chabanais Samba Member
Posted: Thu Jun 25, 2015 11:43 am Post subject: |
NASkeet wrote: |
Are these LED headlamps from Truck-lite, in Harlow, Essex, England, the kind of thing to which you refer?
Those appear to be the most commonly found, high quality ones. _________________ "I spud therefore I yam." |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Wed Jul 01, 2015 8:23 am Post subject: |
chabanais wrote: |
NASkeet wrote: |
Those appear to be the most commonly found, high quality ones. |
A late-model (A British J-prefix registration), RHD VW Type 25 Syncro (i.e. Vanagon or Transporter T3, with retro-fitted Truck-Lite LED headlamps, was recently featured in the following magazine article:
Dave Richards & Andrew Thompson, “Have Syncro, will travel …”, Volkswagen Camper & Commercial, Issue 92, June 2015, Pages 38~42.
I wonder whether these Truck-Lite and other 7-inch diameter LED headlamp units, are compatible with the headlamp buckets associated with fitting sealed-beam headlamp units, to North American specification 1968~79 VW Type 2s or whether some other mounting hardware would be required!?!
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net
Posted: Wed Jul 01, 2015 8:32 am Post subject: |
telford dorr wrote: |
OK, measurement made.
Used a Lambda adjustable constant voltage / constant current power supply to pass approximately 100 ma (0.1 amp) through the dipped beam filament of a (used) Philips 55/60 watt H4 lamp.
Equipment used: Fluke 8020B to measure lamp current, Fluke 8050a to measure lamp voltage.
Actual current: 112.5 ma (0.1125 amps)
measured voltage: 20.8 mv (0.0208 volts)
calculated cold resistance: 0.185 ohms
Thus, when 14.4 volts is applied to a cold filament, the instantaneous current is 14.4 / 0.185 = 77.8 amps, or 155.6 amps for a pair of lamps. [This exceeds the 40 amp rating of a good relay by a significant amount.]
Now granted, this current surge doesn't last long (milliseconds, maybe), but it's enough to stick a relay, and is definitely hard on the filament itself (which is why filament lamps generally fail when switched on). It follows that some current-limiting series wiring resistance is likely a good thing, as long as it doesn't limit normal lamp performance. |
I think it unlikely that one will obtain as much 14·4 V across the headlamp filaments on a 1968~79 VW Type 2; especially once the alternator has to deliver any significant current. About 13·5 V is typically more realistic I believe.
Tungsten (aka Wolfram) has a melting point of 3,422 °C (i.e. 6,192 °F, for those in the USA), but the tungsten filaments of domestic incandescent light bulbs, typically operate at circa 2,500 °C (i.e. 4,532 °F, for those in the USA), but it's likely to be higher than this for quartz-halogen bulbs.
So far as relay contact-welding is concerned, one needs to inhibit arcing across the contacts, which might be done by connecting a suitable capacitor in parallel. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Jul 01, 2015 11:02 am Post subject: |
NASkeet wrote: |
Thus, when 14.4 volts is applied to a cold filament, the instantaneous current is 14.4 / 0.185 = 77.8 amps, or 155.6 amps for a pair of lamps. [This exceeds the 40 amp rating of a good relay by a significant amount.] |
I think it unlikely that one will obtain as much 14·4 V across the headlamp filaments on a 1968~79 VW Type 2; especially once the alternator has to deliver any significant current. About 13·5 V is typically more realistic I believe. |
OK, let's use 13.5 volts:
The instantaneous current is 13.5 / 0.185 = 73.0 amps, or 146 amps for a pair of lamps. This is still significant current for a 40 amp relay.
Quote: |
So far as relay contact-welding is concerned, one needs to inhibit arcing across the contacts, which might be done by connecting a suitable capacitor in parallel. |
A capacitor won't help with the current surge. It may actually make it worse. [With the lamps off, the capacitor would charge to battery voltage, When the switch is turned on, that stored energy is dumped into the switch contacts. Not good...]
Now significant series inductance would get the job done, but then you would need a way to dump the stored energy on shutdown. Thus, this is likely impractical.
The easiest solution is to have enough series resistance (we're talking about small values here) such that (a) the inrush current into a cold lamp is limited to a reasonable value, and (b) that the hot lamp operating voltage is still above the minimum lamp ratings.
Bottom line: DON'T wire your headlamps with an 8 gauge feeder from the battery, or some other oversized current sourcing scheme. Use wire just large enough such that the operating voltage is proper, and no larger. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Thu Jul 02, 2015 8:27 am Post subject: |
NASkeet wrote: |
Bottom line: DON'T wire your headlamps with an 8 gauge feeder from the battery, or some other oversized current sourcing scheme. Use wire just large enough such that the operating voltage is proper, and no larger. |
To which wire gauge system do you refer?
8 AWG => 8·37 mm˛
Volkswagen quote cable cross-sectional areas in mm˛. My 100/80W H4 headlamp live-feed cables are circa 3·0 mm˛ and the earth (aka ground cables are circa 4·5 mm˛. The main live-feed from the alternator to the fuse & relay boxes in the cab is 2 x 6·0 mm˛.
https://en.wikipedia.org/wiki/Wire_gauge
https://en.wikipedia.org/wiki/Standard_wire_gauge
https://en.wikipedia.org/wiki/American_wire_gauge
http://www.engineeringtoolbox.com/wire-gauges-d_419.html
http://www.rapidtables.com/calc/wire/wire-gauge-chart.htm
http://rapidtables.com/calc/wire/swg-to-mm.htm
Rather than limit the steady-state voltage using resistive elements, it might be preferable to further explore electrical-arc suppression technology.
https://en.wikipedia.org/wiki/Arc_suppression
http://www.industrologic.com/mechrela.htm
http://www.arcsuppressiontechnologies.com/ _________________ Regards.
Nigel A. Skeet
Posted: Thu Jul 02, 2015 4:23 pm Post subject: |
NASkeet wrote: |
To which wire gauge system do you refer? |
Sorry - AWG
Quote: |
8 AWG => 8·37 mm˛
Volkswagen quote cable cross-sectional areas in mm˛. My 100/80W H4 headlamp live-feed cables are circa 3·0 mm˛ and the earth (aka ground cables are circa 4·5 mm˛. The main live-feed from the alternator to the fuse & relay boxes in the cab is 2 x 6·0 mm˛. |
Wouldn't go any larger than the 3mm˛ (~12 AWG) on the lamp feeders. I used 10 AWG on a pair of H1 100 watt driving lights. After welding two Bosch relays, I downsized to 14 AWG (individual lamp feeders) and the problem stopped.
I studied the references above, and they all seem to deal with suppressing the arc which occurs when the contacts open, where the load has an inductive component. In the case of tungsten filament lamps, the arc occurs on contact make, emulating a spot welder. As such, the arc suppression techniques referenced don' t seem to apply.
Now one method that would likely work would be some sort of PWM soft-start circuit using mosfet devices. Don't know if anybody makes such a device for automotive use - will have to investigate.
TD _________________ '71 panel, now with FI
SGKent Samba Member
Posted: Thu Jul 02, 2015 8:30 pm Post subject: |
getting in kinda late here and this is probably meaningless. My bus has a set of Cibie 7" H4 Narva 60/55 lights in it. Having cleaned all connections from the battery and alternator to the lights, replacing the stock switch with a NOS stock switch, and the ignition switch being new, all grounds cleaned, all crimps cleaned etc, the CIBIE lights see 11.99 - 12.01 volts across them. The loom coming forward drops about 7/10th of a volt and the combination of switches drops another 7/10. This drops the 13.5 at the alternator to the 12.1 or so at the lights. Daniel Stern suggests using heavier wiring and relays for the lights to get the benefit of the full 13.5 but listening to y'all argue the point has convinced me I can see fine with them as they are. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jul 02, 2015 10:26 pm Post subject: |
Found a possible solution on-line:
Install a Negative Temperature Coefficient (NTC) current limiting thermistor, like a GE CL-30, in series with the lamp. This device has a resistance of 2.5 ohms when cold, thus limiting the turn-on surge current to 5 amps or so, with most of the voltage (and power) drop across the thermistor. As the device heats up, it's resistance drops, and more current is fed to the lamps.
The trick is to wire a cube relay coil from the bulb feeder to ground, so that it sees the bulb voltage. The contacts are wired to short out the thermistor device. Thus, when the lamp voltage gets high enough (e.g. the lamp is warmed up), the relay closes and full voltage is applied to the lamp.
With something like this, you can use as big a feeder wire as you desire, allowing the lamps to operate at maximum available voltage, with no current surge or welded relays or surge-shortened bulb life.
Will try to source one of these devices and try this out. _________________ '71 panel, now with FI
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1732 Location: SoCal
Posted: Thu Jul 02, 2015 11:37 pm Post subject: |
Great information here. Puzzled, however, by the specter of using oversized "feeder" wires (guessing those would be the actual high-current supply leads to the relays and from there to the headlight bulbs, right).
Our '68 Westy's Cibie Z-beams/relays (and some other up-front devices via fuses) are fed 12V+ by a #4AWG lead from the auxiliary battery bank, through a circuit breaker at the isolator in the camper's rear. Is this arrangement tempting fate? Are you, Telford or Nigel, saying that I should replace the #8AWG leads to the relays & Z-beams with #10 or even 12? Is it just dumb luck that I haven't trashed a relay yet?
The idea of frying any relays in the midst of traveling to/from a camping or road trip conjures up some really negative thoughts. TIA _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
Posted: Fri Jul 03, 2015 8:06 am Post subject: |
Will try to source one of these devices and try this out. |
I've previously come across negative-temperature-coefficient thermistors as temperature-sensing transducers (including designing signal-linearising Wheatstone-Bridge type circuits for them), but had never heard of them being used as current-limiting devices before! It will be interesting to learn how effective they are in the VW headlamp application and how much voltage drop they incur under steady-state conditions.
http://www.digikey.com/product-search/en/circuit-protection/inrush-current-limiters-icl/656273
http://www.digikey.com/catalog/en/partgroup/cl-ser...Link_Table _________________ Regards.
Nigel A. Skeet
Posted: Fri Jul 03, 2015 10:23 am Post subject: |
WestyPop wrote: |
Great information here. Puzzled, however, by the specter of using oversized "feeder" wires (guessing those would be the actual high-current supply leads to the relays and from there to the headlight bulbs, right). |
Correct.
Quote: |
Our '68 Westy's Cibie Z-beams/relays (and some other up-front devices via fuses) are fed 12V+ by a #4AWG lead from the auxiliary battery bank, through a circuit breaker at the isolator in the camper's rear. Is this arrangement tempting fate? |
No. You want heavy gauge feeders from the battery to the front of the bus. Other loads (which don't have the initial current surge problem that tungsten filament lamps have) appreciate large feeders. It's only the lamps which have the issue.
The idea of frying any relays in the midst of traveling to/from a camping or road trip conjures up some really negative thoughts. TIA |
Maybe.
Speaking for myself, I'd run no larger than #12 from the relays to the lamps. If #14 gave satisfactory results, I'd run that. The idea is to run wire just large enough to provide proper operating voltage to the lamps, and no larger. Your voltmeter is your friend here.
Take care of those Z-beams. I'd love to source a replacement set of reflectors for mine, but the genuine Cibie versions are NLA... _________________ '71 panel, now with FI
Posted: Fri Jul 03, 2015 10:38 am Post subject: |
Apparently, these specific devices are intended for applications like this. According to the datasheet above, at full operating current of 8 amps, their resistance drops to 0.06 ohms, resulting in a voltage drop of 0.48 volts. At a 4 amp load (typical 55 watt lamp), the IxR drop would likely be around 0.24 volts. I could probably live with that. _________________ '71 panel, now with FI
Posted: Sat Jul 04, 2015 8:02 am Post subject: |
Fabricating & Installing the Supplementary Headlamp Mounting Brackets
By measuring the right-hand (i.e. offside or starboard) and left-hand (i.e. nearside, port or larboard) bodywork headlamp shells (aka bowls), of a scrapped, British specification, 1974 VW 1800 Type 2 and the positions of its various mounting brackets, for the 1974~79 VW Type 2 pattern headlamp units and trim rings, I was able to fabricate a cardboard template.
Late headlight mount – bodywork headlamp shells
Modified 1968~73 VW Type 2 headlamp-buckets, with three supplementary headlamp-mounting lugs & captive M4 nuts, to mount 1974~79 VW Type 2 headlamps or others with the same mounting requirements.
This template summarises all the required location data, for the three headlamp-unit fixing points, relative to the rims of the bodywork headlamp shells and the existing trim-ring's fixing point; which is identical for both the right-hand and left-hand sides.
The 217 mm external diameter of the template, corresponds to the 217 mm external diameter of the headlamp unit's nominally circular (with various cut-outs) mounting ring.
The 179 mm diameter (i.e. 2 x 89•5 mm radius) inscribed blue dotted-line circle, corresponds to the outer circumference, of the lamp-unit's glass lens.
Three 4 mm diameter holes, are punched in the cardboard, corresponding to the required mounting-hole centres, in the headlamp unit's nominally circular (with variously shaped peripheral cut-outs) mounting ring. The mounting ring also has other holes, which will not be used for the VW Type 2 installation.
Using the headlamp trim-ring's fixing point, as a point of reference which defines a horizontal line to the headlamp lens centre, the locations of the headlamp-unit mounting brackets and their captive-nut centres, are as follows:
(1) Recessed 34 mm in from the lamp shell rim and 9 mm outboard of the lamp lens periphery. Rotated 19 degrees clockwise, from the trim-ring's fixing point.
(2) Recessed 9 mm (i.e. within 9˝ ± ˝ mm) in from the lamp shell rim and 5˝ mm outboard of the lamp lens periphery. Rotated 118˝ degrees (i.e. 90 + 28˝ degrees = 19 + 71 + 28˝ degrees) clockwise, from the trim-ring's fixing point.
(3) Recessed 10 mm (i.e. within 9˝ ± ˝ mm) in from the lamp shell rim and 5 mm outboard of the lamp lens periphery. Rotated 242 degrees (i.e. 19 + 71 + 28˝ + 123˝ degrees) clockwise, from the trim-ring's fixing point OR rotated 118 degrees (i.e. 90 + 28 degrees) anticlockwise, from the trim-ring's fixing point.
For the moment, I don't have time to examine my L-shaped, headlamp-mounting brackets in-situ and it's been many years since I installed them, so my memory is a little hazy, with regard to the exact procedure I adopted. I shall try to examine them in the near future and also draw some sketches, to help explain the various piecemeal stages, of positioning & securing the mounting brackets, plus the required locations of their fixing holes & captive M4 nuts for the headlamps.
Using scrap off-cuts, of 25 mm thin-walled (circa 1 mm) square-section tube, the L-shaped, headlamp-mounting brackets, were fabricated by first cutting off circa 25 mm and 30 long sections and then cutting across the square-section diagonal. These were then trimmed and shaped to suit their individual locations; the details of which I didn't record, but can check shapes and dimensions when I have sufficient time to spare.
Cursory examination of my L-shaped, headlamp-mounting brackets, has revealed that the material is nominally 1•0 mm thick. The other dimensions of the brackets, vary according to installation position, which are as follows.
(1) - Upright height 12 mm | width 30 mm | Leg length 20 mm | Leg towards headlamp-shell rim
(2) - Upright height 12 mm | width 25 mm | Leg length 15 mm | Leg away from headlamp-shell rim
(3) - Upright height 12 mm | width 25 mm | Leg length 15 mm | Leg away from headlamp-shell rim
My design choice re bracket width, was related to bracket strength, plus the security & stability of the lamp units.
Note that neither the Legs nor the Uprights, are rectangular in shape, being profiled to accommodate the shape of the headlamp unit's nominally circular (with variously shaped peripheral cut-outs) mounting ring.
Note that the bracket widths of 25 mm and 30 mm, were my own design, the original brackets on the 1974 VW 1800 Type 2, from which I took positional measurements, were much smaller.
Owing to the curvature of the body headlamp shell, it is necessary to slightly bend the L-shaped sections, to more or less than 90 degrees, dependent upon whether the orientation of the Leg, is towards or away from the rim.
Positioning the brackets within the body headlamp shell, needs to be done in stages, to ensure that each set of three brackets, are properly aligned in the plane of the headlamp unit's nominally circular (with variously shaped peripheral cut-outs) mounting ring, and that the 4 mm fixing holes in the brackets, coincide with those in the mounting ring to within acceptable tolerances.
The Legs fasten to the body headlamp shell, whilst the Uprights provide the fixing points for headlamp unit's nominally circular (with variously shaped peripheral cut-outs) mounting ring.
Drill a small hole in the centre of the Legs, of all six L-shaped brackets. These will be used to fasten (either temporarily or permanently; dependent upon your preference!?!) the L-shaped brackets to the body headlamp shells. The diameter of these holes, will depend upon the diameter of fastening screws one has available, but I would suggest circa 3~4 mm. _________________ Regards.
Nigel A. Skeet
garyt Samba Member
Posted: Fri Apr 15, 2016 12:35 pm Post subject: Re: Refurbishing & upgrading 1968~79 VW Type 2 headlamp syst |
Great info thanks.
Just a note to say that my dimmer relay has just blown on my 79 SB and I noticed that although the stick on the column no longer works, of course, when I switch between headlamps and parking light it goes from full beam to low beam and back again etc, so you don't actually get stuck on full or low. Do not know if this is true on earlier models. |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Tue Oct 23, 2018 8:01 am Post subject: |
Apparently, these specific devices are intended for applications like this. According to the datasheet above, at full operating current of 8 amps, their resistance drops to 0.06 ohms, resulting in a voltage drop of 0.48 volts. At a 4 amp load (typical 55 watt lamp), the IxR drop would likely be around 0.24 volts. I could probably live with that. |
Sorry to revive an old thread, but did you ever try one of these?
I bought some Hella H4's from Bus Depot recently. For now I only have the 60/55 bulbs, but I'd like to try some of the 100W or 130W bulbs.
If I understand you correctly, I want to limit the initial inrush current to the cold lamp filaments with the gauge of wire from the relay to the lamp. Since I want to try out different wattage bulbs, would it be a sound plan to install a relay rated to the highest wattage bulb, and then swap out different AWG jumpers from the relays to the bulbs? ie 14AWG for 100W and 12AWG for 130W? It would still be OK to feed the relays with an 8AWG from the back, right? _________________ ~Kevin
My 1968 Campmobile |
Posted: Tue Oct 23, 2018 2:26 pm Post subject: |
Hikelite wrote: |
If I understand you correctly, I want to limit the initial inrush current to the cold lamp filaments with the gauge of wire from the relay to the lamp. Since I want to try out different wattage bulbs, would it be a sound plan to install a relay rated to the highest wattage bulb, and then swap out different AWG jumpers from the relays to the bulbs? ie 14AWG for 100W and 12AWG for 130W? It would still be OK to feed the relays with an 8AWG from the back, right? |
8 AWG from the back is fine. I'd use 14 AWG to the lamps, unless testing shows it isn't big enough. Like I said above, on my first pass at this I used 10 AWG to the lamps, and after a few uses, welded the relay. Changed to 14 AWG (and a new relay), and all was fine. This was with 100 watt H1 bulbs.
I still think thermistors are the best solution, but I haven't tried them (yet), as I currently am running stock 55/60 H4 lamps. In the next day or two, I'll look at the thermistor datasheets and come up with some part recommendations. _________________ '71 panel, now with FI
Posted: Tue Oct 23, 2018 3:25 pm Post subject: |
Hikelite wrote: |
I still think thermistors are the best solution, but I haven't tried them (yet), as I currently am running stock 55/60 H4 lamps. In the next day or two, I'll look at the thermistor datasheets and come up with some part recommendations. |
thanks Telford
I need to place another order for some electrical supplies anyway, so I'll add some of these and try it out. I'm assuming you mean someplace like Mouser or Digikey?
I already decided I should order some extra relays in case I weld some _________________ ~Kevin
Posted: Tue Oct 23, 2018 11:19 pm Post subject: Re: Refurbishing & upgrading 1968~79 VW Type 2 headlamp syst |
Yup - either of those suppliers should work.
I'd look for a part that's maybe 5 ohms cold (inrush current would be less than 3 amps) and can handle 8 amps (100 watt bulb) or 10 amps (130 watt bulb). Should give a nice soft start. (Maybe not so good on high beams if you have a flashing type headlight relay - flash could be a bit slow...)
Extra relays are a good idea. _________________ '71 panel, now with FI
slowbird Samba Member
Joined: June 25, 2019 Posts: 2 Location: North Carolina
Posted: Wed Jun 26, 2019 12:37 pm Post subject: Re: Refurbishing & upgrading 1968~79 VW Type 2 headlamp syst |
Sorry to revive an old one, but this post is exactly what I was looking for and is brilliant in its thoroughness. Thanks, NASkeet.
I have but one question (My first as a member of TheSamba after years of lurking and gazing at my long neglected Bay Window, Jessica)
In the below diagram, where exactly are you connecting the Red Wire (relay 30) at the fusebox?
I see on the diagram that it's to the unfused side of a 16 fuse then unfused R/W to Battery (+).
I am interpreting your diagram to mean the red wire is a new wire (USA) to unfused side of Accessory (Terminal 9 on my '78 Bay).
Is that correct?
_________________ ------------------
Slowbird
Winston-Salem, NC
'78 BAY
"Sure you can, you just haven't yet." |
Posted: Wed Jun 26, 2019 1:57 pm Post subject: Re: Refurbishing & upgrading 1968~79 VW Type 2 headlamp syst |
Correct. The bottom row of connections on the fuse block are the unfused connections. IIRC, the right end are the red full-time power fuses. Connect to an available open terminal on the bottom row with all of the other red wires. _________________ '71 panel, now with FI
