Krmnnghia Samba Member
Joined: March 28, 2005 Posts: 797 Location: Michigan, Land of salty roads!
Posted: Thu Oct 16, 2008 4:37 pm Post subject: Has anyone re-tapped King/Link Carrier Zerk holes? |
After removing a pair from a 64 beam I noticed all 4 of the holes will need to be tapped for new zerks. Has anyone done this? Any idea what size I need to tap and where to get those zerks? Thanks |
troll77 Samba Member
Joined: July 03, 2008 Posts: 90 Location: victorville,california
Posted: Thu Oct 16, 2008 4:48 pm Post subject: |
wolfsburg west has the zerks,if iam right they should be 10mm but they also may be 8mm but wolfsburg west has them both |
ladybug89 Samba Member
Joined: February 27, 2005 Posts: 581 Location: City of Orange,CA
Posted: Thu Oct 16, 2008 4:51 pm Post subject: |
i did it when i narrowed my beam. drilled the hole and tapped them and drilled a hole in my urathane bushing and greased up my beam (synthetic grease). no problem what so ever.
doesnt squeak either _________________ 1958 bug - 1958 baja - 1962 vert - 2000 Golf |
Slow6t5 Samba Member
Joined: September 29, 2008 Posts: 327 Location: Texas
Posted: Thu Oct 16, 2008 4:57 pm Post subject: |
If you have an Ace Hardware local, they have both on the shelf, straight and angled, 8mm and 10mm. |
Posted: Thu Oct 16, 2008 5:10 pm Post subject: |
So if they are currently 10's then I would have to tap larger correct? What do they make larger than a 10? |
Posted: Thu Oct 16, 2008 5:25 pm Post subject: |
You might be able to follow the threads with a tap and clean them up. I would use a sealant if it works. Other than that I am stumped.
If you do follow them and it works, make sure to clean out all the shavings out of the tubes. Some may say don't worry about it, I just have a thing for metal shavings and grease. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Thu Oct 16, 2008 5:31 pm Post subject: |
Hi, the size is the threads, not the hex.
They are made in 6mm, 8mm and 10mm
also in 1/8, 3/16, 1/4, 3/8
There is a 1/2" but its for industrial use, you wouldn't want it.
If you are stripped out and you are already at the largest size, weld it shut, redrill and retap.
Ghia
Vanagon
Beetle
