dubshack1 Samba Member
Posted: Sat Oct 18, 2008 4:50 pm Post subject: RGB stripped nut. |
I have an issue that needs a quick fix,only needs to last a few more weeks,then a straight Axel swap. I was giving my RGB axle a little more torque when the nut stripped out and the axle, I was wondering if it was possible to re cut some threads? use a smaller nut? any help would be great. Thanks |
58deluxerag Samba Member
Posted: Sat Oct 18, 2008 4:52 pm Post subject: |
Was it only the nut that stripped? get a new nut. I might have a die that big to clean the axle threads, but I'm not positive. either way you might want to just swap out the stub & the nut.
I've seen nuts only strip out and I've put a new one on and have been fine. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
Posted: Sat Oct 18, 2008 5:19 pm Post subject: |
It was the nut and axle, just happened, don't know what i will do at this point,still looking into my options,but looks like I will be changing the axle and nut, not fun this close to the show. |
Posted: Sat Oct 18, 2008 5:43 pm Post subject: |
it's not that bad. Just change the outer half with the stub axle. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
mightymouse Samba Member
Posted: Sun Oct 19, 2008 12:54 am Post subject: |
wow, how the hell does this even happen. ive put SO much torque on those, and taken off nasty ass corroded ones. never ever seen one eat threads.. odd. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Posted: Sun Oct 19, 2008 5:46 am Post subject: |
mightymouse wrote: |
wow, how the hell does this even happen. |
Shitty aftermarket replacement parts?
Ever heard the story about the Wolfsburg West axle nut with no threads?
Not sure where the nut came from he's using but replacement parts these days are mostly crap. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
crusty67t2 Trailer Park King
Joined: January 11, 2005 Posts: 607 Location: flori-duh!!!
Posted: Sun Oct 19, 2008 7:36 am Post subject: |
ive had them both strip we are dealing with 40-50+ year old parts...
I have a couple of stub shafts If you need one. Send me a pm. _________________ 62 original paint Turkis double cab
59' rag top |
Posted: Sun Oct 19, 2008 11:53 am Post subject: |
I need one at this point, dont know what I have, pretty sure it is the stock 60 RGB, so any help,especial local would be nice. |
Posted: Sun Oct 19, 2008 12:00 pm Post subject: |
I have some out of a '59. axles were cut but the reduction boxes & internals should be good. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
Posted: Sun Oct 19, 2008 7:31 pm Post subject: |
how much? money is tight, it would be a big help. |
