Porsche Pulley
tylergeddis
tylergeddis is offline
PostPosted: Wed Nov 19, 2008 10:08 pm    Post subject: Porsche Pulley Reply with quote
I was interested in buying a Porsche Pully, but I have a few questions before a do:
1. How well would they work on a 40hp.
2. Where would you buy one original or repro?
3. Also do you have to buy a porsche crank or can you just bolt it on the stock crank.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Wed Nov 19, 2008 11:08 pm    Post subject: Reply with quote
Hello-
1) The upside is that they look cool, and they lower the amount of HP consumed by the fan. The downside is that your fan won't blow as much air over your engine, so it will run warmer.
I believe Porsche was able to use them because they're engine ran at speeds much closer to the limit of the fan.
2) You can find used ones on eBay, or you can buy repros NLA Parts.
3) They'll fit onto a VW crank, but only the early ones will have the oil grooves. Most will require that you install a sand seal.
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
oval56
oval56 is offline
PostPosted: Thu Nov 20, 2008 11:48 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Hello-
Paul
or machine a busching with oilgrooves (early pulley's are not easy to get)
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
the.fordhams
the.fordhams is offline
PostPosted: Thu Nov 27, 2008 10:10 am    Post subject: Reply with quote
It would appear there are also Porsche crank pulley's that are full width at 170mm - I have one - its a 4 hole OT - was this Okrasa VW? However, on measuring the diameter of the scroll seal it would appear to be 49.7mm - hence mine would probably leak unless I go sand seal with it. Oh well.
Now if you go for a smaller Porsche top pulley - 356's 96mm vs vw's 110mm - then you may be able to use those smaller OT Porsche crank pulleys and still turn the same speed? Maybe thats how Porsche got away with it?
I would have thought with our small width 40hp fans you'll need all the fan speed to keep a higher output / heat making engine cooled enough? On my 40hp big bore I went for an oversize bottom pulley like AC net sells with a stock 110mm top pulley.
63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender
53 0val
Samba Professor
53 0val is offline
PostPosted: Sat Nov 29, 2008 4:36 pm    Post subject: Reply with quote
Hello-
Paul
Those are "easy" compared to a Pre-A pulley. Wink
