Aluminum two piece cases
Page: Previous  1, 2
hollandbug
hollandbug is offline
PostPosted: Wed Sep 13, 2017 3:28 pm    Post subject: Re: Aluminum two piece cases Reply with quote
How do you see that?
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Wed Sep 13, 2017 10:33 pm    Post subject: Re: Aluminum two piece cases Reply with quote
I've been building these engines for over 40+ years. I know what I know.... There are a couple of clues that let me know that this is a magnesium block without seeing it in person. The date cast tells me that this block was cast on the 3rd week of Jan. 1951. Right about the time when VW switched to magnesium from aluminum. Granted: I have seen magnesium blocks BEFORE Jan. 1951 also but the wasn't the norm based on what I've typically seen. Besides, you can see the oxidation starting to form on the gen. stand and traces of the chem. treatment still visible.... ah-ite Wink
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
mark tucker
mark tucker is offline
PostPosted: Thu Sep 14, 2017 1:45 pm    Post subject: Re: Aluminum two piece cases Reply with quote
the reason for the switch was the mag is much eazer to cast and much eazer to machine. eazy=$$$ eazy also=time ..witch =$
most people dont know theoil gallys in most engines are machined(drilled) the mag cases are cast in the case, thus there all tapered from the core rod's that are pulled out. thus many machining opps are deleated. mag also dosent require as much or high grade of cutting fluid. and to farther the bennifit of the mag cases, after work at the bon fire they have fireworks!!!
hollandbug
PostPosted: Fri Sep 15, 2017 7:02 am    Post subject: Re: Aluminum two piece cases Reply with quote
Thanks . 👍
Page: Previous  1, 2
Page 2 of 2
