frodin1 Samba Member
Posted: Sun Nov 16, 2008 8:45 pm Post subject: Crank assembly question? |
First off I'm kind of a newB here. I decided to try and tackle a lower end assembly. I'll save all the extra BS and get to the meat of my issue. I've put the main bearing on the crank, heated the "NEW" straight cut gear and put it on, spacer goes next, then the dist. drive gear and circlip. This is correct isn't it? I don't appear to have enough room for the circlip? it's about half the thickness off. Do these timing gears have different ticknesses to them? I aquired all this stuff from someone with a vehicle. Some is new and other stuff old. The only thing new on this end is the timing gear? Can someone clue me in a little before I take this to the lake? Thanks for taking you time to help me out! |
manxracer1 Samba Member
Joined: December 07, 2007 Posts: 536 Location: Escondido calif.
Posted: Sun Nov 16, 2008 8:52 pm Post subject: clip room |
Make sure the timing mark is facing toward the snout of the crank. It looks like an "0" stamped into the gear. If this is not facing up it might not slide all the way down on the crank. Don't get the gears too hot like glowing red it will make them brittle. _________________ 1960 vw Manx
My photo's & video's
http://s263.photobucket.com/albums/ii131/manxracer1/
Posted: Sun Nov 16, 2008 8:58 pm Post subject: |
Yup, got the dots facing out. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Nov 16, 2008 9:01 pm Post subject: |
Same thing happened to me when I built the 1915. Take some sandpaper to the brass gear to get the needed clearance. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun Nov 16, 2008 9:05 pm Post subject: |
Did you take a real close look at where the timing gear butts up against the step on the crank, next to the bearing, to make sure it got seated all the way up the crank? Some people keep a brass punch handy when installing the gears to tap on them once installed while still hot to make sure they've slid all the way up the crank. Do you have any way of measuring the timing gear to compair the width to a stock VW gear? I would bet the gears just didn't go on the crank all the way. |
Posted: Sun Nov 16, 2008 9:07 pm Post subject: |
Thanks, I was thinking that. I wanted to make sure there wasn't some other way of fixing this? Grinding, sanding, shims ??? I don't know? The only thing new is the timing gear, it should all fit unless it's to thick? |
Posted: Sun Nov 16, 2008 9:09 pm Post subject: |
I can't move the bearing anymore? And there's no way of measuring the old gear becasue the guy I got this from must have gotten rid of it. I do have the old bearing however and it looks the same? |
Posted: Sun Nov 16, 2008 9:10 pm Post subject: |
I figure i'm about 1/16 off? just looking at it? |
Posted: Sun Nov 16, 2008 9:44 pm Post subject: |
If you can no longer move the bearing, there's something wrong. I would take the gears off, and take a closer look. |
