dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Tue Nov 04, 2008 4:46 pm Post subject: BA6 gas heaters |
I just finished rebuilding the entire heating system on my 76 bay. Heat exchangers, tubes, fans,valves and the BA6 gas heater. On heat exchangers I am getting approx 120 deg F coming out of the defrost vents. When I turn on the gas heater on LOW, I am getting 265 deg F out of the defroster. I think this is a little high. Ambient temp is -2 deg F.
What is the value I should be getting on LO and HIGH? I want to know the value before the overheat sensor shorts out the fuel pump fuse. I will be diagnosing the regulator circuit in the next few days. My manuals only list the output in BTU's
Thanks _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
fukengruvenoval Samba Member
Joined: December 07, 2004 Posts: 774 Location: OSHAWA, ONTARIO, CANADA
Posted: Tue Nov 04, 2008 6:29 pm Post subject: Re: BA6 gas heaters |
dan macmillan wrote: |
Ambient temp is -2 deg F. |
Dan, I'll let the others chime in on the heater, but I think you mean ambient is 2 degrees C. Even in Sudbury I doubt it's -19C, which is what -2F converts to...
Only mentioned it because it's a huge difference in ambient. _________________ Check out my video series at www.youtube.com/midnightoilgarage |
Posted: Tue Nov 04, 2008 8:31 pm Post subject: Re: BA6 gas heaters |
fukengruvenoval wrote: |
Only mentioned it because it's a huge difference in ambient. |
Thanks, you are correct. I meant to say -2 deg C/30 deg F. _________________ Licensed Automotive Service Technician
Current projects:
Posted: Sun Nov 09, 2008 1:04 pm Post subject: |
It amazes me that out of 131 viewers, no one is able to answer this question. _________________ Licensed Automotive Service Technician
Current projects:
theizzardking Samba Member
Posted: Mon Nov 17, 2008 12:00 pm Post subject: |
seems to me like you should be happy with that, what's too hot for you heater, really? i know in my neck of the woods there is no such thing as my heater is putting out too much heat. just my opinion and maybe why you haven't gotten a response on this, i was just searching around to find if i could install a gas heater from a '76 into my '71 with out much complication and came across this. sorry if i come across like a jerk, but your heater sounds like it's working great to me! _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Mon Nov 17, 2008 12:22 pm Post subject: |
problem is everyone is too jealous to reply. "what a jerk, all 'oh my buss is too hot, what ever shall I do', grumble grumble."
no, I have nothing constructive to add _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Mon Nov 17, 2008 12:51 pm Post subject: |
I have a BA6 manual but it's buried in a storage unit somewhere.
I looked at the manual for the very similar BA4 and the overheat switch on that system works at 375*-400*F.
I don't think 265 is too high. Once the ducts warm up the air inside won't drop in temp between the heater and the defroster outlets. I don't know of any specific temps for the low and high settings for the BA6. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Posted: Mon Nov 17, 2008 2:04 pm Post subject: |
can some one comment on the use of a 76' gas heater in a '71
i too want my heat to be too hot! _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Posted: Mon Nov 17, 2008 2:46 pm Post subject: |
josh wrote: |
I don't think 265 is too high. Once the ducts warm up the air inside won't drop in temp between the heater and the defroster outlets. I don't know of any specific temps for the low and high settings for the BA6. |
Thanks for the info. I realize many are having the opposite problem. In my case this info is important to know. Too high at the def vent and it melts plastic. Too high at the heater and the system is designed to short out the overheat switch, which is not resettable. New one will be needed and they are getting scarce. If by chance the switch were to fall out of it's mounting and did not short I could end up with a fire. Not a scenario I want to experience. _________________ Licensed Automotive Service Technician
Current projects:
Posted: Mon Nov 17, 2008 3:41 pm Post subject: |
josh wrote: |
Thanks for the info. I realize many are having the opposite problem. In my case this info is important to know. Too high at the def vent and it melts plastic. Too high at the heater and the system is designed to short out the overheat switch, which is not resettable. New one will be needed and they are getting scarce. If by chance the switch were to fall out of it's mounting and did not short I could end up with a fire. Not a scenario I want to experience. |
wow i'd just cut the switch out of the circuit in that case and install an air temp gauge in it's place then you could see what the temp is for real when the heat is on and adjust accordingly. you can do that right? there's no computer that runs this thing is all just hard wired relays and such right? _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Mon Nov 17, 2008 4:37 pm Post subject: |
The BA6 info is in the yellow manual.
There is an online version here:
http://www.vintagebus.com/techinfo/eber/index.html
I checked my yellow manual and it doesn't give any temps. It shows how to test it and replace it, but no temperatures. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
hiwaycallin Samba Member
Joined: May 07, 2008 Posts: 356 Location: Salmon Arm, BC
Posted: Mon Nov 17, 2008 4:48 pm Post subject: |
theizzardking wrote: |
i too want my heat to be too hot! |
I think you should go with your original idea of in-floor heat. |
Posted: Mon Nov 17, 2008 6:07 pm Post subject: |
hiwaycallin wrote: |
quit making me laugh haha! _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
busdaddy Samba Member
Posted: Mon Nov 17, 2008 7:36 pm Post subject: |
Dan, from the looks of that manual unless you have a stash of NOS temp sensors the only way to reduce the cutout is tweeking tabs in the relay like adjusting a voltage regulator. Would it be easier to just install a thermostat like the BN-4's use in the output duct and regulate the pump? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Nov 17, 2008 7:59 pm Post subject: |
busdaddy wrote: |
Dan, from the looks of that manual unless you have a stash of NOS temp sensors the only way to reduce the cutout is tweeking tabs in the relay like adjusting a voltage regulator. Would it be easier to just install a thermostat like the BN-4's use in the output duct and regulate the pump? |
I have a few good temp sensors and the dash mounted control switches. What I do not have is a supply of overheat sensors. I am looking to find out if anyone knows the low cut in temp and the max high cut out temp. I want it to work as it did new without having the old style pump cut out. The dash switch contains electronics that turn off the pump at the set temp then restart it before the flame switch cools too much to switch the blowers off. _________________ Licensed Automotive Service Technician
Current projects:
64Bug Samba Member
Joined: May 01, 2008 Posts: 120 Location: Ontario, Canada
Posted: Tue Nov 18, 2008 6:49 am Post subject: |
Dan Macmillan wrote:
Quote: |
I have a few good temp sensors and the dash mounted control switches. What I do not have is a supply of overheat sensors. I am looking to find out if anyone knows the low cut in temp and the max high cut out temp. I want it to work as it did new without having the old style pump cut out. The dash switch contains electronics that turn off the pump at the set temp then restart it before the flame switch cools too much to switch the blowers off. |
You mentioned you were looking for low and high temp. Although its not temperature specific, I found this testing procedure in the BA6-BN4 manual from www.vintagebus.com
If you already have this info, my apologies, otherwise, I hope this works for you. _________________ When you turn it on, does it return the favor?
1974 Westfalia
1964 Beetle (stock)
2017 Santa Fe |
Posted: Tue Nov 18, 2008 7:07 am Post subject: |
64Bug wrote: |
If you already have this info, my apologies, otherwise, I hope this works for you. |
Thanks. I do have all of the information ever published in all of the manuals. The spec is not there. That is why I am asking people in the real world that have a properly working system what their temp values are. It seems so far that no one has a properly working system. _________________ Licensed Automotive Service Technician
Current projects:
superalf72 Samba Member
Posted: Mon Nov 24, 2008 10:50 am Post subject: |
hello to all
first of all, sorry for my english, i'm writing form italy and my english is 'scholastic'
i have a westy 1975 with a BA6 and i i have one problem with it :
when it's start, i hear the heater working (like fire in the heater) and hot air comes out from the exhaust pipe but... inside of the bus no hot air
i just checked pump fuel, spark and sensor temperature and all works good (fuel pump makes tick-tick-tick... )
mine BAS runs when i push down the middle thing (dunno the right word in english) on the das (that with red plastic cap) end when i obviously turn the green switch (that that has the timer too)
what have i to check ??? why hot air comes out from exhaust pie and not inside the bus (obviously i wanna hot clean air inside... lol)
thank in advance for qyour answers |
Posted: Mon Nov 24, 2008 11:37 am Post subject: |
It sounds like your blower fan is not working, it's located at the right rear of the heater and connects to a duct from under the rear seat. Connect a test light or meter to the wires supplying the motor and see if it gets power when the heater is running. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Nov 25, 2008 1:48 am Post subject: |
ok, i'll check that thing
thank you
ALF |
