Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Fri Nov 28, 2008 11:55 pm Post subject: 6v clutch options |
What kind of 6v pressure plate/disc combo are you guys using with these vintage speed engines? _________________ www.DenverWildlifeControl.com |
glutamodo The Android
Joined: July 13, 2004 Posts: 26302 Location: Douglas, WY
Posted: Sat Nov 29, 2008 8:38 am Post subject: |
I'm not sure how much a 1385cc 40HP counts as "vintage speed" but many of the threads where I discuss them have been moved over to this new forum.
Me, I just use a stock 6-spring pressure 180mm plate and a spring-center disk. I prefer the feel of that type of pressure plate over the modern diaphram style. |
water guy Samba Member
Joined: January 25, 2008 Posts: 463 Location: Puyallup Washington
Posted: Sat Nov 29, 2008 9:36 am Post subject: |
I'm also using a stock Sachs cluth in my 36 hp Okrasa. Seems to be just fine. But I do drive like a grandma! _________________ '55 Porsche Continental
'63 Firetruck |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1468 Location: San Carlos, CA
Posted: Sat Nov 29, 2008 11:10 am Post subject: |
Hello-
I've you're concerned that a standard 180mm pressure plate won't be enough, ACN sells a super duper 180mm pressure plate from Kennedy.
BTW, if you do install a Kennedy PP, I would recommend rebuilding your pedal assembly and adding one of the extra long clutch arms. When I installed a Kennedy PP in my oval, the already worn pedal assembly, wore out shortly after. With the longer clutch arm, you won’t have to rationalize why your left leg hurts all the time.
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Last edited by gimmesomeshelter on Sun Nov 30, 2008 3:10 pm; edited 1 time in total |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Sat Nov 29, 2008 6:33 pm Post subject: |
Or get a 6V flywheel that takes the 200mm disc and PP and be done with it.
Cool info gimmesomeshelter on ACN carrying that Kennedy 180mm PP, thanks! _________________ Looking for aluminum single port Kadron manifolds. |
justinmcallister55 Samba Member
Joined: May 11, 2008 Posts: 13 Location: Riverdale Utah
Posted: Sat Nov 29, 2008 8:51 pm Post subject: |
who is acn I can't find them anywhere on the web? |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Sun Nov 30, 2008 9:11 am Post subject: |
thanks I should have known that. |
Posted: Sun Nov 30, 2008 11:50 am Post subject: |
good info, thanks.
i'm building a big bore, dual carb, cam, headwork, etc 40hp engine. even though it isn't going to big a big performance upgrade, i was wondering if the stock 180mm clutch would work. i didn't realize john sold a hd clutch. _________________ www.DenverWildlifeControl.com |
volksworker Samba Member
Joined: October 30, 2004 Posts: 309 Location: Arizona
Posted: Sun Nov 30, 2008 10:12 pm Post subject: |
Use the 180mm Porsche 356 pressure plate. Karls Custom in Mesa has them. Not too expensive. _________________ Tom
67 Porsche 912 Bahama Yellow
68 Crew Cab Transporter
73 Thing original
57 MGA 1500 Coupe
71 K20 Suburban 3dr
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Mon Dec 01, 2008 6:03 am Post subject: |
The clutch plate on my 30hp judson motor has a pressure plate off an industial engine, as it has more springs = more pressure. Its worked fine and hooks up well. Just a thought. :D |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Mon Dec 01, 2008 8:57 pm Post subject: |
volksworker wrote: |
Use the 180mm Porsche 356 pressure plate. Karls Custom in Phoenix has them. Not too expensive. |
This is the way to go.... I have this clutch in my 55 3Fold with Judson and in my 52 Split even.... really a nice springy clutch. _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
Posted: Wed Dec 03, 2008 12:05 pm Post subject: amortex |
Actually Sachs/Amortex has an excellent pressure plate out that is diaphram style like the Porsche and costs 69.00 at Karls Custom VW in Mesa, AZ. Its a bus plate and will hold anything but the crazy stuff. The Kennedy will break your pedals, cable, clutch tube and left leg on a daily driver. The real german Porsche one is 110.00......... _________________ Tom
73 Thing original
57 MGA 1500 Coupe
71 K20 Suburban 3dr |
Shorrock Samba Member
Posted: Thu Dec 04, 2008 11:33 pm Post subject: Re: 6v clutch options |
Lee. wrote: |
What kind of 6v pressure plate/disc combo are you guys using with these vintage speed engines? |
Lee, I have a very nice 200mm 12lb 6 volt flywheel just resurfaced if interested. I use a Kennedy Stage-1 with Daikin Disc. Send me a Private Email. Howard in Arvada |
