Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Wed Oct 15, 2008 3:10 pm Post subject: Coolant tank leak at sensor |
I can't seem to find anything on this problem.
I just put in a Subaru engine into my '89 Westy and fired it up for the first time today. As I started bleeding the system, I noticed that there is now a leak around the lever sender on the burp tank. It didn't do this with the old WBX. I tried lightly tightening it up with no change. I tried a little plumbers tape making sure no tape will get into the coolant itself, with no results. There does not seem to be any cracks around the hole for the sender. I am at a lose.
Whats the best way of fixing this? Do I need a new tank or is there any chance a new sender will solve the problem? Can i just use some rtv?
Many thanks for the help! _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
transporterjr Samba Member
Posted: Wed Oct 15, 2008 5:16 pm Post subject: |
I've had two of these go on me. The sensor itself cracked, pull it out, take off the O-Ring and it probably will have a radial crack.
The latest one I bought from the dealer is a slightly different design, perhaps it will last longer.
John |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Wed Oct 15, 2008 6:09 pm Post subject: |
The plastic gets fragile with age and cracks.
I had one break to bits under pressure, spewing coolant.
Definitely don't try to re-use it, a new one is only about 11$ from van-cafe, it's one of those cheap-insurance items. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
