Braukuche Samba Member
Posted: Mon Dec 15, 2008 6:03 pm Post subject: Heat treating a EMPI stroker crank? |
My crank is at the machinist and he called to suggest that I have the EMPI stroker crank for my 36 horse heat treated as he had to grind it. There is a risk of it twisting apparently, and he is not sure it needs to be done. Anyone know?
--Dan |
Unkl Ian Samba Member
Joined: September 11, 2008 Posts: 288 Location: Near Toronto
Posted: Tue Dec 16, 2008 9:13 pm Post subject: |
How much did he grind it ?
What stops it from distorting during heat treatment ?
I'd be looking for a different machine shop. |
Posted: Wed Dec 17, 2008 12:09 pm Post subject: |
Unkl Ian wrote: |
I phrased it wrong. He said that distortion could occur during heat treatment. The crank is fine. He ground it one under.
--Dan |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Wed Dec 17, 2008 9:15 pm Post subject: |
i guess i dont see the point,with cranks you want to balance and magniflux to make sure you have no cracks......to my knowledge it shouldnt need heat treating and i might be very curious to make sure my machinist knows these cranks BEFORE grinding,best of luck _________________ Have a great day! |
Posted: Thu Dec 18, 2008 12:29 pm Post subject: |
hugheseum wrote: |
i guess i dont see the point,with cranks you want to balance and magniflux to make sure you have no cracks......to my knowledge it shouldn't need heat treating and i might be very curious to make sure my machinist knows these cranks BEFORE grinding,best of luck |
I don't know about you guys but finding knowledgeable machinists for 50 odd year old VW engines is getting damned hard. Most of them are dead or retired. The guy I am using does a lot of aircooled VW and Porsche work so i feel relatively comfortable. Its just that he has no experience working with an EMPI stroker crank from the '50s and hasn't seen much 36 horse stuff of late. I guess if I was willing to look outside of the area I could find someone more knowledgeable but I like to stay local as I have heard toomany horror stories about stuff going missing that has been farmed out to far away destiantions.
--Dan |
Posted: Thu Dec 18, 2008 12:54 pm Post subject: |
hopefully he knew what he was doing,alot of porsche cranks have been ruined by improper machining by vw machinists,they machine differently at the cheeks. i dont know about empi cranks though,seriously i do wish you the best of luck _________________ Have a great day! |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Thu Dec 18, 2008 1:12 pm Post subject: |
id like to find a new old machinist my guy just retired after more years than i can count |
