passoa55 Samba Member
Posted: Sat Dec 13, 2008 11:55 am Post subject: 1967 walk trough pannel with accidental dammage! |
I've restored this bus 5 years ago.
It was realy nice till now!
A SMART drove into the left rear side of the bus, turned around and hit the door, dogleg and frontbumper.
A luck he haves a good insurance and a good friend!
A luck you can still find NOS parts.
Take a look!
http://forums.pre67vw.com/Default.aspx?g=posts&t=16298 _________________ 1950 Hebmuller #458
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1963 firetruckred 23 window
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Sat Dec 13, 2008 12:08 pm Post subject: |
nice work... _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
Aaron Samba Luddite
Posted: Sat Dec 13, 2008 10:58 pm Post subject: |
Looks good. How did you weld up high on the vertical forward seam on that? (Not the horizontal butt weld.) This area is hard to get to anyway and you are working on a walkthur so have to get around the tire holder. _________________ ____________________
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Dec 14, 2008 8:10 am Post subject: |
Nos is sooooo nice. Are there a lot of these items still on earth? Yeah, how did you weld the upper part by the vents? From what little I know about it it's a good job. |
Runboy Samba Member
Joined: September 19, 2007 Posts: 298 Location: Antioch Ca - Soon to be Crescent City Ca
Posted: Sun Dec 14, 2008 10:48 am Post subject: |
You can see that he seemed it a couple inches below the beltline. That is why there is solid filler there to smooth out the weld.
Mike |
Posted: Sun Dec 14, 2008 11:31 am Post subject: |
The vertical part is glued with 3M glue for metalparts. _________________ 1950 Hebmuller #458
1967 SO42 westy
Aaron Samba Luddite
Posted: Sun Dec 14, 2008 1:26 pm Post subject: |
Runboy:
Aaron wrote: |
Looks good. How did you weld up high on the vertical forward seam on that? (Not the horizontal butt weld.) This area is hard to get to anyway and you are working on a walkthur so have to get around the tire holder. |
Passoa55:
thanks for the info. I thought maybe you had a special set of jaws for a spotwelder, or a really good trick for me. I have opened a "window" in the inner skin before to access upper most part of this area, it works but is a 1 step back, 2 steps forward kind of deal. I just pre-drilled the flange on the donor corner and plug welded bind, by feel, most of the way up.
Anyway, thanks for the info.... _________________ ____________________
Runboy Samba Member
Posted: Sun Dec 14, 2008 8:59 pm Post subject: |
Aaron wrote: |
Runboy:
Aaron wrote: |
Passoa55:
Anyway, thanks for the info.... |
Ya, I gotcha.
The 3M panel adhesive is good stuff but I would at least want a nice plug weld at the top and bottom of that flange. I think your idea of cutting a window for accessing the very top for a plug weld, plug weld at the bottom, combined with the panel adhesive the rest of the way down may be a good option.
Mike |
BarryL Samba Member
Posted: Mon Dec 15, 2008 8:05 am Post subject: |
I used aircraft bolts in mine in each spot-weld hole. It took two guys to tighten them and start them; a major nightmare. I love the NOS stuff. |
Posted: Wed Dec 17, 2008 3:22 pm Post subject: |
Quote: |
Ya, I gotcha.
Mike |
It had some plug welds at the bottom near the splashpannel.
Is back in primer now.
Tomorrow painting inside. _________________ 1950 Hebmuller #458
1967 SO42 westy
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Thu Dec 18, 2008 7:25 pm Post subject: |
passoa55 wrote: |
The vertical part is glued with 3M glue for metalparts. |
passoa55,
Wow very impressive. I did a search but I can't figure out which one you used. Can you get me the product number? I will use my MIG on my project but there are some areas I would like to try that stuff out on.
Thanks a ton,
Linda _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Tue Dec 23, 2008 1:43 pm Post subject: |
I will check what the number of the product is.
Some new pictures!
Bus is painted! _________________ 1950 Hebmuller #458
1967 SO42 westy
Posted: Fri Dec 26, 2008 6:39 am Post subject: |
That's all folks for this year! _________________ 1950 Hebmuller #458
1967 SO42 westy
Posted: Thu Jan 08, 2009 12:34 pm Post subject: |
I've posted some pictures of the 3M glue that I used for the corner.
1967 SO42 westy
Posted: Sun Mar 22, 2009 1:32 pm Post subject: |
Last pictures are posted,
Looks nice to me! _________________ 1950 Hebmuller #458
1967 SO42 westy
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun Mar 22, 2009 5:20 pm Post subject: |
It's beautiful. Congrats.
Now come to Texas and fix mine. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Sun Mar 22, 2009 7:50 pm Post subject: ! |
It looks really good. Nice! |
Posted: Sun Mar 22, 2009 11:43 pm Post subject: |
zozo wrote: |
That would be a long distance restoration! _________________ 1950 Hebmuller #458
1967 SO42 westy
