Jeep resistor for blower fan
joshtw709
joshtw709 is offline
PostPosted: Fri Feb 23, 2018 8:35 am    Post subject: Jeep resistor for blower fan Reply with quote
I did this conversion at the same time as swapping in a new front blower fan. fan stopped turning on yesterday, and I discovered a blown fuse. swapped that out and now fan only works on setting 3 and won't kick on when the switch is on setting 1 or 2. I suspect the resistor is at fault? any other things that could be causing this?
1980 rusty light blue westfalia - sold
1987 less rusty white westfalia - daily driver
dhaavers
dhaavers is offline
PostPosted: Fri Feb 23, 2018 8:42 am    Post subject: Re: jeep resistor for blower fan Reply with quote
Classic bad resistor mode. Luckily for you, now it's easy plug & play!
Cool
- Dave
86 White Westy Weekender
"The WonderVan"
alaskadan
alaskadan is offline
PostPosted: Fri Feb 23, 2018 8:51 am    Post subject: Re: jeep resistor for blower fan Reply with quote
How long did it last?
dhaavers
dhaavers is offline
PostPosted: Fri Feb 23, 2018 9:00 am    Post subject: Re: jeep resistor for blower fan Reply with quote
Have you checked, or are we just assuming your switch, wiring & connectors are all good?
- Dave
"The WonderVan"
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Feb 23, 2018 9:07 am    Post subject: Re: jeep resistor for blower fan Reply with quote
I like the accessibility of this mod, but haven't been too impressed with the quality of the aftermarket resistors themselves. Perhaps an OE Jeep version would be a wise investment.
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30
dhaavers
dhaavers is offline
PostPosted: Fri Feb 23, 2018 9:28 am    Post subject: Re: jeep resistor for blower fan Reply with quote
FWIW, my $12 OE Jeep (Mopar) "Made-in-USA" resistor has been running for 3 years so far...
<maintaining crossed fingers>
- Dave
"The WonderVan"
wesitarz
wesitarz is offline
PostPosted: Fri Feb 23, 2018 12:50 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
- Dave
Ha,ha,ha,ha. $25 in Canada. Didn't check to see where it was made.
djkeev Premium Member
djkeev is offline
PostPosted: Fri Feb 23, 2018 4:37 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
Those types of resistors are tough things .....
BUT
They MUST BE IN THE BLOWER AIR STREAM to be cooled or the will over heat and burn out rapidly.
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Fri Feb 23, 2018 4:49 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
i've got some extra ceramic resistors from my AC delete... i wonder if it would be smart to mount those in a port like the Jeep resistor for easy replacement. the ceramic ones have a lower surface temp due to dropping the voltage over a larger mass and surface area. they still need cooling air flow but i think i'll look at doing this when i tackle my fan. also have the Dorman wire coil resistor but those coils do run like a toaster element. very hot. it just seems to be a slight increase in fire hazard to run them in a plastic plenum subject to debris infiltration.
-dan
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Feb 23, 2018 4:58 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
Mine has been working well for about 9 months and they're mounted in the plenum air flow. Easy peezy to replace. How long did the failed ones last?
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
dhaavers
dhaavers is offline
DO IT, and post up a new thread! Almost anything's better than the original, and the more good options the better...
Cool
- Dave
"The WonderVan"
IdahoDoug
PostPosted: Fri Feb 23, 2018 5:08 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
I've never thought of this, but having a toaster element in the airflow also means in the summer when you turn the fan on for cooling air, it's getting heated by these things. Argh.
djkeev is offline
PostPosted: Fri Feb 23, 2018 5:30 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
I've seen OEM fan resistors melt the plastic they are mounted in.
They don't run all that cool.......
Dave
Ghia
Vanagon
Beetle
Paulbeard
Paulbeard is offline
PostPosted: Fri Feb 23, 2018 6:48 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
That was why I replaced mine with the Jeep version. Seeing that blistered plastic was not great. Cruise around on low fan speed means lots of heat in that old plastic box.
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
dhaavers
IdahoDoug
PostPosted: Sat Feb 24, 2018 3:02 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
Hi Josh,
So I think this is the third time asking how long the Jeep resisters lasted for you. Any input for the herd? Thanks.
Doug
crazyvwvanman
crazyvwvanman is online now
PostPosted: Sat Feb 24, 2018 3:41 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
Checking his photos and posts, he installed it about 7 months ago.
He also said it smelled when in speed 1 or 2, so maybe it had a problem from the start.
Resistors warm up when in use. They are rated in watts for a reason. They need to be mounted where there is airflow or they may overheat. If they are not rated for enough watts they may die, even with airflow. If the motor stalls or doesn't get up to speed the current will be higher than normal and the resistor will get hotter than normal. This can burn out the resistor and/or cause melting nearby. This is not a flaw with the resistor.
Mark
dhaavers
dhaavers is offline
PostPosted: Sat Feb 24, 2018 3:43 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
^^^ Hasn't been on since he posted this. Probably out pulling the dash...again... Wink Rolling Eyes
- Dave
"The WonderVan"
DanHoug
DanHoug is offline
PostPosted: Sat Feb 24, 2018 3:54 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
Dave
the OEM ceramics run really hot, too hot to touch. but they don't run red hot at the ignition point of some combustibles. so, they are *somewhat* safer but the Jeep wire coil ones can be safe too mounted properly.
it's like my 1B14 Toastmaster toaster. runs REALLY hot with bright red nichrome wires and makes toast faster than any modern toaster that has reduced the wire temp for consumer safety. thank lawsuits for your modern slow toaster but if used smartly, red hot is just fine as evidenced by my 1948 beauty still in daily service without incident.
http://kaxeengineer.blogspot.com/2008/09/american-engineering-toastmaster.html
-dan
dhaavers
dhaavers is offline
PostPosted: Sat Feb 24, 2018 6:31 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
^^^ So much truth!
FWIW, same reason I recently sprung for the B&D "Rapid Toast" model:
https://www.amazon.com/BLACK-DECKER-2-Slice-Stainless-TR3500SD/dp/B00LU2HVAO
50% faster = 90% better! Cool Wink
Back on topic, I suspect a <somewhat> faulty resistor is the cause of the OP's issue.
- Dave
"The WonderVan"
joshtw709
PostPosted: Sat Feb 24, 2018 9:57 pm    Post subject: Re: jeep resistor for blower fan Reply with quote
been installed for about 7 months. on the road so I won't be pulling the dash for another couple weeks.
update - runs in setting 1 and 3 but not 2. my guess is faulty resistor. will keep y'all posted.
