jim altemus Samba Member
Joined: September 22, 2002 Posts: 366 Location: New Milford CT
Posted: Wed Jan 19, 2011 5:37 am Post subject: |
Jason Eden wrote: |
If I just changed the bearing cover " i dont think it would do it for me " because right now the bearing is right at the end of the cover so I must have to change the spacer that is behind the bearing also. What you think? thanks |
It could be your spacer, though I reused all those pieces from my car when I did the conversion. Here are a couple images of the area in question:
If you somehow got your spacers backwards that might explain things, but then again you shouldn't be able to tighten down the bearing cap if you did.
Jim _________________ aka Jimal
Currently sans Volkswagen |
Joined: March 18, 2002 Posts: 593 Location: Peterborough, Ontario, Canada
Posted: Sat Jan 29, 2011 3:29 pm Post subject: Re: F.Y.I. short Type 1 swing axle's in a type 3 |
I have a type 3 swing axle that is 4 bolt with hubs. and I would like to use the type 3 4 bolt hubs/brakes.
So I need to find:
61-6? beetle axles, tubes, and end castings (with bearings, spacers etc)
65-66 only bearing covers AND spacers?
Then I use the beetle axles
inside the type 3 axle tubes
With the type 1 end castings
using the bearings and bearing covers from
65-66 type 1
as well as type 1 axle spacers (which set of spacers: the 61-6?, or the 65-66only?)
and then button it up with
type 3 backing plates
hubs (machined 0.625" ???)
and the type 3 drums
Anyone help me see this perfectly clear? Thanks guys!
STICKY anyone? |
Posted: Sun Jan 30, 2011 8:39 am Post subject: |
So I need to find:
61-6? beetle axles, tubes, and end castings - Yes, these are also available new from CB Performance, among other places
(with bearings, spacers etc) - bearings and spacers are universal
65-66 only bearing covers AND spacers? - Yes, the bearing doesn't go as far into the early end casting. the '65-'66 only bearing cover addresses this. Reuse your Type 3 spacers
Then I use the beetle axles - Yes
inside the type 3 axle tubes - You can do it this way if your Type 3 tubes are good (mine weren't.
With the type 1 end castings - Yes
using the bearings and bearing covers from 65-66 type 1, as well as type 1 axle spacers (which set of spacers: the 61-6?, or the 65-66only?) - As stated above, the bearing covers are '65-'66 specific only. The rest of the parts (bearings, spacers) are universal
type 3 backing plates - Yes
hubs (machined 0.625" ???) - At least. I would consider going as far as .6875"
and the type 3 drums - Along with shoes, hardware, wheel cylinders,etc. _________________ aka Jimal
Posted: Sun Jan 30, 2011 3:46 pm Post subject: |
Jim, you are a true pal!
I thank you, and the other contributors to this thread. You folks, this site, this vdubbin' - its a life saver!
Also, I was sad to see that you have sold the fasty! but I see, although watercooled, you still have some dubs in the fleet! (me too! -I have a 98 jetta... that I am hoping will magically morphe into a 81 rabbit 2dr )
It is because of helpful, good natured vw folks like yourself that make this scene great! -CHEERS! |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Thu Apr 14, 2011 5:45 pm Post subject: T3 Short Axle Swap w/Trans in Car... |
Russ Wolfe wrote: |
The axle tube will come out with the trans in the car. You just have to hold your mouth right.
Also, just unbolt the mounts from the cross member and jack the transmission/engine up slightly. |
Trying to do my short axle swap with motor/trans in car...need to gain a spec of clearance on the rings that hold the axle tubes to the trans. Are the mounting bolts Russ refers to, the ones I have circled in the photo? Thanks...
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69804 Location: Phoenix Metro
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
Posted: Thu Apr 14, 2011 10:23 pm Post subject: |
its a bitch to do in the car... especially a driver that is dirty & greasy... I've done it... by unbolting the mounts and getting a jack under in place with some pressure, your giving yourself a little more room to work with the axle tube bell ends that mount to the side cover
once you pull the axles... usually the fulcrum plates are going to move around...
if it was me doing it again, I'd stop trying to save time and just pull the motor & trans
Anthony / ISP WEST _________________ facebook = http://www.facebook.com/pages/ISP-WEST-INC/212843163005?ref=nf
twitter = http://twitter.com/ISPWEST |
Posted: Thu Apr 14, 2011 10:45 pm Post subject: |
Thanks Everett & Anthony. I'm going to make one more attempt at doing it while installed...I guess I could also remove the two larger bolts that hold the crossmember to the frame horns so long as the jack was under it. If I start to feel like I'm going to pop a vessel I'll step back take a deep breath and pull everything _________________
Lind wrote: |
campingbox wrote: |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Fri Apr 15, 2011 7:25 am Post subject: |
[email protected] wrote: |
Thanks. The kid who bought my Fasty has been keeping me updated on its progress. It has been fast and impressive. He and his father have facilities I will probably never have and are knocking this thing out quicker than I ever could have. I've seen some pictures and the doors and other panels are already painted their new VW pale blue color. I'm glad the car went to a good home.
Posted: Fri Apr 15, 2011 9:02 pm Post subject: Re: T3 Short Axle Swap w/Trans in Car... |
RHD Notch wrote: |
Russ Wolfe wrote: |
I ended up removing the 2 large 27mm crossmember/frame horn bolts (the wrench is on them in the photo above). My jack was under the crossmember when I did this...I did nothing to the smaller bolts circled in yellow. Once removed, I raised the jack so that the frame horns bottomed out in the crossmember and that gave me enough clearance to 'pull' the axle tubes off the axle shafts. The photo below is the set-up I used to 'pull' the tubes from the shafts. The old axles are still attached because i need to get a larger snap-ring plier...tomorrow.
Yes, it can be done with the trans in the car...
Lind wrote: |
campingbox wrote: |
junk34 Samba Member
Joined: May 06, 2009 Posts: 52 Location: los anngeles, ca, usa
Posted: Mon Apr 25, 2011 10:42 am Post subject: |
Hey everyone! Quick question, would I run into any trouble if I ran a short axle swap, AND a 2" trans raise?
Thanks |
IAMIROY Samba Member
Joined: September 27, 2011 Posts: 294 Location: Palmdale, CA
Posted: Tue Oct 04, 2011 6:10 pm Post subject: |
Quick question. To convert a '63 wide five to 4 lug with shortened axles, I would do all the above but change the backing plates, drums, and all other brakes parts? |
vic Samba Member
Joined: August 31, 2005 Posts: 1669 Location: Fontana, Califas
Posted: Fri Feb 10, 2012 11:08 am Post subject: |
Does anyone have the part number for the 65-66 bearing caps? I'm in the middle of this conversion and I want to get the right ones.. _________________ The Original German Folks! |
HenrikL Samba Member
Posted: Fri Feb 10, 2012 2:05 pm Post subject: |
vic wrote: |
Does anyone have the part number for the 65-66 bearing caps? I'm in the middle of this conversion and I want to get the right ones.. |
311 501 311 |
vic Samba Member
Posted: Fri Feb 10, 2012 8:05 pm Post subject: |
Sweet, thanks, look like I have everything I need for this job, busy day tomorrow! _________________ The Original German Folks! |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3686 Location: San Jose, CA
vic Samba Member
Posted: Fri Feb 10, 2012 10:56 pm Post subject: |
No I found some good used ones at car craft in riverside, does anyone know if I have to change the hockey stick also? _________________ The Original German Folks! |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Sat Feb 11, 2012 12:42 am Post subject: |
vic wrote: |
No I found some good used ones at car craft in riverside, does anyone know if I have to change the hockey stick also? |
If you are using the bug transaxle then yes you will need to use your type 3 nose cone and hockey stick. But if you are only changing the axles then you will need all the pieces to the bug axles. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Mon Apr 02, 2012 1:39 pm Post subject: |
Great thread
I was just going to go for it anyway but, a little research does no harm , thanks fellas. _________________ I never learned that much at school, but i've taught ladies plenty!! |
