Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Thu Nov 06, 2008 6:41 pm Post subject: can someone confirm a paint code? |
if i did this right, it seems that tha metal part of a dash for a 71 bay is code L43 gray black. does that sound about right? will be pulling dash at some point soon and just wanted to confirm paint code ~thanks~ |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu Nov 06, 2008 6:50 pm Post subject: |
Only thing listed in parts book concerning the front area:
Steering column tube, gearshift and hand brake lever: L 41 black
Seat frame: LD 43 grey black |
Posted: Thu Nov 06, 2008 9:46 pm Post subject: |
Karl wrote: |
hummmm it would appear that the top of the dash kind of has a well, 'grey/black' ish tint to it, not a straight black. back to the drawing board |
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Thu Nov 06, 2008 9:56 pm Post subject: |
Hiya skills,
I mistakenly painted my steering column tube L43 Gray/Black. Ooops! It is definitely the wrong color in the dash area. As a result I'd go with L41 Black. _________________ Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com |
Posted: Fri Nov 07, 2008 11:24 pm Post subject: |
Bookwus wrote: |
Hiya skills,
I mistakenly painted my steering column tube L43 Gray/Black. Ooops! It is definitely the wrong color in the dash area. As a result I'd go with L41 Black. |
can you refresh my memory, where on a bus (or bug) would i find the grey/ black L43? is the L41 more of a correct color for the top of the dash? |
bay window bandit Samba Member
Posted: Thu Dec 18, 2014 4:33 am Post subject: |
I've been checking this out as I'm about to spray my dash, and it appears the dash is LD 43 grey black, as it is a different colour to the steering column and gear lever, which are black, not grey black. My problem now is that no one seems to stock, or know of this colour here in Australia. |
wcfvw69 Samba Purist
Posted: Thu Dec 18, 2014 6:08 am Post subject: |
bay window bandit wrote: |
Do you have any parts that are still LD43 that you could take to an automotive paint house? Wolfsburg West sells spray cans of LD43. What I did was use the spray can to spray out the color on a piece of paper. I then took the paper to an automotive paint store. They had lots of color chips and we found a spot on match. They mixed it up and it was a perfect match.
They were NOT able to mix it by that paint code though. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Dec 18, 2014 6:14 am Post subject: |
I don't have anything painted still, as it all went to the sand blasters! Hopefully I might be able to get a hold of some from W/West and do what you did to match the colour, thats if I can get it shipped here. Thanks for the tip. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Dec 18, 2014 7:44 am Post subject: |
Well, if the paint is available in a spray can from WW, why not just use that?
Is this the stuff? They call it L43, not LD43.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=PAINTL43 _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Dec 18, 2014 9:35 am Post subject: |
It's a very soft paint which is typical of spray paint. When you get it mixed, the hardner and reducer makes it much harder and durable. I used a mid range quality Sherman Williams paint. It was SSOO much nicer and harder when I sprayed my interior parts. It lays out beatifully. _________________ Contact me at [email protected]
Posted: Sun Dec 21, 2014 7:02 am Post subject: |
Just got back from my painter, and he has just updated his whole paint system, and now VW L43 grey black comes up on his system, and it's the right colour, just might have to add a tiny amount of matting agent so it's not too glossy. Otherwise, I'm very happy. |
eche_bus Samba Member
Posted: Sun Dec 21, 2014 12:50 pm Post subject: |
Could you please share the paint manufacturer's name and their code for this L43 paint? You should see this info on the can. |
babysnakes Samba Member
Posted: Sun Dec 21, 2014 2:08 pm Post subject: |
eche_bus wrote: |
X2 |
Tcash Samba Member
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Dec 23, 2014 11:25 pm Post subject: |
I had my dash sandblasted and powder coated in "black watered silk" finish and it came up almost identical to original. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Tcash Samba Member
Posted: Wed Dec 24, 2014 9:20 am Post subject: Re: Instrument Panel Cover Plate/ Dash Panel |
The only thing that I could find for L43 was this.
Porsche, Gray Black, 7A1, PPG 925446
Without having them next to each other. This looks like a good match to my 70 dash, but not as glossy. There does appear to be gloss, in my dash.
Grey Black Car
When the paint code is discovered. It should be listed here as well.
Paint mixing FAQ |
Hoody Samba Member
Posted: Thu Dec 25, 2014 12:42 am Post subject: |
I hate to say it gentlemen but you are pissing in the wind when it comes to matching paint codes with current paint distributors. I have been through this multiple times. The computer cameras are dog shit. Don't waste your time....buy a spray bomb from WW spray it on piece of metal and make the guys selling you the paint get it right. Some people are willing to spend serious money on people like US who love our Cult Vehicles. WW is one of them. |
Tcash Samba Member
Posted: Thu Dec 25, 2014 8:32 am Post subject: |
Hoody wrote: |
Hi Hoody
Has this been your experience with the OE. supplier as well, in this case Glasurit?
Thank You
Tcash |
Posted: Thu Dec 25, 2014 4:31 pm Post subject: |
Hoody wrote: |
I hate to say it gentlemen but you are pissing in the wind when it comes to matching paint codes with current paint distributors. I have been through this multiple times. The computer cameras are dog shit. Don't waste your time. |
I find that untrue. sikkens has a killer computer system, plus a color map that will blow your mind.
the other issues most people have is just being some walk in customer. most people don't want to waste the time to do this work and have a customer say 115.00 for a pint of paint?!?!
so, my best advice to joe public would be:
- go into the paint store. treat help with respect
- explain you know they are doing you a favor, and let them know you expect to pay through the ass for the paint (shit's expensive)
-do as much of your own legwork as possible. don't let the counter guy think you're wasting his time.
I have never had an issue with color scanning paint _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
