DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Thu Nov 06, 2008 9:56 am Post subject: Best distributor for a 30/31 carb on a 1600dp |
The short version of a long story is I picked up an early bug with a fresh 1600dp that is based on a "D" case (40hp?!) It runs well etc so I'm not terribly concerned anout the early case and I can always fix it if it breaks.
It has a 30 / 31 carb on an adapter to fit the dual port manifold and has an 009 with a pertronix module. I'm after best MPG / drivability and am thinking I'll be better off with a stock distributor. What's the best distributor for the 30 / 31 carb? _________________ Midwest Autosavers, Inc. Woodstock, IL |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Thu Nov 06, 2008 10:15 am Post subject: |
The H30/31 was never stock, so there is no "stock" distributor.
You can use a 205M or 205T which are vacuum only. A 019 which is mechanical ir Aircooled.net sells a vacuum/mechanical that works with that carb. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Nov 06, 2008 12:21 pm Post subject: |
Glen,
205M , 205T am I thinking 1965 - 1970-ish distributors?
It actually runs OK with the 009 but I'd like to tweak for optimum MPG. _________________ Midwest Autosavers, Inc. Woodstock, IL |
DMC-12 Samba Member
Joined: September 19, 2006 Posts: 817 Location: Maryland
Posted: Thu Nov 06, 2008 12:43 pm Post subject: |
DrDarby-
I also recently purchased a vehicle with an H30/31. It came with the stock DVDA but I found a 205T in my stash of parts so I'm going to try it out and see what happens. _________________ "Unpimp ze auto"
1974 Orange Thing Daily driver/Rolling resto.
1981 DeLorean DMC-12 |
Glenn Mr. 010
Posted: Thu Nov 06, 2008 1:24 pm Post subject: |
I ran a 1600DP with a Solex H30/31PICT for 4 months while I was between engines and swapped out the OO9 for a 034 and a 019 and found the 019 ran best. _________________ Glenn
Member #1009
#BlueSquare |
gt1953 Samba Member
Posted: Thu Nov 06, 2008 4:43 pm Post subject: |
The 205T will work fine for that application. Has anice advance to it as well. The 091 is straight out mechanical which is fine also. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Thu Nov 06, 2008 4:45 pm Post subject: |
Hiya Darby,
Not a stock suggestion here, but...............
John out at aircooled.net is selling an SVDA that is responsive to the vacuum signal from a 30/31. He claims (and I'm a believer - I run his SVDAs although not with a 30/31) that the engine will run cooler and get better mileage.
In any event, you might want to check it out at....
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=IGD0001&cartid= _________________ Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Thu Nov 06, 2008 5:00 pm Post subject: |
I have run both a 205M and an 010, with my H30/31 and both ran excellent. _________________ oo9less since 2007
-72 Ghia- |
muffler bearing Samba Member
Joined: August 28, 2007 Posts: 355 Location: Atlanta,GA
Posted: Thu Nov 06, 2008 5:15 pm Post subject: |
I had a 34-3 and the 009 did not work well with it at all I went to the 30-31 with the adapter and have had no problems at all.....1 year _________________ " A poor ride is better than a proud walk"
56 Beetle
72 Westfalia (Driving project)
75 Riviera
Yes, I do have a Bentley. |
