sebgi1 Samba Member
Joined: September 19, 2005 Posts: 169 Location: Quebec, Canada
Posted: Fri Aug 14, 2020 3:26 am Post subject: Re: Barndoor Assembly Line Pics |
Capriacci wrote: |
24-A Model, fresh from the assembly line? |
I wonder how that lift works with only two arms on the same side. _________________ SEB
Dogs are the most precious and valuable possession of mankind. VWs are second!
'73 Neptune blue safare camper
'71 Neptune blue tintop |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3838 Location: San Jose, CA
Posted: Fri Aug 14, 2020 6:23 pm Post subject: Re: Barndoor Assembly Line Pics |
It looks to me like there is a subframe mounted to the chassis of the Bus (or the Bus is resting on it). Presumably, that subframe consists of two parallel rails with two long pins running laterally through them. The ends of those pins would attach to the two lifting arms in the nearside of the photo.
If you look closely, there is a potential illusion in viewing the two arms, but they appear to be oriented inline with the length of the rails of the entire assembly, and they're action is in parallel with the ramps and up-and-down in the fore/aft direction, and so when it lifts, it resembles two railroad crossing arms lifting in the same direction, thereby translating the Bus in a bit of forward travel upon lifting, and then rearward again upon lowering. While hard to judge at the angle pictured, it looks like there is enough of an offset so that when the Bus moves rearward slightly upon lowering back down, the front beam would rest in the cradles, as would the rear torsion tube on its cradles. Does that make any sense?
There also appears to be a leadscrew down the middle, which looks to be for actuating the two lifting arms.
Just my two cents based on what I see. Of course, I could have it ALL wrong. |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Mon Oct 19, 2020 8:07 am Post subject: Re: Barndoor Assembly Line Pics |
Bottom picture is a (new) third one in the series
_________________ -StockRocks- |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2171 Location: Graz, Austria, Europe
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24037 Location: Southeast USA
Posted: Sun Nov 22, 2020 12:21 am Post subject: Re: Barndoor Assembly Line Pics |
_________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
CaLiBus Samba Member
Posted: Fri Nov 27, 2020 7:12 am Post subject: Re: Barndoor Assembly Line Pics |
I’m sure there was a better technique and posture approach to crimping that lower nose. It appears he was asked to pose for this shot |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1259 Location: Yulee FL
Posted: Fri Nov 27, 2020 7:58 am Post subject: Re: Barndoor Assembly Line Pics |
8:36 AM on a Tuesday
the boss Samba Member
Posted: Sat Nov 28, 2020 3:44 am Post subject: Re: Barndoor Assembly Line Pics |
Respect for all those workers ... |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Sun Nov 29, 2020 11:55 am Post subject: Re: Barndoor Assembly Line Pics |
the boss wrote: |
So true. It was 5 years since the end of WWII, and those guys had been through hell. Most were probably soldiers in the war, and would have been through defeat, possible POW status, and the postwar scarcity and rationing. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Sun Nov 29, 2020 12:12 pm Post subject: Re: Barndoor Assembly Line Pics |
Also considering the working conditions and labor hours of the era. Even though the factory was 'modern' for its time, I am sure it was cold in winter and hot in summer. At that time it was at least 48 hours a week (6x8). Certainly the air must have smelled oily, steel trenched, dusty. those heavy spot welders, gigantic and bulky grinders, and the noise must have been unreal in such a huge building with unshielded working booths. imho, the nastiest job must have been wet sanding the body assemblies. those huge panels, and day by day, and most probably that wasn't warm water to begin with. My arms and back are getting sore only thinking about half a day of that...imagine doing that 300 days a year. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Mon Nov 30, 2020 11:27 pm Post subject: Re: Barndoor Assembly Line Pics |
The factory did shut down for holiday in July. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Two Glove Boxes Samba Member
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Dec 02, 2020 9:55 am Post subject: Re: Barndoor Assembly Line Pics |
i wonder if you could order a birth certificate for VIN number 20-001000?
just to validate the build day, color and options?
maybe 998 and 999 as well? _________________ regards
Uli
aa390392 Samba Member
Posted: Sat Dec 05, 2020 10:19 am Post subject: Re: Barndoor Assembly Line Pics |
Mandrak, why dont you try getting a BC an get back to us, will ya
Thx. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
finster Samba Member
Joined: May 26, 2012 Posts: 7934 Location: north o' the border
Posted: Tue Dec 08, 2020 4:06 am Post subject: Re: Barndoor Assembly Line Pics |
easy engine removal/install
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Tue Dec 08, 2020 1:08 pm Post subject: Re: Barndoor Assembly Line Pics |
djfordmanjack wrote: |
terrific shot !
It'd be interesting of how the hoist truss 'grabs' the engine. It appears to be attached to the valve covers/heads. or maybe that's just a side to side rest and it has further brackets below engine. |
me too, that looks like a very nifty tool. certainly niftier than a floorjack and a block of wood.
chances are it "grabs" it by sitting under the oil drain, perfectly centered _________________ regards
Uli
Posted: Tue Dec 08, 2020 2:40 pm Post subject: Re: Barndoor Assembly Line Pics |
That looks a little off topic, as I'm not sure that's how they installed engines on the assembly line.
(I know, I'm a buzzkill.) _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Posted: Tue Dec 08, 2020 3:01 pm Post subject: Re: Barndoor Assembly Line Pics |
Blue Baron wrote: |
(I know, I'm a buzzkill.) |
no, you are not. love all the pictures you have found.... _________________ regards
Uli
