Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Dec 10, 2015 7:10 pm Post subject: Re: BA6 Eberspacher Gas Heater |
rickshak wrote: |
Your posting was excellent and will help me immensely. Thanks |
That's my vid btw....that's more info I didn't post on YouTube hope my vid helps ya out too! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
airkooledchris Samba Member
Posted: Thu Dec 17, 2015 9:43 pm Post subject: Re: BA6 Eberspacher Gas Heater |
Stuartzickefoose wrote: |
Got a few things left to do....but she runs so the hard part is done
Ba6 installed!!
Need to strap in the fan, fuel pump, and the coil, run a intake hose for the trigger fan, and run a 3"/2" coupler to the rear seat intake tube I'm gonna use for my recirculated air intake. Next I'll need to bolt it in, and fix a couple tubes for routing air....then just tee into the gas line and it'll actually be ready to go and drive with it |
Im so glad that BA6 ended up with someone who actually installed it! Good luck with buttoning up the remaining bits.
Did you end up using those cut outs from the donor floor for the mounts on the belly? |
Posted: Thu Dec 17, 2015 9:54 pm Post subject: Re: BA6 Eberspacher Gas Heater |
I haven't had a chance to mess with it since I tested it, but yes I will be using them! Got a chance to play with a few ba6's now and know where everything is supposed to go, so once I get a chance I'll definitely be using them! Waiting for the rain to stop for a day ...
Should have my frame aligned mid January if all goes well, so I'm aiming to have it done by then at least so I can blast the heater in this semi frigid weather
I almost didn't get it done...this ba6 and my tent nearly both went up for sale ...decided on just the tent once jason let me see what his could do...couldn't say no to a snowy day in the bus headed down a mountain with my tee shirt on and not worrying about a foggy window!!! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Dec 18, 2015 6:28 am Post subject: Re: BA6 Eberspacher Gas Heater |
How does the air flow/volume with the BA6 running compare with, say, the engine idling but hot, and the booster fan turned on? (Like at a stop light.) How about with driving down the highway?
Is the big benefit just from hotter air coming out of the vents, or do you end up with a higher volume too?
I'm debating on whether to cut my '73 for one. While driving the other day, I decided it seemed like the biggest issue was hot air flow into the bus. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Dec 18, 2015 6:32 am Post subject: Re: BA6 Eberspacher Gas Heater |
vwwestyman wrote: |
I'm debating on whether to cut my '73 for one. While driving the other day, I decided it seemed like the biggest issue was hot air flow into the bus. |
As a clarifying point, I am struggling to see if/how the fan that comes with the BA6 could/would provide extra air flow, and wondering if something less intrusive like a blower under the front floor would get me most of the way there. The BA6 fan is very similar in size/build to the booster fan.
I suppose the advantage(s) of the BA6 blower over the factory booster (even if they are the same size and all) is that it isn't pushing through the exchangers and as much ductwork and also has the recirculation feature. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Dec 18, 2015 8:25 am Post subject: Re: BA6 Eberspacher Gas Heater |
It doesn't have to blow through my leaky heat exchangers, which makes a huge difference. If it was totally sealed up like tootype2crazy did with his heater, then it would be quite similar to the booster fan. However, the recirc definitely helps get it warmer faster.
As far as heat it's something like stock heater puts out 5000 btus on a great day, and at the top end a ba6 in use with the stock heater can hit up to 55k btus. Don't hold me to those number bus that'll give you an idea
When we took my buddies ba6 bus snowboarding, the cabin was 65-70 in about 5 minutes, well before the engine got warm. Highly worth it. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Dec 18, 2015 10:06 am Post subject: Re: BA6 Eberspacher Gas Heater |
Thanks Stuart for that.
My exchangers aren't leaky, and when I installed the motor last fall, I sealed all the gaps I could with high temp RTV too.
Could you (or someone else who has one) measure the air temps coming out of the front vent and/or dash vent after the BA6 has been up and running for a bit?
Thanks! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Dec 18, 2015 11:11 am Post subject: Re: BA6 Eberspacher Gas Heater |
Notchboy can...with that kick ass camera _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Dec 20, 2015 1:04 pm Post subject: Re: BA6 Eberspacher Gas Heater |
I played with my infrared thermometer, and a meat thermometer today.
After driving the bus a bit, and in my driveway idling, I measured the outside of the heater tree at about 160. Same with the heat vents in the middle and back, both also very close to 160.
The pipe up from the heat exchanger to the on/off valve was right at 200.
It's about 55 outside. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Bleyseng Samba Member
Posted: Sun Dec 20, 2015 9:28 pm Post subject: Re: BA6 Eberspacher Gas Heater |
vwwestyman wrote: |
The benefits are:
Hotter instant air
Constant Hot air vs dependant on engine rpm
Not dependant on air flow from heat exchangers (especially if leaky) and having the engine running! Perfect for a camper.
It's my next project to do on my Westy this spring. I have been restoring hte parts slowly..... _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Tue Apr 12, 2016 9:58 pm Post subject: Re: BA6 Eberspacher Gas Heater |
Got some knowledge for y'all...
Vanagon and bay harnesses are slightly different... Here's the first of the things I noticed, the harness being the first of a few small changes throughout the setup.
I later noticed that the thermostat output temp sensor is a different size on the ends, but both work. I'll post most pics when I fully remove the Vanagon one to install the bay harness and such.
206-841-7324
[email protected] |
Posted: Mon Apr 18, 2016 9:50 pm Post subject: Re: BA6 Eberspacher Gas Heater |
So I decided to do some comparisons as I swapped my whole ba6 out for a bay version gonna actually get the new used unit out and make it work later, and put the swole bay unit into a bay and Vanagon into my Vanagon... go figure...
The first:
206-841-7324
[email protected] |
Posted: Mon Apr 18, 2016 10:08 pm Post subject: Re: BA6 Eberspacher Gas Heater |
Harness:
206-841-7324
[email protected] |
Posted: Mon Apr 18, 2016 10:50 pm Post subject: Re: BA6 Eberspacher Gas Heater |
Trying to get all the pics uploaded but taking forever...once they get uploaded then interested parties can find them under a search for BA6 posted by me. I'm not gonna post it all here. Basically pics of the stuff in the videos. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Jun 12, 2016 12:12 am Post subject: Re: BA6 Eberspacher Gas Heater |
Gonna pass along my spare parts...2 full setups essentially. Missing 2-4 things but enough to make what you need work!
Check my ads _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Abscate Samba Member
Posted: Sun Jun 12, 2016 4:59 am Post subject: Re: BA6 Eberspacher Gas Heater |
That heater will considerably up your chances with random Bay women who cruise through your domain, Stuart
Bravo Zulu _________________ .ssS! |
Posted: Sun Jun 12, 2016 9:42 am Post subject: Re: BA6 Eberspacher Gas Heater |
True.
I have mine and the knowledge so what do I need the 2 extra sets for? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sun Jun 12, 2016 10:49 am Post subject: Re: BA6 Eberspacher Gas Heater |
Abscate wrote: |
Bravo Zulu |
Ahhhh. Now I completly understand why you broke that cute girls combustion fan!
You clever little shit you. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
L51C_75 Samba Member
Posted: Mon Jan 08, 2018 9:24 pm Post subject: Re: BA6 Eberspacher Gas Heater FAQ |
Hello, New Westy owner here, great thread with lots of great info, pictures and videos. I am hoping to get the heater in my 77 functional again, and was able to pick up a mint BA6 complet with harness from an 84 Vanagon. My plan was to use this heater for parts, but based on the condition of it, I may just swap it in directly into my Bus instead. I did notice something different though on the combustion blower from the vanagon, it has a ground wire coming out of the top of the rubber boot, and the Vanagon harness does not appear to have a ground in the harness at the round connector with the 4 pins. Has anyone seen a combustion blower like this before? Here is a link to new one like mine below.
https://goo.gl/images/8Xg9M4
I am assuming I should be able to just swap the Vanagon heater straight over and use my existing 77 harness?
Any help would be appreciated
Thanks |
Posted: Tue Jan 09, 2018 5:11 am Post subject: Re: BA6 Eberspacher Gas Heater FAQ |
Weird. I knew there were a few slight differences in the two heaters, but that is not one I was aware of. I thought they were primarily how the airflow was ducted, and how the wiring interfaced with the heat controls up front. I wonder if that was an "extra" ground perhaps?
The other plug appears to be the same, perhaps all four contacts are still used, meaning you could plug your harness into it and go. The best way to tell for sure would be to test each pin with a multimeter and check for the same function.
It may be overall less work to diagnose what is in the bus and just replace the faulty component(s), and keep the rest as spares. _________________ Dave Cook
1973 Wild Westerner
My Thing |
