gregb Samba Member
Posted: Sun Nov 23, 2008 2:04 pm Post subject: Spark Plug doesnt fit Head |
I bought a new set of spark plugs for 73 beetle, 3 went in just fine and the last one rolled around in the hole. Checked and the treads are fine/ not cross- threaded. Just looks like it take a larger spark plug for some reason?
I noticed with the three other holes there looks like a copper sleeve of some sort inside the hole. Not sure what to do - can I get 1 larger spark plug for the 4th hole?
A. Is the normal hole, spark plug fits fine
B. Is the larger hole ( notice no copper collar )
Any help would be greatly appreciated.
Thanks,
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Sun Nov 23, 2008 4:07 pm Post subject: |
Take a look at the plugs you removed. I think you'll find a threaded insert still attached to one of them. _________________ Midwest Autosavers, Inc. Woodstock, IL |
gregb Samba Member
Posted: Sun Nov 23, 2008 4:40 pm Post subject: |
DrDarby wrote: |
Take a look at the plugs you removed. I think you'll find a threaded insert still attached to one of them. |
Unfortunately, there were no plugs in the engine when I acquired it, but I suspect you are correct! - Am I able to get a hold of these things somewhere? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sun Nov 23, 2008 6:46 pm Post subject: |
I have a solid insert on one of mine on my 1835cc. NAPA or CarQuest or BAP have them. Loctite it in (red Loctite) use anti-seize on the spark plug threads. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gregb Samba Member
Posted: Sun Nov 23, 2008 7:24 pm Post subject: |
Cusser wrote: |
I have a solid insert on one of mine on my 1835cc. NAPA or CarQuest or BAP have them. Loctite it in (red Loctite) use anti-seize on the spark plug threads. |
Great, is there a specific name for these things? |
f4stunter Samba Member
Joined: January 19, 2008 Posts: 68 Location: Hot Springs, Arkansas
Posted: Sun Nov 23, 2008 8:28 pm Post subject: |
Time-serts is one brand. Just do a search for thread inserts in google or yahoo. or just go down to autozone or napa and tell them you need a spark plug repair kit. I would tell you the brand I bought through advanced auto but its over at my dads right now. _________________ '71 Super Beetle Autostick 1641cc |
Cusser Samba Member
Posted: Sun Nov 23, 2008 9:54 pm Post subject: |
If your cylinder head is already tapped for the insert, you don't need the whole kit, just the threaded insert. They come in different lengths so be sure to take a standard plug to the store with you. There are different metal inserts available as well; mine from BAP was stronger and has worked longer than the cheapie assortment one from discount store. carQuest's also looked good. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bongon247 Samba Member
Joined: August 18, 2008 Posts: 78 Location: Apple Valley
Posted: Mon Nov 24, 2008 4:51 pm Post subject: thread repair insert |
NAPA Part # that you need is SER2128...
comes with the loc-tite, anti-sieze a plug, thread it hand tight into the insert then torque the entire thing into the head. they work well.
love,
you friendly neighborhood napa parts guy, who is bored to tears at work |
Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1902 Location: Havre, MT
Posted: Mon Nov 24, 2008 5:37 pm Post subject: |
BTW, they are called helli coils. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
2002sportside Samba Member
Joined: January 27, 2004 Posts: 1489 Location: New England
Posted: Mon Nov 24, 2008 5:45 pm Post subject: |
Endicott jb wrote: |
BTW, they are called helli coils. |
The actual part is called a threaded insert. Heli-coil is just a brand name. _________________ 1973 Volkswagen Beetle never ending project |
Cusser Samba Member
Posted: Mon Nov 24, 2008 5:49 pm Post subject: |
Heli-coil is a brand name, for a spring-looking insert. I'm talking about a solid threaded insert. By the way, my cylinder heads were heli-coiled by the shop when they were rebuilt in 1986, so one of those unthreaded, which I then replaced with the solid threaded insert. Luckily, the solid insert used the same thread size, so I didn't have to re-tap. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
