Godsbug Samba Member
Joined: April 29, 2006 Posts: 996 Location: Renton, WA
Posted: Wed Oct 22, 2008 12:08 pm Post subject: 1990 Cabriolet help from a distance |
My mom is in CA and I'm up here. She said her car won't start, but it will turn over. It's a 1990 5 spd Cabriolet. My brother looked at it and said it doesn't have spark. Any ideas on how to fix it? The battery is good and the starter spins. Unfortunately that's all I know right now but I told her I'd ask.
Thanks! _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
kamzcab86 Samba Moderator
Posted: Thu Oct 23, 2008 3:40 pm Post subject: |
Test for primary voltage at the ignition coil. If there is no voltage, the ignition switch could be faulty (the switch is now a common failure item on these old cars). _________________ ~Kamz
2016 Golf GTI S
Posted: Mon Oct 27, 2008 9:53 am Post subject: |
OK, my brother checked the ignition coil and it had voltage. What other options do we have? _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Hiramhaus Samba Member
Posted: Tue Oct 28, 2008 7:36 pm Post subject: |
I have a cabriolet and it would turn over and not start, had power to the coil but no power to the Hall sensor. I ended up replacing the distributor. It could also be a problem with the air flow sensor. There is a cabriolet specific site as well as the vortex that might be helpful, I am only familiar with my 93 cabriolet and my friends 86 vanagon. Good luck.
http://www.cabby-info.com/
http://forums.vwvortex.com/zeroforum?id=152 _________________ 1969 Ghia
2016 Audi Q3 |
Posted: Wed Nov 19, 2008 1:11 pm Post subject: |
The distributor was the problem. Thanks for your help! _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
