Aluminum two piece cases
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Fri Nov 14, 2008 12:14 am    Post subject: Aluminum two piece cases Reply with quote
Hello-
I'm aware that the very early 25HP two piece cases were made out of aluminum. I'm also aware that they're stronger, heavier, and much more expensive than magnesium cases. I realize that the 36HP case isn't particularly strong. Is an aluminum case that much stronger than a mag' case?
Thanks,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Bengt H
Bengt H is offline
PostPosted: Sun Nov 16, 2008 10:06 am    Post subject: Reply with quote
I have also heared that the alu case is stronger but are there any prof ??
The early case have not so many strengthening fins as 36 case. Here is pics of the case halves so you can compare.
Bengt H
Bengt H is offline
PostPosted: Thu Nov 20, 2008 12:26 pm    Post subject: Reply with quote
No one has anything to say about this??
Is it just rumours that the aluminium is stronger???
bvilletom
bvilletom is offline
PostPosted: Sat Nov 22, 2008 10:24 am    Post subject: Case strength Reply with quote
Thank you for posting the inside pictures of the 36 alum. case. I have never seen the inside of an aluminum case before, they are very, very rare here. After studing the pictures carefully, I really don't think they are any stronger than the latest 36 HP case, the 57-60 style. Notice the very tall and long breather opening into the generator stand, it would be a oil throwing monster at high RPM. I think the gussets and heavy webbing around #1 main and thicker area metal at all through bolts + the smaller breather hole make this the best case for the money. I question the unattached top center main web to the top of the later cases. Your alum one is attached ??
I posted the question about 36HP case strength May 24,2006 in the 36 drag race thread page 6 and got no response so I came to my own conclusion.
I'm pounding these 36HP moters as hard as anybody and the cases have been OK so far
Bvilletom
bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
Art Thraen
Art Thraen is offline
PostPosted: Sun Nov 23, 2008 7:58 am    Post subject: Alum Vs Mag Reply with quote
Well, I think that if the case was casted the same the alum would be stronger, But I do know that, the new Alum Cases that are built for the 1600 based engine are prone to Crack at the bell housing area at the top.
In the Off Road race cars you have to weld a gussit to prevent this, and the Mag cases do not have the problem.
Mag is a little forgiving ( mallable ) Maybe it has a little forgiveness?
36hplandspeedracer
36hplandspeedracer is offline
PostPosted: Mon Nov 24, 2008 8:02 am    Post subject: Reply with quote
Art
I am surprised to find out the late style aftermarket aluminum cases crack at the bell housing. That was a huge problem with the factory magnesium cases also "back in the day" when they motor was built for power and we also would have a supporting gusset welded between the bosses to reduce that possibility.
The problem appeared to go away or at least minimize when the concept of deep studing the number 3 cylinder was introduced. Could either of these same procedures be applied to an aluminum 36hp case?
Burly
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is online now
PostPosted: Sun Dec 07, 2008 12:54 pm    Post subject: Aluminum vs. Magnesium Reply with quote
Most, if not all Porsche Pre-A 2pc. engines before mid 1951 were aluminum. Reason: Aluminum is more dense/stronger and make for a better building foundation for a engine that is going to put in "heavy duty" service. Why do you think Porsche started using ALUMINUM blocks AFTER they went to their own 3pc. design post Oct. 1954? Granted, aluminum is more heavier but the "pros" of service/performance outweighed the gains of lightness and cost.
I have been collecting these 2pc. aluminum blocks now and have accumilated about 30 blocks now ONLY for the reason of using them as my foundation for my DENZEL engines.
Cheers! Mr. Okrasa Wink
Eaallred
Eaallred is offline
PostPosted: Sun Dec 07, 2008 1:07 pm    Post subject: Re: Alum Vs Mag Reply with quote
This may also be due (or likely a combination of) to the added weight of the case adding to the total weight of the engine bouncing around at the back of the car without any additional support (like a +68 bus has).
The extra weight/force of the aluminum case being thrown around with the addition of the aluminum not 'giving' a bit like the aluminum is probably just enough to bring on the stress relief (cracking) from the off road racing.
For a street car that is not being 'jumped', I would assume aluminum being much stonger if they are cast the same (as Art says), but I don't know early engine cases and do not know if there are any differences other than material used. You could make a steel case weaker than a mag case if the mag was thick enough, and the steel was thin enough. Case design probably has as much to do with it as anything. Wink
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Jimmy111
Jimmy111 is offline
PostPosted: Wed Dec 10, 2008 7:07 pm    Post subject: Reply with quote
Aluminum as a material is stronger than Magnesium. Especially the alloys in use at that time. Magnesium is more ductile to a point but the aluminum case weighs twice as much so puts twice as much stress on the mounting flange. Aluminum is not twice as strong. it is about 33% stronger
But the reason for the use of the Aluminum was they only expected to make less than 500 of them. In 1950 they only made 300 of them so it was not worth the expense to do the R&D work to refine the injection mold necessary at that time to produce the Magnesium case.
henry roberts
henry roberts is offline
PostPosted: Thu Dec 11, 2008 1:44 am    Post subject: Reply with quote
ok i think i must have missed something.
is this topic about vw cases or really early 356 cases?
thanks.
henry the uneducated.
edit.
btw jimmy, if you get bored with your current case project do you want to make us externaly stock looking case that will take 356 or late t1 lifters, has bigger oil galleries, more ribbing etc etc? some affordable dp heads would be lovely as well, just if you're looking for something to fill in all that spare time you must have. Smile
john morris
john morris is offline
PostPosted: Sat Dec 27, 2008 1:52 pm    Post subject: aluminum two piece cases Reply with quote
Is the aluminum case VW or Porsche? Are there numbers etc. that can be used to identify one? Thanks!
Bengt H
Bengt H is offline
PostPosted: Mon Dec 29, 2008 1:25 am    Post subject: Reply with quote
Its earlyer 25 cases this is about.
Dont know the exact engine number but after 19 jan -51 the crankcase was made of elektron, number could bee something around 270 000?, its clearly when you see it they are more chiny than later cases.
Unkl Ian
Unkl Ian is offline
PostPosted: Sat Sep 05, 2009 7:29 pm    Post subject: Reply with quote
If someone wanted an Aluminum case, what serial numbers would they have to look for ? Question
grueni
grueni is offline
PostPosted: Sun Sep 06, 2009 1:50 am    Post subject: Reply with quote
would this be a aluminium case? the engine should be from a 1950 brezel bug.
2-066 488
OOC
OOC is offline
PostPosted: Sun Sep 06, 2009 8:09 am    Post subject: Reply with quote
The ones without numbers are the best Smile
here are a few pictures of one of our modified 25hp cases
OOC
billmetric
billmetric is offline
PostPosted: Sat Sep 26, 2009 11:09 am    Post subject: Reply with quote
the problem with magnesium cases is that the flywheel main bearing saddle always gets pounded out requiring a line bore & oversize bearings, the aluminum is much more resistant to the crank bore getting pounded out from what I have seen of late type 4/914/bus motors they rarely require a line bore upon rebuild ( usually just burnt valve seats falling out ) I'm guessing the resistance to bearing saddle wear was why Empi used an ancient aluminum 25hp case for the original inch pincher?
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
Unkl Ian
Unkl Ian is offline
PostPosted: Sat Sep 26, 2009 3:16 pm    Post subject: Reply with quote
Aluminum is stronger than Magnesium,
also easier to weld.
I suspect the factory chose Magnesium to save weight,
and added a few internal ribs to improve stiffness.
hollandbug
hollandbug is offline
PostPosted: Wed Sep 13, 2017 1:19 am    Post subject: Re: Aluminum two piece cases Reply with quote
Made in 18 1 1951
hollandbug
PostPosted: Wed Sep 13, 2017 1:20 am    Post subject: Re: Aluminum two piece cases Reply with quote
Aluminium case or not?
Original Old Speed
PostPosted: Wed Sep 13, 2017 11:43 am    Post subject: Re: Aluminum two piece cases Reply with quote
magnesium
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
