my 36hp new pic
[email protected]
vwlownslo69@hotmail.com is offline
PostPosted: Sun Nov 30, 2008 7:05 pm    Post subject: my 36hp new pic Reply with quote
I have been messing around with my 36hp, doing mock up on dual carbs, made a cool tailpipe (for my bus) plug wire tube, manifolds, distributor clamp and some cool buggy exhaust velocity stacks... anyone have some old tin, and a pulley layin' around?
Any comments or tips or other cool, not overly hurtful comments welcome!
Don't mind the vise grips, studs are nuked! I will fix that soon, manifolds need "tweaking" anyway...
I don't know how to post the pic on here... I tried! Here's a link...
http://i456.photobucket.com/albums/qq286/vwlownslo/DSC04127.jpg
Last edited by vwlownslo[email protected] on Thu Jan 01, 2009 4:13 pm; edited 1 time in total
fredy a
fredy a is offline
PostPosted: Sun Nov 30, 2008 8:05 pm    Post subject: Reply with quote
sorry for the spelling
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Nov 30, 2008 8:07 pm    Post subject: Re: my 36hp Reply with quote
Dump the OO9 and put in a VJ4BR25 or 0 231 129 010 distributor.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
[email protected]
PostPosted: Sun Nov 30, 2008 8:46 pm    Post subject: Re: my 36hp Reply with quote
O.k, I wasn't sure what I was looking for... Is that far better then the 009 or? I am fairly new to the 36hp world.
Thanks for posting the pic fredy a
Mr. 010
Glenn is offline
PostPosted: Sun Nov 30, 2008 8:50 pm    Post subject: Reply with quote
Besides looking "period correct" they offer better performance over a OO9.
The VJ4BR8(019) were originally on 36hp Bus engines and and the VJR4BR25(010) were on Bastard 40hp Bus engines.
Glenn
[email protected]
PostPosted: Sun Nov 30, 2008 8:52 pm    Post subject: Reply with quote
yeah, as soon as I put it in I thought it didn't seem right...
Mr. 010
Glenn is offline
PostPosted: Sun Nov 30, 2008 8:53 pm    Post subject: Reply with quote
Bosch 010 in a 40hp Bus with vintage dual carbs.
Glenn
[email protected]
PostPosted: Sun Nov 30, 2008 9:00 pm    Post subject: Reply with quote
Thanks Glenn
fredy a
fredy a is offline
PostPosted: Mon Dec 01, 2008 7:36 am    Post subject: Reply with quote
looks cool man
the manifolds home made??
[email protected]
PostPosted: Mon Dec 01, 2008 3:58 pm    Post subject: Reply with quote
fredy a wrote:
looks cool man
Yeah, I used the stock end castings for the base and the top flanges are made off of the og manifold center(s). I spanned the distance in between with a scrap bit of tube off of an old pipe clamp... To that I added a little heat and bend... They turned out great, but I still have to tweak them a bit more.
Anyone point me in the right direction as far as a camshaft?
I plan on doing some very mild port work to the otherwise stock heads and run stock displacement (for now) yet still want a bit more lump at idle...
I love thesamba!
Last edited by [email protected] on Mon Dec 01, 2008 7:13 pm; edited 1 time in total
Mark
Mark is offline
PostPosted: Mon Dec 01, 2008 7:12 pm    Post subject: Reply with quote
Those intakes are l-o-o-o-n-g! Have you thought about shortening them to help the carbs against potential icing problems?
www.zwerks.ca
[email protected]
PostPosted: Mon Dec 01, 2008 8:05 pm    Post subject: Reply with quote
The manifolds are 12 1/4" tall from head to top of carb. not stacks but carb. So maybe they are a bit tall... but they can't be to much taller then an okrassa manifold, can they?
[email protected]
PostPosted: Mon Dec 01, 2008 8:14 pm    Post subject: Reply with quote
The top of the carb, is near the same height as the top of the genorator backing plate on my engine. It appears to be fairly close height wise to the beaty in this pic... Is icing going to be a concern?
Mark
Mark is offline
PostPosted: Mon Dec 01, 2008 8:24 pm    Post subject: Reply with quote
Not sure, I wish I had a set of Okrasas in my hands to confirm this!
Either way, ambitious project you have there. Something similar to what I want to do when I have more time in the shop.
www.zwerks.ca
Freeform Metal
Freeform Metal is offline
PostPosted: Mon Dec 01, 2008 9:34 pm    Post subject: Reply with quote
It looks like the the Okrasa are 8.125". Bottom of flange to top of flange. I might be a hair off because it is hard to measure exactly w/ them installed. I hope this helps.
Rob
[email protected]
PostPosted: Mon Dec 01, 2008 10:57 pm    Post subject: Reply with quote
Rob
With that being said, my measurement was 12 1/4" including a 28 pict, so providing a 28pict is approx. 4" tall, I am close....
fredy a
fredy a is offline
PostPosted: Tue Dec 02, 2008 6:30 am    Post subject: Reply with quote
this is my first test need some work stiil.
hugheseum
hugheseum is offline
PostPosted: Tue Dec 02, 2008 11:22 am    Post subject: Reply with quote
the length is a good thing,you get more of a ram effect,but you should fab some preheater tubes and a balancing tube between the 2 intakes,have fun
Have a great day!
fredy a
fredy a is offline
PostPosted: Tue Dec 02, 2008 12:00 pm    Post subject: Reply with quote
any ide on have to do the preheater ??
balangsing is no problem
thanks
[email protected]
PostPosted: Tue Dec 02, 2008 2:58 pm    Post subject: Reply with quote
I have balancing tubes on mine... they wrap around the back of the shroud. I will mock-up some preheater action tonight. As soon as I fix my intake studs, I want to start making the linkage...
Still gotta weld up my ex-towel bar bumper tailpipe... To bent to save IMO, so I recycled it!
Need a pulley, and some tin.... soon enough!
Thanks all!
