redcanoe Samba Member
Posted: Sat Nov 08, 2008 9:31 am Post subject: Cvs and motor mounts |
While I realize the answers to these querries may be subjective.......
How long could I expect motor mounts and CV joints to last?
CV joints (complete rear drive axles) were installed 40k kms ago. Appears something in the R side is going. Knocking noise on right hand corners.
Have been told the motor mounts are weak. I get a bang/clunk when I initially turn the motor over. Something hitting either the engine carrier or the HD trailer hitch. Made that noise when I bought it.
2.4 was installed at 265k kms and upgraded to 2.5 at 270k. Van now has
327k. PO had all this done, I've had it 6 months. |
Dogpilot Samba Member
Posted: Sat Nov 08, 2008 9:59 am Post subject: |
I wouldn't say the motor mounts are weak. You now have a bunch more torque on your new motor, a bit more strain, not huge. The mounts are really cheap and it is not a big deal to replace them. The CV's can go, depends if they where replaced or are original. Get the Lobro ones, the ones from China are not worth the labor putting them on. Put new boots on while your in there.
http://www.van-cafe.com/home/van/page_632_339/cv_joint___fits_all_rear_and_syncro_inner.html _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Vanagon Nut Samba Member
Posted: Sat Nov 08, 2008 10:07 am Post subject: |
Likely not the issue, but are you sure the exhaust isn't hitting the body?
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat Nov 08, 2008 1:54 pm Post subject: Cvs and motor mounts |
Weak was the word the the service desk at my indepedent shop used to describe the current motor mounts. Have an estimate and you are right it isn't expensive.
I'll take a closer look at the potential contact points for this start up noise. I remember what the PO said and the shop used those contact points as possibles. Hmm, hitting the body? |
Posted: Sat Nov 08, 2008 3:12 pm Post subject: |
It is about an hour job with a floor jack being the complex tool in the mix. The mounts them selves are under $10 each:
http://www.van-cafe.com/home/van/smartlist_702/engine_mounts.html _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
