duderanchero Samba Member
Joined: October 25, 2008 Posts: 166 Location: el paso, tx
Posted: Sat Oct 25, 2008 11:49 pm Post subject: Shifter for '91 Vanagon? |
Hi, I've got a '91 Vanagon Carat. My shifter broke off at the bushing, and I'm looking for a new one. Anyone know of an online retailer that still carries these? Also, was a solid-metal lever (rather than hollow) ever made to fit the Vanagon? I haven't taken apart the whole assembly, so maybe it's got to be hollow, but seems like it's just asking for trouble. If I had a forge around, I'd just bang one out. I already hit all the salvage yards here in El Paso, TX with no luck at all. Any help would be much appreciated. Even a part number on the damn thing would be helpful right now.
Thanks,
James |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Sun Oct 26, 2008 5:30 am Post subject: Re: Shifter for '91 Vanagon? |
They don't break often but it happens. The break occurs at the small hole for the setscrew. Some people put a splint inside and then weld it back to one piece, grinding the weld smooth. The outer diameter needs to stay the same so the parts can slide down past the repair.
The part number is 251 711 121E.
Mark
duderanchero wrote: |
Thanks,
James |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Sun Oct 26, 2008 7:14 am Post subject: |
Got Bentley? _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Posted: Sun Oct 26, 2008 11:14 pm Post subject: |
Thanks for the replies. I'll probably end up welding the piece, which is what I would have done already if I had a rig here. This also means I'll have to scrape off the Gorilla Glue I'd used for a temporary fix. Never fun.
I do have the Bentley manual, but I don't see how it would be helpful at this point. When I'm in the dis-/re-assembly step, I'm sure it will come in handy.
James |
mccabe Samba Member
Joined: March 20, 2007 Posts: 101 Location: Olympic Peninsula
Posted: Mon Oct 27, 2008 4:45 pm Post subject: |
I had the same thing happen 2 weeks ago. Also a 91'. Mine broke at the set screw ( scared the crap out of me ) I took it apart and had it welded now Im back in action. _________________ 1991 Carat 2.1wbx
vans "checkerboards" size 9.5 |
Ryan Alfonso Samba Member
Joined: March 23, 2007 Posts: 101 Location: Half Moon Bay, CA
Posted: Mon Oct 27, 2008 5:51 pm Post subject: |
I've got a spare I can sell you cheap. Don't need it since switching to a 5spd. |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Tue Oct 28, 2008 12:58 pm Post subject: |
you can check w/ gordi davis at 4eva4 603-313-5333 [email protected] or john or mike at johns car corner 802-722-3180...both these guys are great and i have never been unable to locate a part through them |
Posted: Wed Oct 29, 2008 2:46 pm Post subject: |
Thanks to everyone for the replies. I'm going to weld it today, and I hope the effort is successful. If not, it's good to know I have options.
James |
