how the inner-rocker
attaches to the rear cargo pillar. I know how the inner rocker attaches to the jack point but how does this pillar support weld in place?
Thanks for any help.
Right now the pillar is "floating" on my bus...LOL
The B and C pillars sit on top of the inner rocker lip as in the pic below. I did stitch welds where the two meet.
The outer rocker/strengthener fits in the B/C pillars. You have to kind of twist / turn it so the tabs fit. Hard to explain.
This is the piece I am missing. It's flat out gone! What is this called and can I order it? Thanks again...and thanks for the pic Kelly _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Fri Aug 28, 2009 10:33 am Post subject: |
C pillar, make sure you specify left hand drive, right side cargo door. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
volksfahrer.nl Samba Member
Joined: September 18, 2003 Posts: 2128 Location: Delft Holland
Posted: Fri Aug 28, 2009 12:55 pm Post subject: |
If it's just that bottom piece fabricate it yourself.
Not that hard to do and saves some bucks. _________________ www.volksfahrer.nl
www.theundutchables.nl
66 panel |
Posted: Sat Aug 29, 2009 10:04 pm Post subject: |
I found a pin sized hole on my axle shaft that is allowing tranny fluid to leak. Would it be safe to weld it up after I've drained the fluid and cleaned / dried the area? I think a 3 second zap would be all it needs.
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
57Drag Samba Member
Joined: July 27, 2003 Posts: 994 Location: Lawtey,Florida
Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Posted: Sun Aug 30, 2009 9:23 am Post subject: |
Do it outside with a friend holding a fire extinguisher and you should be ok as long as your friend does not 'accidently' spray you |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Posted: Sun Sep 06, 2009 4:33 pm Post subject: |
slow36hp wrote: |
be more worried about the nearby gas tank or grease contaminating the weld than anything else . no danger ,magic or problems with welding that up |
Managed to not blow myself up....
Got the engine installed, bumpers, suspension adjusted, brakes bled, safaris installed. Took it for it's first spin around the block and my first in a bus, ran out of gas.... (had spare gan can with me) Engine needs help, backfiring , but my mystery transmission shifted smooth, no noises, or poping out of gear. Brakes were better than I expected. Still plenty to do, but after and year and a half it's finally rolling.
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Sun Sep 06, 2009 4:47 pm Post subject: |
Great looking bus!
_________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
DKO Samba Member
Posted: Mon Sep 07, 2009 7:38 am Post subject: |
Great bus!. Thanks for documenting all of this as well. I'm impressed by your workmanship. I have learned a lot from your posts.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Nor_AL_67 wrote: |
Still plenty to do, but after and year and a half it's finally rolling. |
Great feeling, ain't it!
Bet you were sporting one of these! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Aaron Samba Luddite
Posted: Mon Sep 07, 2009 9:58 am Post subject: |
One more on the road, good job. |
DownRiver Samba Member
Joined: January 05, 2003 Posts: 797 Location: threeonethree
Posted: Mon Sep 07, 2009 10:19 am Post subject: |
Congratulations! Looks like the hard work has paid off. Enjoy the rides! _________________ Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Sep 07, 2009 12:56 pm Post subject: |
Beautiful! Very nice work, and good luck with that engine, that's what's keeping my super down ATM. |
Posted: Mon Sep 07, 2009 2:48 pm Post subject: |
You guys are great thanks for the motivation, suggestions, corrections and special props to Aaron at widefive.net for answering all my pesky lowering questions. The fun part for me is almost over......hmm...single cab next?? _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
Posted: Thu Sep 10, 2009 10:59 am Post subject: |
I could not get the engine to run right; put good carb, distributor (from my nice running bug), tune up , etc. kept backfiring and lack of power. I did a compression test of the engine and here's what I found.
#1-35 psi
#2-130
#3-30
#4-115
I'm guessing 2 burnt valves, will tear down and see. Alway's something. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
Posted: Thu Sep 10, 2009 12:10 pm Post subject: |
Well that sucks balls!
Oh... and I answer pesky engine questions too If you need any help let me know! _________________ Aaron D. Badertscher
Click here for ALL my links. |
Posted: Sat Sep 12, 2009 9:19 pm Post subject: |
Pulled the motor, looking at the valves, the #1 and #3 exhaust valves are about 1/2 cm below the others with the rocker arms removed. Also the valves were super tight, with a zero gap. Does this mean the valve guides are worn? Also the #1 & #3 push rods tubes were sucked in, like they had collapsed, weird? Will pull the heads tomorrow
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
