74 Westy Build
Page: 1, 2, 3, 4  Next
pinkfloydms
pinkfloydms is offline
PostPosted: Fri Oct 17, 2008 3:57 pm    Post subject: 74 Westy Build Reply with quote
The trip to pick up the bus was longer than I first thought it would be. Anyway it's back now. Here are a few pics.
www.panicstream.com
My 74 Westy in the works!
http://www.thesamba.com/vw/forum/viewtopic.php?t=324463
PicklePickle
PicklePickle is offline
PostPosted: Fri Oct 17, 2008 4:01 pm    Post subject: Reply with quote
interesting. It apparently was originally white, then painted green inside and out and then later painted red on the outside.
Love the bus!! Congrats! You're in for lots of learning and fun! Laughing
"Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
1970 Yellow Beetle aka "Melbourne"
pinkfloydms
PostPosted: Fri Oct 17, 2008 4:02 pm    Post subject: Reply with quote
I figured I would start tearing it apart today.
The floor actually looked pretty good in the back so far.
What is this hole for?
And this box?
I'm going to have to replace the front floor plan.
And the doglegs.
A few quarter panels.
And the front cap.
The frame underneath looks pretty good. Anyway now comes the fun part of cutting, welding, cleaning, and getting rid of that ugly as paint. Smile
www.panicstream.com
pinkfloydms
PostPosted: Fri Oct 17, 2008 4:04 pm    Post subject: Reply with quote
Yeah that's what I was thinking. After that I then thought oh noo there will be bondo everywhere. But I went around it with a magnet and it stuck everywhere so I may be lucky.
I dunno what color I'm going to throw on it yet.
www.panicstream.com
PicklePickle
PostPosted: Fri Oct 17, 2008 4:10 pm    Post subject: Reply with quote
Paint doesn't always necessarily mean bondo. Some will spray or roll a coat to sell a vehicle. Small time car dealers are famous for it.
On the other hand, someone went through a fair bit of work to convert it to sage green at some point in history. Then some goofball went and slapped red over it. When/if you paint one day, I would go back to the sage green if I were you since most of the interior is done that way anyway. That means you don't have to strip the interior to get it to match the outside.
hazetguy
hazetguy is offline
PostPosted: Fri Oct 17, 2008 4:15 pm    Post subject: Reply with quote
wow, you must have the good drugs.
what year is the bus?
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
PicklePickle
PostPosted: Fri Oct 17, 2008 4:17 pm    Post subject: Reply with quote
sorry, don't get it...
zachary
zachary is offline
PostPosted: Fri Oct 17, 2008 4:18 pm    Post subject: Reply with quote
i kind of dig those stripes, if only The Joker didn't chose the color scheme.
hazetguy
hazetguy is offline
PostPosted: Fri Oct 17, 2008 4:20 pm    Post subject: Reply with quote
wondering where you see the "original white" on that bus?
pinkfloydms
I'm not really positive I want to go with a OG color. I know this will prolly make some people mad. Laughing
I don't really mind stripping all of the interior paint and prepping it. I have all winter and prolly even longer. Smile
I was thinking of a dark silver/grey or maybe charcoal? I really have no idea yet though. Confused
www.panicstream.com
pinkfloydms
PostPosted: Fri Oct 17, 2008 4:21 pm    Post subject: Reply with quote
It's a '74 automatic. I'm not sure if I am going to change it over to a manual or not yet.
www.panicstream.com
hazetguy
hazetguy is offline
PostPosted: Fri Oct 17, 2008 4:23 pm    Post subject: Reply with quote
74. then i stick to my claim that the bus was not "originally" white at all, but that neon/ravenna-not-ravenna/yosemite westfalia only color.
(it also has later westfalia cabinets/seats in it in case you were not aware)
PicklePickle
PostPosted: Fri Oct 17, 2008 4:25 pm    Post subject: Reply with quote
Not completely sure on the original color, but it was definietly painted green on the interior at some point. There is green paint all over everything (including the gas pedal). The door shows white inside where the plastic was not taken off when it was sprayed inside.
pinkfloydms
PostPosted: Fri Oct 17, 2008 4:26 pm    Post subject: Reply with quote
I don't know.
The only white I see on it is behind the door panels. Everywhere else is green. And if it was some color other than green, then who ever painted it green did a pretty good job.
www.panicstream.com
PicklePickle
That might look good, but would be very hot in a vehicle with no a/c.
PicklePickle
PostPosted: Fri Oct 17, 2008 4:33 pm    Post subject: Reply with quote
Starting from the top of the thread: pics 5 and 12. Left of the driver's headlight recess, you can see where the green spray stops.
PicklePickle
PostPosted: Fri Oct 17, 2008 4:35 pm    Post subject: Reply with quote
Pic 10, in the hole the green spray fades to white
pinkfloydms
PostPosted: Fri Oct 17, 2008 4:43 pm    Post subject: Reply with quote
In the back, under the green, there isn't any other color that I can see.
What is the little canister for up front? It has a tube coming out and a fill hole. You can see it in the pic of the front floor pan.
www.panicstream.com
PicklePickle
PostPosted: Fri Oct 17, 2008 4:47 pm    Post subject: Reply with quote
You are probably referring to the window washer fluid reservoir. You put your window washer fluid in there and pressurize it so that you can clean your windows when you need to. However, a lot of the old systems have pressure leaks that prevent them from operating properly. You'd just have to test it.
busnerd
busnerd is offline
PostPosted: Fri Oct 17, 2008 4:48 pm    Post subject: Reply with quote
I bet the nose and front doors have been replaced from a white donor bus.
Clarke B.
samba member # 3245
'78 Westfalia Dakota Beige
'64 Camper
Page 1 of 4
