Lorelei Samba Member
Joined: August 23, 2017 Posts: 16 Location: Jacksonville
Posted: Tue Apr 09, 2019 6:31 pm Post subject: Part identify help |
Can someone help tell me what this is in the picture that I’m pointing at.
It has a bracket that holds it in place. I’m not sure what it is or does.
Thanks in advance.
Shawn
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Tue Apr 09, 2019 6:31 pm Post subject: Re: Part identify help |
crankcase breather _________________ Glenn
Member #1009
#BlueSquare |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Tue Apr 09, 2019 7:01 pm Post subject: Re: Part identify help |
Glenn wrote: |
crankcase breather |
for a guy who doesn't like bays you sure are in here a lot lately.
slumming? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Glenn Mr. 010
Posted: Tue Apr 09, 2019 7:03 pm Post subject: Re: Part identify help |
skills@eurocarsplus wrote: |
Glenn wrote: |
slumming? |
I've worked on a few..... as long and the cash is green, i'll take it. And id beats working on a Honduh. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Apr 09, 2019 7:08 pm Post subject: Re: Part identify help |
Thank you sir. Now if I can figure out what the heck it does and if it was row correctly. |
Posted: Wed Apr 10, 2019 2:51 am Post subject: Re: Part identify help |
Lorelei wrote: |
It vents the blowby gases from the crankcase and dumps them into the intake air stream so they can be burnt by the engine. Since you have an aftermarket progressive carburetor, you need to set up a system that dumps the blowby into the top of the air cleaner. This will give the hose sufficient slope so that it drains well and will not clog, and by sending the oily fumes directly into the venturi will not cause an oily mess.
I have a totally different air cleaner from you, but here is a picture of the crankcase ventilation hose and fitting going into the top of my air cleaner. Sorry the pic is out of focus.
Posted: Wed Apr 10, 2019 3:52 am Post subject: Re: Part identify help |
Thanks Wildthings I will look into building something similar. Appreciate the picture. |
