What ups with my headlights?
HeftySmurf
HeftySmurf is offline
PostPosted: Mon Oct 20, 2008 10:45 am    Post subject: What ups with my headlights? Reply with quote
I am having an issue with my headlights. I have replaced the ignition switch and installed headlight realy ugrades. Next i a going to switch the head light switch its self, it seems tight, I am curious though to what part need to be repalced for the high and low beams. The only work when I keep the brites pulled back manually. Do I need this part? Obviously the piece that inside it was worn out.
http://www.van-cafe.com/home/van_1224524127139/pag...ntrol.html
-Lorenzo
90 GL w/ Bostig
fairweather
fairweather is offline
PostPosted: Mon Oct 20, 2008 10:53 am    Post subject: Reply with quote
With my van the key needs to be turned on for the lights to work, with the key off they behave just as you describe.
When I installed my relay upgrade i thought the same thing.
TV
HeftySmurf
PostPosted: Mon Oct 20, 2008 11:08 am    Post subject: Reply with quote
Yeah its wierd, my van was sitting for a bit like 2 weeks and when I started it the light came on, but then went out. I dont know if this is realted but I did smoke tail lights, new side markers, and turn signals. Only the driver side front running light and rear running light work with the switch engaged. When the flashers are on the reds on both side work and so does the passenger side turn signal, but the drivers side doesnt blink just stays on. This really my first gremlin I've run into...
Also when i turn on the turn signal to the left a buzzing noise come from the fuse box, but no blown fuses... Weird ... My uncle is gonna fuss with it this weekend, I gave up for the time being...
-Lorenzo
90 GL w/ Bostig
everist
everist is offline
PostPosted: Tue Oct 28, 2008 1:51 pm    Post subject: Reply with quote
I'm having the exact same issue... any news on this?
HeftySmurf
PostPosted: Tue Oct 28, 2008 2:24 pm    Post subject: Reply with quote
I havent had time to touch my van in like 10 days.. Unfortunately. I going to change the wiper lever which controls the dimmer. I'm also switching in dimmer lever with cuise control. No clue yet to as whats going on with the signals and running lights yet.
-Lorenzo
90 GL w/ Bostig
PDXWesty
PDXWesty is offline
PostPosted: Tue Oct 28, 2008 5:03 pm    Post subject: Reply with quote
I'm not sure about your headlights, but I found out something about the turn signal bulbs when I replaced mine. The fronts have two filiments in them, one for running and one for turns. It matters which way you install the bulbs to get them to blink properly. If one's not working, try taking it out and turnig it 180 before reinserting.
twscott
twscott is offline
PostPosted: Wed Oct 29, 2008 4:54 am    Post subject: Reply with quote
I had something that sounds similar - lights would not work at all except when I pulled back on the dimmer switch. I pulled the steering wheel, cleaned the contact ring inside, put a little dielectric grease on it and it put it back together - Lights again Laughing! I think the dimmer switch may be going, but this worked for now.
87 Westy, "Rose"
westyventures
westyventures is offline
PostPosted: Wed Oct 29, 2008 6:39 am    Post subject: Reply with quote
When the headlights go out for any reason, always check the ground connection at the grounding star above the fuse panel, to the left on the body under the dash. VW actually overloaded the headlight ground here--the best fix is to ground each headlight AT the headlight mounting.
GBA 88West LA
GBA 88West LA is offline
PostPosted: Wed Oct 29, 2008 8:45 am    Post subject: Reply with quote
same with mine when i did the smoked signals and tail lenses they didnt blink properly one side did one side didnt i had crossed the wires, and had the blinker wire hooked to the running wire so i was getting a fast blink on one side. when i did the sa kit i had a bare wire grounding out, causing the one light to go out, after a wrapped the wire no prob
