Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sun Jun 06, 2010 5:08 am Post subject: |
if it was me (i always hate starting with that statement) i would run a 10 or 12ga wire from the battery up to the front of the bus to a secondary fuse box you could tuck under a kick panel. i would fuse the feed wire at the battery (for extra protection) then you could power a few extra goodies. you can follow the OE harness front to rear pretty easily. when i did my gauges, i bought a roll of wire for a trailer, so it was 4 wires, bonded together and was like killing 4 birds with one stone, jut another idea if you are going to run wires _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Randy in Maine Samba Member
Posted: Sun Jun 06, 2010 6:14 am Post subject: |
Yes I am already doing the 4 wire trailer wiring thing for the gauges (+ the CHT wires) run ina wiring loom coming out at the drivers left foot, but I didn't know if a 10 gauge wire was heavy enough for the 20 amps needed for the seats. It would certainly fit in the 3/8" wiring loom though. |
Opossum Samba Member
Joined: February 26, 2005 Posts: 735 Location: Islets of Langerhans
Posted: Sun Jun 06, 2010 10:30 am Post subject: |
skills@eurocarsplus wrote: |
if it was me (i always hate starting with that statement) i would run a 10 or 12ga wire from the battery up to the front of the bus to a secondary fuse box you could tuck under a kick panel. i would fuse the feed wire at the battery (for extra protection) then you could power a few extra goodies. |
Exactly. I ran a fused 10 gauge wire to a secondary fuse box located behind the glove box. It has fuses for the power windows, stereo, fresh air fans, and 12v power outlet. These all run from the auxiliary battery.
The heated seats run off the main battery with a dedicated fused (at the battery) 10 gauge wire. I did this with the H4 headlights and a/c too.
Be sure to use a relay and connect the heated seats so they can only be used when the bus is running. _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Sun Jun 06, 2010 3:16 pm Post subject: |
I guess one of the first questions is, 'what does a bus pull in terms of amps when running? Engine/AC?/Headlights?' How close are you to the return value of a 40A alternator on a standard bus, never mind those of us lucky enough to have the 70A.
Knowing the delta might help a lot.
Knowing the goodies I'd like to put to on a 40A rig, I think I'm a candidate for a dual battery rig, rather than pursuing the 'unobtainium' 70A alternator.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Posted: Sun Jun 06, 2010 4:09 pm Post subject: |
webwalker wrote: |
Try E-bay? http://cgi.ebay.com/ebaymotors/VW-Mini-Bus-Porsche...ccessories
75 amp. $89.99 with one year warranty. _________________ "You can lead an aircooled to water, but you can't make it drink"
fastmc25 Samba Member
Joined: January 01, 2004 Posts: 1202 Location: East Tennessee
Posted: Sun Jun 06, 2010 5:31 pm Post subject: |
Randy in Maine wrote: |
Well I am going to bring this post back to life and I need some advice....
This 79 "project bus" has a 70 amp alternator.
I bought a couple of these that will be going in. Currently the seats are all torn apart, getting new foam cushions, new seat covers (brown camping cloth of course), cleaning and repainting the innerds.
http://www.heatedseatkits.com/heatedseatkits/iheat2/index.html
How should I wire these up? I need to get 20 amps to the front of the bus to power them up and I was thinking about putting an additonal fuse box someplace to do it. How big of wire do you figure I need to run? I will likely mount the switches in the floor like opposum did.
The only other wierd stuff I have going on in here is that I would also like to power up the 2 "ambulance fans" and the power amp for the stereo into this new fusebox if that is the way to do it.
The stock fuse box can do the ambulance fans if needed and the power amp comes off the battery right now. I could just leave that alone if needed. The power amp is currently under the rear seat, but will likely move to the overhead compartment. I would rather deal with it all at once as opposed to in phases.
The bus is headed for the paint shop here later this week and will be naked on the inside (and outside also....no windows or pop top as they are getting new seals/canvas after the paint job).
Thoughts? |
Hey Randy,
I ran a separate 8 Ga. wire (from the Battery) to the front and installed a 6 fuse panel under the dash for running accessories from.... I run my front radiator fan, heater and a couple of accessory items from it.... no problems at all.... I ran it all under the bus along one of the frame rails and secured it with zip ties.......ensuring it was clear of any items that may damage it or rub it...
Just remember the longer you go you need to go bigger for higher amperage use.....I have thought of going up to a 6 ga. wire but don't need it at this time... _________________ Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Pissed Old GI ” |
chabanais Samba Member
Posted: Thu Jul 29, 2010 10:41 pm Post subject: |
I ordered the heated seat kits, relay, and fuse box from Amazon. I'll have it done in 2 weeks I'll post pics!
This thread was of great help.
Here's to hot asses. _________________ "I spud therefore I yam." |
Posted: Tue Aug 10, 2010 5:10 pm Post subject: |
Mostly done here's a picture of the passenger side switch installed in my center console. Works great!
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sun Feb 08, 2015 10:44 am Post subject: |
chabanais wrote: |
Mostly done here's a picture of the passenger side switch installed in my center console. Works great! |
Your butt still getting hot? Just curious how well those heaters have held up. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sun Feb 08, 2015 3:55 pm Post subject: |
scrivyscriv wrote: |
chabanais wrote: |
Your butt still getting hot? Just curious how well those heaters have held up. |
Does fine. _________________ "I spud therefore I yam." |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Feb 10, 2015 1:32 am Post subject: |
Or you could do what I did and achieve the same results...no cold ass seat to sit on. These are holding up very well. Had them done 15 or so years ago.
_________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Brian Samba Moderator
Posted: Tue Feb 10, 2015 1:35 am Post subject: |
I have gone through many winters with leatherette seats. My solution: a jacket. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Feb 10, 2015 1:50 am Post subject: |
Brian wrote: |
I have gone through many winters with leatherette seats. My solution: a jacket. |
Move to Colorado and play that |
