therealfrogman Samba Guitar Hero
Joined: October 23, 2007 Posts: 666 Location: Pueblo, Co
Posted: Fri Dec 12, 2008 8:52 pm Post subject: Converted to 12 volt? I cant tell. |
Okay, bought a 65 with a 12 volt battery in it, PO said it was converted to 12 but it was an incomplete project and the guy is a kid so who knows. It has a stock 40 hp in it and I mean it looks stock so im trying to figure out what is true without spending too much time in the freezing garage. It has a 009 on it but everything else looks stock and I cant find anything that indicates its a 12v conversion.
Theres a 12v battery in it thats reading 8.1 volts and the wiring has been hacked. All of my past dubs have been 6volt so please give me a free pass on this question.
If I go out and pull the starter should there be 12 volt stamped on it or no? I think I could handle the cold for the time it takes to do that. _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Really appreciate what Everett has done here. Almost like he hand picked some of you. I am very thankful for all the help I get here. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Dec 12, 2008 8:57 pm Post subject: |
That is a 6V generator on the engine. Sounds like the only conversion done was to install the 12V battery. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Dec 12, 2008 9:02 pm Post subject: |
Russ Wolfe wrote: |
That is a 6V generator on the engine. Sounds like the only conversion done was to install the 12V battery. |
If the POS tried to run it like this what gets trashed? _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
JinxedSydney Samba Member
Joined: May 06, 2008 Posts: 576 Location: Redding, CA
Posted: Fri Dec 12, 2008 9:08 pm Post subject: |
Wear earplugs and try the horn. _________________ '63 Beetle "Gertie"
Yes, I am indeed a chick that does her own work on her own Dub. |
stale air Samba Member
Joined: August 23, 2007 Posts: 5154 Location: Senoia Ga, formally NorCal
Posted: Fri Dec 12, 2008 11:25 pm Post subject: |
JinxedSydney wrote: |
Wear earplugs and try the horn. |
And then try the wipers. _________________ WANTED: Henry Veale Santa Rosa plate frames
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Sat Dec 13, 2008 6:04 am Post subject: |
The coil should say if it's 6 volt, and the choke element cover plate will say 6V or 12V. The very last thing that should be added to the conversion is the battery. Sounds like it was being done in reverse. I'd ask Santa for a nice new Interstate 19L 6V battery and a poratble heater for the garage. At least get a heater, you're gonna need it for the work you got ahead of you. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
krlang Samba Member
Joined: October 16, 2004 Posts: 228 Location: Commonwealth of Massachusetts
Posted: Sat Dec 13, 2008 7:02 am Post subject: |
Sounds like its really an 8v battery. _________________ 67 Type I in Harley turquoise(1914CC)
"Then I landed on the water, Just about my favorite thrill....." -JB |
Posted: Sat Dec 13, 2008 7:38 am Post subject: |
krlang wrote: |
Sounds like its really an 8v battery. |
Good god! Im no testing guru but I know how to use a meter and that just looked weird, never seen that before. I just want to see if this engine runs before I swap the pan out and sell the engine. I will put my 6 volt battery in it and see if anything turns on.
I do have a heater I just need to get some kerosene today. _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Posted: Sat Dec 13, 2008 11:28 am Post subject: |
Count the number of cells in the battery. 6V = 3, 8V = 4, and 12V = 6.
Check what the coil says. Check what it says on the choke element.
Check what the sealed beams say on the back. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
