don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2829 Location: West Palm Beach, FL
Posted: Fri Dec 28, 2018 5:38 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Installed BRV split swing axle boot (the kit was missing 2 nuts so I had to use 2 from the old boot).
Fits nice and tight.
Looks good.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Fri Dec 28, 2018 5:40 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Spent some time cleaning up the undercarriage with degreaser and brake cleaner.
Posted: Fri Dec 28, 2018 5:41 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Drained all the old trans fluid, cleaned lots of gunk from the magnet on the drain plug.
Filled with 2 quarts of Valvoline 80W-90 gear oil.
Posted: Fri Dec 28, 2018 5:44 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Replaced fuel line and filter under the bus.
Decided to skip using the worm clamps.
This hose was much tighter.
Posted: Fri Dec 28, 2018 5:46 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Replaced the piece of rubber I used as a gasket under the vented gas cap.
It was dried up.
Used a new valve cover gasket as a fuel cap gasket after cutting it to fit.
Posted: Fri Dec 28, 2018 5:50 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Put my overriders back on the rear bumper and installed my street sweeper mud flaps.
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Wed Feb 20, 2019 7:52 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
EverettB wrote: |
don.ville wrote: |
You can use the gasket for the oil cap too, no seam |
Ah, ok. Good to know. _________________
Posted: Wed Feb 20, 2019 7:59 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
I had such amazing success with the Wolfsburg West oil drain plate gaskets that I decided to try their valve cover gaskets.
No such luck.
Maybe I got a bad one but one side leaked just sitting in the garage.
The other side was dry.
I switched back to cork.
Never had problems with that as long as I changed them after each valve adjustment _________________
Posted: Sat Mar 02, 2019 4:03 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Time to make some panels out of plastic cardboard.
Don’t have to worry about getting them wet and warping
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Sun Mar 03, 2019 3:46 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
don.ville, I wish I still had my original kick panels as I would have sent them to you, although I did send them it to a Veteran several years ago to complete his bus.
You are very inventive with that corrugated plastic.
Thinking of your peach bus today, I just received a set of VW Trends 1996 and your beauty is in it. Keep up the good work.
don.ville wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Mon Mar 04, 2019 4:35 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
LAGrunthaner wrote: |
Thank you Linda 🤘 _________________
Posted: Mon Mar 04, 2019 4:44 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Did a recent cruise with the Treasure Coast V-Dub Club to Port Mayacca, FL
Posted: Tue Mar 05, 2019 3:02 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
VW Trends needs to update their cover photo for a retrospect
Maui Roadsters
Lind wrote: |
Posted: Sat Apr 06, 2019 10:55 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
The wiring on this bus is totally hand made by the customizers that made it.
Many parts are from different year VWs.
Recently the turn signals started to flash really fast even though no bulbs were out. This usually happens because of low voltage/bad grounds.
I did some voltage checks and noticed there was a voltage drop on the ignition circuit.
I also wanted to clean up the wiring behind the speedo as it looked so untidy.
I can’t replace the wiring with a new harness without putting back all the factory switches and lights which I don’t have.
The start:
Some of the aftermarket wiring used in the bus have gotten buildup on the internal copper.
Gettin closer
Finished product:
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sun Apr 07, 2019 11:45 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Way more copacetic. Now the flashers work normal? |
Posted: Mon Apr 08, 2019 6:37 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
BarryL wrote: |
The flashers always worked great, and still do.
Note: for some reason the previous owner installed euro style tail lamps.
The turn signal is a separate bulb in the lower half of the taillight, NOT combined with the tail/stop bulb.
So the wiring is different due to that.
The flasher relay is not the 9 prong bus version, neither is the hi/low beam relay.
The turn signal switch is from WW which seems correct for this bus so I had to wire it differently to match my bastard bus
The turn signals were always flashing fast (like a bad bulb) even with all the bulbs working. (Especially when you pressed the brake. )
At night with the headlights on, if you pressed the brake the GEN light would come on very dim.
All seemed to be symptoms related to low voltage, poor terminations, poor grounds.
Cleaned and tightened up connections, removed redundant crimps, terminations, wires, and reduced voltage drop across various points.
Drove it last night and didn’t see any of the previous issues.
Fingers crossed 👍👍👍😀 _________________
Posted: Wed May 01, 2019 11:10 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Evolution of the face of this bus.
1996
2008
2014
2019
