VR6 vanagon Samba Member
Joined: October 26, 2008 Posts: 93 Location: New Port Richey Florida
Posted: Wed Oct 29, 2008 9:02 am Post subject: I need a pinout for the ECU of a 1997 2.8 jetta |
I have just gotten a tachometer for my vanagon with an MK3 from a 97 Jetta, just trying to figure out what pin is for the tach, does anyone know?
Thank you and have a great day! ?:
OR can I just attatch it to the coil? If so, what color should the wire be?
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Wed Oct 29, 2008 10:13 am Post subject: |
I have looked on vwvortex and I am just not finding the info I need, any other help would be GREATLY appreciated. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10347 Location: Sunshine Coast B.C.
Posted: Wed Oct 29, 2008 10:24 am Post subject: Re: what pin on a 1997 MK3 ecu is for the tachometer? |
VR6 vanagon wrote: |
Thank you and have a great day! |
My Jetta install is an OBD1 ABA.
The tach from my '94 Jetta cluster (removed) worked with signal from 22/68 from the ECU or 1 from the coil. (got that info from the Vortex. Hint hint ) With either wire, it was a little "jumpy" at idle (like vibrated a *little*).
I'm not sure if tach needs to be used in conjunction with the Jetta cluster.
Please post if you get the same results or an improvement using the tach with the Mk3 cluster.
A quick look at Bentley and things look much different for OBD2. I don't see a 1 in the fuse/relay box portion of diagram. Have a look. If you find 1, trace it back to the ECU. This may give you the wire.
But.....
1 from the coil might work too. For my Vanagon hi/low pressure oil warning unit I installed, I needed to connect to 1 of the coil. Pics below of added wire to Jetta coil. If you add a wire, use a spade type connector. I used a ring. It's possible your coil has the leads shown in the pics soldered in place. Don't know how you'd deal with that.
On my Jetta tach, there are 4 pins. IIRC, 15 is on one end of the row of 3 pins, - is middle and 1 is the other end. The top 4th pin may be for illumination.
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Oct 29, 2008 10:34 am Post subject: |
My engine is an OBD II, It is a 2.8 liter from a 1997 jetta. I have all the wires on the harness, just wanting to know what one is for the tach. I have been searching samba and vwvortex, but am finding nothing in the way of a diagram, or a wire color for my specific engine. |
Posted: Wed Oct 29, 2008 10:39 am Post subject: |
Got Bentley? _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Wed Oct 29, 2008 10:47 am Post subject: |
No, I don't have a bentley guide. Was hoping I wouldn't need it to just hook up a tach, was also told that it might not even have the pin info I need in it. |
Posted: Wed Oct 29, 2008 11:24 am Post subject: |
IMHO, totally worthwhile getting.
And my bad. Shoulda known from your sig what engine you had!
The 2.8 VR6 ignition coil setup is quite different. From Bentley: ".... three double ended coils within one housing".
Check your Pmail.
VE7TBN |
Posted: Wed Oct 29, 2008 11:28 am Post subject: |
Sooooo, is it possible to connect the tach through the coil instead of the ECU??
there is only 1 connector on my coil, does anyone know what color the wire should be where I connect in? |
Posted: Thu Oct 30, 2008 6:59 am Post subject: |
bump |
syncro vr6 Samba Member
Joined: October 31, 2008 Posts: 11 Location: monroe,wa
Posted: Fri Oct 31, 2008 4:58 pm Post subject: |
I think it has to come from the ecu. I ended up buying a 6 to 4 cyl tach converter to use the stock one. |
