ovaaldirk Samba Member
Joined: November 02, 2014 Posts: 2 Location: Netherlands
Posted: Sun Nov 02, 2014 8:00 am Post subject: WW cam gear |
I want to buy a WW 36hp camshaft, but what cam gear wil fit? |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Sun Nov 02, 2014 10:41 am Post subject: |
Here are your choices. The only new cam gears I've seen are made for Porsche engines (same pitch, same size). Only problem with that is you get to pay the Porsche price for it. If you have a usable gear on your old cam then just simply cut the rivets, remove the gear and then drill and recess the holes to fit an 8mm bolt. Check this thread for an idea of what it takes:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6612387&highlight=#6612387
I have discovered that the new aftermarket 1600 cam gears are a smaller diameter (same OD size as 36hp gears) and will fit on a 36hp application. You would also have to use a 1600 crank gear due to the different pitch. I have a couple engines running at the moment that use that swap with no problems. No aluminum flakes in the oil tell me the fit is good. The final option is a straight cut cam gear set, any brand works. While they do make a little more noise that a helical cut gear, it's not unbearably loud (sound will depend on brand). _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Posted: Sun Nov 02, 2014 1:34 pm Post subject: |
O.K. thanks , straight cut gear it wil be than.
I Always thought that on 36hp engines the crank and the cam where closer together |
Posted: Sun Nov 02, 2014 5:46 pm Post subject: |
ovaaldirk wrote: |
They are.........all aftermarket 1600 gears these days are the smaller 36hp diameter to allow for greater clearance, that is why they (straight cut or helical) can be used in a 36hp. _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Nov 06, 2014 9:14 pm Post subject: |
I run straight cut gears on my 36hp, no issues
Supplied by Mr. Motorhead |
