iradi Samba Member
Joined: August 24, 2007 Posts: 211 Location: Miami, Fla
Posted: Thu Nov 13, 2008 8:51 am Post subject: Lights and night vision |
I use my car daily, she has the original lights and are well aligned. But lately I have had to travel at lot at night and the streets on this zone do not count on good illumination.
I have always received good advice from this forum and desire to know if the same units sealed for coupe 74 but with better illumination exist ( halogen ) or if I place fog lights to her .
In case of fog lights, if one of you have photos of your cars and references, better to keep the nice line of the car.
Thanks
kingkarmann Samba Member
nikita Samba Member
Joined: September 16, 2007 Posts: 531 Location: California
Posted: Thu Nov 13, 2008 11:00 am Post subject: |
Good quality H4 units are a lot better than adding fogs. The light distribution pattern is far superior, especially on low beam. |
johnnyrotten I Cure Seizures!!!
Joined: January 06, 2004 Posts: 1209 Location: Behind the security gate
Posted: Thu Nov 13, 2008 11:31 am Post subject: |
nikita wrote: |
but fog lights look cool looks before safety, right _________________ Enemies are friends in reverse..... G. Busey
In the garage....
64 Ghia
66 beetle
56 Oval rag
58 ex-art project Beetle
A fleet of parts buses and ghias |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu Nov 13, 2008 1:02 pm Post subject: |
I would make sure your lights work properly and you are getting full illumination. I live in a rural area where there is virtually no lighting. I find the standard headlights work fine. _________________ Ghia Owner Emeritus |
werka Samba Member
Joined: August 25, 2006 Posts: 1110 Location: Huntsville, AL
Posted: Thu Nov 13, 2008 1:13 pm Post subject: |
You may need to play with where your lights are currently aligned to. You can pull your car facing the house, and turn your lights on. If your headlighs are pointing crazy directions, then you will be better off, pulling it, and adjusting it, then trying this again. |
blarneyman Samba Member
Joined: February 06, 2005 Posts: 1622 Location: Everson/Bellingham, WA
Posted: Thu Nov 13, 2008 2:35 pm Post subject: |
How old are the lights that are in the car? I replaced both headlights on my bug when I repainted it. It was literally like a night and day difference. _________________ 69 Beetle
70 Ghia(resto) |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Thu Nov 13, 2008 2:45 pm Post subject: Re: Lights and night vision |
iradi wrote: |
But lately I have had to travel at lot at night and the streets on this zone do not count on good illumination. |
I can relate to that; I often drive at night where deer prance around in the unlighted roads, so to help light my way I replaced the stock sealed beam units on my '71 Ghia with some Cibie units with Osram 60/55 watt H4 bulbs, and now driving at night I'm as happy as a clam. Look before you leap in regard to local laws, etc., but if you need more candlepower you can get H4 bulbs with higher wattage ratings. If you go that route I'd caution you to consider beefing up the wiring of your headlight circuit beforehand.
Charley
iradi Samba Member
Posted: Thu Nov 13, 2008 8:57 pm Post subject: |
Thanks to all.
Rgds |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Nov 13, 2008 9:52 pm Post subject: |
Hella H4 E-code halogens are great. Make sure your wire connections are clean, tight. I also added some Bosch fogs, and the combo is great when aimed right. My night vision is not great, and this makes up for it without sending glare into other's eyes. The wide fog beams help on town when turning, and really are great when it rains and road detail is lost. Use relay(s) on the fogs. Make sure your grounds are all good. |
DerekR Samba Member
Joined: July 22, 2004 Posts: 384 Location: Riverton, Utah
Posted: Thu Nov 13, 2008 11:03 pm Post subject: |
I love my H4's! I would never go back to sealed beams.
_________________ 63 Ruby Red Double Cab
60 SO 23 Westfalia SWR/BG Camper
59 Dove Blue Standard Kombi |
furbo Samba Member
Joined: November 28, 2003 Posts: 147 Location: Harker Heights, TX
Posted: Fri Nov 14, 2008 6:47 am Post subject: |
I replaced the stockers with Hella units. Very sweet, one of the best Mods I made. _________________ 79 Westy
70 Ghia Vert
95 Mex Beetle
Eccl 9:10 |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Nov 14, 2008 6:54 am Post subject: |
Bosch H4s on mine. Osram 55/60 bulbs. There is no need to upgrade wiring for this setup unless you want a higher wattage bulb. |
iradi Samba Member
Posted: Fri Nov 14, 2008 7:46 am Post subject: |
Is this the correct reference for the Hella H4 ?
What is the Bosch reference ?
Posted: Fri Nov 14, 2008 8:24 am Post subject: |
KTPhil wrote:
Quote: |
The wide fog beams help on town when turning |
Why would you need fog lights in town? Is it an area without street lighting and little traffic? _________________ Ghia Owner Emeritus |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Fri Nov 14, 2008 8:31 am Post subject: |
I have been running H4 halogens on my Ghia since mid 80s, then switched to H4 Sylvania SilverStars bulbs a few years ago. The SilverStars made a quite a difference, especially driving thru the twisties at night. _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Posted: Fri Nov 14, 2008 9:33 am Post subject: |
iradi wrote: |
Looks to me to be the same H4 lamp. Just different manufacturers. I would imagine that the fluting on the lenses and perhaps the profile might be a bit different but both would fit a Ghia. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
