sszakats Samba Member
Joined: November 26, 2008 Posts: 45 Location: New Jersey
Posted: Fri Dec 05, 2008 9:43 am Post subject: starting the Denzel |
I am about ready to fire up the 56 ghia motor with a vintage Denzel hop-up kit installed. This motor is original and was last running about 2 years ago. When it was last run, it ran out of gas. Since then it has been turned over regularly but not fired. The gas tank was removed and cleaned. New fuel filters and 6v battery were installed. I did not do any work on the motor while the car was idle.
My questions are as follows:
1. What precautions should I make before trying to fire the engine? Change the oil? The engine oil was fresh when the car was idled 2 years ago.
2. The car was run out of gas when last fired. Should I do something with the carbs before I turn on the fuel pump? Or can I assume they are OK since the car was run out of gas?
3. What type of fuel should I pour into the tank? Any recommended additives?
4. I have heard of people pouring some oil into the cylinders before starting the engine. Is this recommended? If so, what should I pour in and how much? Spray WD40 into the cylinders?
Any other recommendations are highly appreciated.
Thanks, Steve |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Fri Dec 05, 2008 10:43 am Post subject: |
The first thing you should do is post some pics of that square ported beauty! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
water guy Samba Member
Joined: January 25, 2008 Posts: 463 Location: Puyallup Washington
Posted: Fri Dec 05, 2008 7:42 pm Post subject: |
I would change the oil for sure. _________________ '55 Porsche Continental
'63 Firetruck |
Joined: March 18, 2002 Posts: 593 Location: Peterborough, Ontario, Canada
Posted: Sat Dec 06, 2008 9:07 am Post subject: |
And a big no on the wd40 in the cylinders...
Your engine has two fluids, gas and oil. Neither one of them contain wd40.
A light oiling would be o.k if you are worried about damage to the rings during initial start up...
Post pics and/or video of your vintage speed beauty when you get'er running please!
An early ghia with a denzel! AWSOME!!!! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13954 Location: Southampton U.K.
Posted: Sat Dec 06, 2008 12:38 pm Post subject: |
John Moxon wrote: |
[email protected] wrote: |
Marvel Mystery Oil is recommended for a pre-start up procedure. Take out the spark plugs and add about 2 tablespoons to each cylinder.
Leave to sit for 24-48 hours and then turn the engine over by hand. If it all turns nicely fire it up and run it to burn off the oil. Clouds of white smoke but no problems. |
Awsome, I am gonna find some of this stuff!
Last edited by [email protected] on Sat Dec 06, 2008 1:25 pm; edited 1 time in total |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Dec 07, 2008 12:38 pm Post subject: Un-loved........... |
Enjoy photos! Cheers! Mr. Okrasa
Posted: Sun Dec 07, 2008 1:02 pm Post subject: |
Now THOSE are some porn shots... _________________ Your Vanagon sucks, Stop waving at me.
tommy-turtle Samba Member
Joined: March 07, 2002 Posts: 165 Location: roseville
Posted: Mon Dec 08, 2008 1:10 am Post subject: |
Put some gas in it and run it. Dump the clutch and see if you can get it to spin the tires. Well just try the gas, worry about spinning the tires after it stops. It is a rare motor, but so were Judson's, pepcos, Mag(blowers), okrassa, and 2pc Pre A motors, thought of at one times. With the internet more and more of these pop up.
Be proud of that thing and drive the wheels off it, to many sit in the dark and collect dust. _________________ 5 lbs into 3 lbs bag every day
Nitrous its what my dentist uses |
Posted: Thu Dec 11, 2008 5:22 pm Post subject: |
This shows the rectangular exhaust ports?
This is th engine in general!
What do you guys think? Steve |
AXAM Samba Member
Joined: November 02, 2003 Posts: 314 Location: Gods country,ca
Posted: Fri Dec 12, 2008 7:48 am Post subject: |
tommy-turtle wrote: |
Be proud of that thing and drive the wheels off it, to many sit in the dark and collect dust. |
Well, did you fire it up??? pulled the plugs, few squirts of marvel mystery oil, put fresh oil in it, I would even put some 30wt brad penn break in oil. turn it over a few times without the plugs, fresh gas. check all the fuel lines for cracks and fire it up.
otherwise I be over and do it for you.....but on that test drive I may be gone for awhile......... _________________ Life is Good! Have a Nice Day!-don't worry about the jerks out there on the forum, in the end... they fall, and fall hard!
Peace! |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Fri Dec 12, 2008 12:00 pm Post subject: |
holy crap!!!!!!!!!! that car is neat looking,whats the story behind it and can we please see more pics of the car?
yes the engine is pretty epic too _________________ Have a great day! |
Posted: Sat Dec 13, 2008 6:03 am Post subject: |
[quote="AXAM"]
otherwise I be over and do it for you.....but on that test drive I may be gone for awhile......... |
No, I didn't start it yet. As you can see on the pics, I am still putting the brakes back together (Porsche 356 b drums all around). I also decided to paint the gas tank beofre I reinstall it so I am probably a few weeks away from trying. But I'll keep you guys posted. What other pics do you want me to take??
Steve |
Jason M Samba Member
Joined: September 21, 2003 Posts: 183 Location: Arizona
Posted: Sat Dec 13, 2008 10:41 am Post subject: |
does anyone have pics of the heads? _________________ Jason
The Original German Folks |
Posted: Mon Dec 15, 2008 6:50 pm Post subject: Photos of Denzel Heads |
Jason M wrote: |
does anyone have pics of the heads? |
Wanted to see some photos of Denzel heads? Here you go....
Posted: Mon Dec 15, 2008 7:20 pm Post subject: |
nice....are those the sandcasted p11s? _________________ Have a great day! |
Posted: Tue Dec 16, 2008 1:16 am Post subject: Denzel Heads / Sancast Weber 40DCM / Solex 40P-11 |
hugheseum wrote: |
nice....are those the sandcasted p11s? |
Absolutely! Here's more...... Enjoy Pics. Cheers! Mr. Okrasa
