johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed Dec 10, 2014 12:50 pm Post subject: |
i see what you're saying, i didn't get them mixed up though. I never removede the inside (thinner) spacer becuse id have remove the axle bearing. Just ondering what direction the inside bearing goes. Edges are diffrent. One side of the spacer feels flat and other the edge is machined. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Gotdub Samba Member
Joined: April 11, 2011 Posts: 2 Location: United kingdom
Posted: Thu Jan 15, 2015 4:17 am Post subject: |
Sorry to bother
I have recently done the short axle conversion on my 62 notchback. I have used the type 3 bearing castings I was wondering if anyone has a part number or picture of the correct bearing/seal casting to use. I do have the orignall short axle castings but think they are off a 63 beetle.
Many thanks matt |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Gotdub Samba Member
Posted: Thu Jan 15, 2015 10:26 am Post subject: |
W1K1 thank you very much turns out I already have that size bearing casting on the car many thanks thou saved me a lot of brain ache
Matt |
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
Posted: Tue Oct 20, 2015 7:56 am Post subject: |
I am currently making the short axle swap and being very careful about it as I go, car has been on stands for three weeks now. (including lowering, adjusting torsion bars etc). 4 stud car.
So I am using the short beetle axles with matching tubes and I also have the matching beetle bearing retainer caps.
Will be fitting the original type 3 drums back on.
So now I am considering the machining of the wheel plate?(heavy cast part that the wheel studs fix into) and found that this needs a total of 15mm machined off it since this is the basic difference between the axles differing long and short splines.
The point I am now getting to is that since the new short axle casting ends have a 3mm shallower bearing seat that this will also push the "heavy cast plate" and the attached drum 3mm further out away from the backing plate than original, Yes??
So in the end I am planning to machine my "heavy cast plate" 3mm off the back side and 12mm off the outside nose giving me the 15mm total and putting my drum back to where it would have been originally.
I have not noticed any other mention of this issue in the thread, or maybe the 3mm difference in the drum to backing plate is not an issue anyway??
Before I make a mistake, does this all make sense?? _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Tue Oct 20, 2015 11:21 pm Post subject: |
No, Do not machine anything off of the back side of the drum/hub. That will put the drum into the backing plate and the shoes. Bad idea. just remove the 15mm from the snout of the drum hub to achive the correct fit. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
Posted: Tue Oct 20, 2015 11:46 pm Post subject: |
flyinglow94 wrote: |
No, Do not machine anything off of the back side of the drum/hub. That will put the drum into the backing plate and the shoes. Bad idea. just remove the 15mm from the snout of the drum hub to achive the correct fit. |
But doesn't the 3mm shallower bearing seat push everything 3mm further out relative to the backing plate?
I thought that taking this 3mm off would only put the drum back where it was rather than 3mm further out than normal?? _________________ John
68 Aussie notch
Posted: Wed Oct 21, 2015 12:00 am Post subject: |
No. Don't over think this, as you can see a lot of people have done this without shaving the inside. You are using a type 3 drum and backing plate. after you bolt everything up and go to mount the drum you will see why. The snout of the drum is the only piece that needs to be shaved for the nut on the axle. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
Posted: Wed Oct 21, 2015 12:03 am Post subject: |
PIMPPRIDE wrote: |
sounds good... but lets fix it first...
you should not machine the inside of the drum or hub... just the outside snout... ( if you machine the backside / inside you run the risk of running the drum or hub down into the brake shoes, wheel cylinder, springs ect... )
ultimately if it worked for you that's good... but its not the correct way...
the correct way to do it is to swap to short axles and swap the bug short axle end castings on to the the type 3 tubes... this is where the difference is... on your 1967 type 3 this would have given you the ability to keep the Z bar as the type 3 tube has the hoop for it... the bug does not...
there is a drift pin that holds the end casting to the tube... common on both type 1 and type 3 ( search the gallery for photos )
from there... you do have to take off 50 thou or so... ( about the size of the castle nut ) from the snout of the type 3 drum / hub...
Anthony / ISP WEST |
Posted: Fri Jan 15, 2016 7:44 am Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
All finished a couple of months ago now and thought I would post my result. This pic was taken straight after lowering. It has settled a bit lower now and has a nice touch of negative camber.
It was also lowered a bit further front and back. Already has Bert3 drop spindles on the front so it just needed one outer tooth there.
In the end I have machined the 15mm off the wheel hub but I did do this as I had originally thought with 3mm off the back side and 12mm off the front side. It all worked out fine. No rubbing anywhere.
68 Aussie notch
Marvel Samba Member
Joined: May 20, 2004 Posts: 143 Location: Ringwood, England
Posted: Wed Sep 27, 2017 12:11 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Just finished fitting short axles to my Type 34 so the Sprintstars don't rub. Everything is ok except the brake plates aren't clamped tight enough by the wheel bearing housing. What have others done to stop the annoying clonk. Add a couple of gaskets, machine the bearing housing or what?
Posted: Wed Sep 27, 2017 7:48 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Marvel wrote: |
I did not have the problem like this??
I dont know if this matters but did you also change your bearing housings too or is it still the original ones? _________________ John
68 Aussie notch
Marvel Samba Member
Posted: Wed Sep 27, 2017 11:18 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Yes I'm using early bearing housings and axles but not both from the same source. Are early brake plate thicker? AFAIK the early set-up doesn't use gaskets but I've added a couple to help it clamp up tight. Not ideal but better than it was.I'll be looking at adjusting the length of the bolts so the drum is located on the diameter not the thread. |
HenrikL Samba Member
Posted: Wed Sep 27, 2017 11:56 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
What are early bearing housing? There are at least 3 different housings for short axles, 1950-57, 58-64 and 65-66.
Check this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=422140 |
Marvel Samba Member
Posted: Thu Sep 28, 2017 1:17 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Studying the drawings and sectioned drawings I'm fairly sure I've got the right combination of axles and caps. It does mention that the early brake plates are thicker and as I'm using late ones this could be why they don't clamp up tight. Anyone know the difference or have an early one to measure? |
pitargue Samba Member
Posted: Mon Sep 30, 2019 2:16 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Can anyone recommend a machine shop in/near San Jose, CA that can take 15mm off the end for a reasonable price?
I just came from http://victoryautomotivemachine.com/index.html, and they quoted me 2 hours at $150/hour because they have to figure out how to do this.
Then went to https://www.peninsulaautomotive.com/, and they said they can't do it and I should go to a machine shop. Of course, they can't recommend any.
At this rate, probably easier to to get the short hubs from ISP West.
https://www.vwispwest.com/GA-501581.html?p=c3E9aHVi
So, any machine shop recommendations from the Volks? |
W1K1 Samba Member
Posted: Tue Oct 01, 2019 12:46 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
My local shop did it in about 1/2 hour for a case of beer. In fact it took longer to go get the beers and come back to the shop.
If the machine shop doesn't know how to chuck a hub in the machine, and cut 15 mm off the end.... run, run far away
maybe try a local handyman page on facebook, there are lots of retired guys around here with metal working machines in their garages. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Oct 01, 2019 1:16 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
W1K1 wrote: |
maybe try a local handyman page on facebook, there are lots of retired guys around here with metal working machines in their garages. |
Thanks. It's amazing how hard it is to find an automotive machine shop in Sillycone Valley. It's not like the old days where there were so many good machine shops to choose from. Sign of the times? |
Posted: Tue Oct 15, 2019 6:32 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
Found a old style machine shop in Santa Clara, CA. Jay's Precision Machine, 1751 Grant St, Santa Clara, CA 95050.
Jay cut off 15mm on my type 3 hubs. Turn around: 1 day. Cost. $20.
If you have any machining needs, highly recommended. Jay is extremely friendly. If you have the time, Jay has lots of automotive related stories. I made the mistake about asking about the AS-41 case he had in the shop and what he was doing to it. Truly a blast from the past, just the kind of machine shop I used to remember way back when. 5 stars! |
