crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 8856 Location: Orbiting San Diego
Posted: Tue Jul 21, 2015 12:50 pm Post subject: |
One update to my old post quoted above. The #3 fuse was flipped in the last version of the fuse/rely panel so the wire from the aux battery would plug into the top leg hole in the later panel. Best to measure the voltage on the 2 leg holes with the fuse out. One hole should be constant 12 volts from starting battery. Plug the aux battery powered wire into the other hole.
The later panel is from 90/91 vans, though either version panel could be installed in any 86-91 van.
Mark |
