Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sun Oct 05, 2008 6:10 pm Post subject: |
Maybe help the motor park correctly? Without the spring, maybe momentum would cause the motor to miss the parking location? |
Bravo 1 Samba Member
Joined: September 13, 2005 Posts: 407 Location: Richmond, VA
Posted: Tue Oct 07, 2008 8:36 pm Post subject: |
Could it be that the spring is there so that when the mechanism reaches either extreme position (left/right), it gets pulled back towards the center, minimizing the load on the motor, since it would be most strained at those times... ? _________________ 1964 Type 1 Sedan |
subhuman Samba Member
Joined: January 22, 2008 Posts: 539 Location: north carolina
Posted: Tue Oct 07, 2008 8:46 pm Post subject: |
Bravo 1 wrote: |
Could it be that the spring is there so that when the mechanism reaches either extreme position (left/right), it gets pulled back towards the center, minimizing the load on the motor, since it would be most strained at those times... ? |
that seems to be the most best explenation _________________ 63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Wed Oct 08, 2008 8:30 am Post subject: |
Maybe it's to prevent chatter as the linkages wear? |
64Bug Samba Member
Joined: May 01, 2008 Posts: 120 Location: Ontario, Canada
Posted: Thu Oct 09, 2008 10:54 am Post subject: Wiper Spring |
During the 12 volt (P.O. conversion) back to 6 volt conversion, I also noticed that a spring was there, but it was just hanging loose.
(I know, you're wondering why I would ever convert it back to 6 volt.) In a nut shell, cause that's the way I wanted it, but that's for another story. Besides the P.O. really messed things up.
During the R&R, I took a look at the plastic bushings on the ends of the arms. They were noticeably worn on one side with no spring attached.
IMO, the spring is installed to equalize wear on those bushings.
BTW, for those that are converting from 6 to 12 volt? ...... The motor drive pin is larger in diameter on the 12 volt unit. So even if you get a 12 volt motor, you will still need a 12 volt drive arm, cause the 6 volt drive arm will not fit.
Been there, Done that. The hard way _________________ When you turn it on, does it return the favor?
1974 Westfalia
1964 Beetle (stock)
2017 Santa Fe |
cncwhiz Samba Member
Joined: February 28, 2005 Posts: 226 Location: Gardnerville, NV
Posted: Thu Oct 09, 2008 12:38 pm Post subject: |
The motor drive pin is only bigger on the early 68. 67 12 volt motor is the same size. |
