Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Jon_slider Samba Member
Posted: Thu Mar 25, 2010 9:15 am Post subject: |
> The pin should be in the tow hook. This keeps the possibility of the pin unscrewing down. A 3/4 shackle with a higher WLL can be used as well.
thanks! learned something new, and yes, I confirmed the 3/4 shackle fits the way you pin it.. at the rear of the van.
The 3/4 shackle wont work with the pin thru the front tow loop, it will install but rides too far back from the actual loop..
the 3/4 shackle will work with the D ring thru the front tow loop.. (and the pin should be half a turn loose to prevent it getting overtightened by the pull)
randywebb Samba Member
Posted: Thu Mar 25, 2010 5:24 pm Post subject: |
Alaric.H wrote: |
Screw chain use Hi tech rope its lighter and safer plus stronger and it will not stretch. |
you mean the stuff that Gator Supply sells for ocean going ships?
or what, exactly? |
Posted: Thu Mar 25, 2010 7:18 pm Post subject: |
randywebb wrote: |
Alaric.H wrote: |
or what, exactly? |
http://www.okoffroad.com/stuff-winchrope-atv.htm |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Thu Mar 25, 2010 9:25 pm Post subject: |
The synthetic stuff is amazing and waaaay safer than chain/cable, but it's not UV safe, so keep it stored out of the sun. A heavy bag is fine for this, or any cabinet inside the van.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Thu Mar 25, 2010 10:17 pm Post subject: |
> what exactly
from page 1:
http://tinyurl.com/yelwh6x
read page 2 for a link to 3/4" D rings rated for the same load as the winch line extension, strong enough to hold two of Alaric's Syncro Beasties |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Orbitald Samba Member
Joined: August 12, 2004 Posts: 320 Location: Oakland, CA
Posted: Fri Mar 26, 2010 12:55 pm Post subject: |
>SyncroGhia: One of the nicer mounts I have seen.
Thx! _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
Posted: Fri Mar 26, 2010 1:39 pm Post subject: |
Just out of curiosity...What role did the breaker bar rack play in a winching operation? That's a breaking device, not a pulling device. _________________ '89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * * |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Mon Mar 29, 2010 4:48 pm Post subject: |
Regarding using the Hi-Lift as a winch: The Hi-Lift videos state that either chain or tow strap can be used on both ends. How does it work with a strap on the side that winches? How would the strap be shortened after each winch "cycle?"
_________________ -James
86 Syncro Westy, etc |
Posted: Tue Mar 30, 2010 11:32 am Post subject: |
Very cool. Like the chimney-snorkel too! _________________ -James
Posted: Tue Mar 30, 2010 12:16 pm Post subject: |
Jon_slider wrote: |
You can use a Hi lift Jack with a strap at EITHER end, but NOT BOTH ends at the same time. You are correct, if you dont use chain at one of the ends, you would have no way to adjust the length of the pull. |
Ok, gotcha. _________________ -James
Posted: Tue Mar 30, 2010 1:15 pm Post subject: |
_________________ 1986 2.1L Westy 2wd Auto Trans. |
tozovr Samba Member
Posted: Tue Mar 30, 2010 3:05 pm Post subject: |
squeegee_boy wrote: |
Robyn |
THANK YOU!
NEVER pull with Chain. NEVER. Never pull or tug with cable from a winch. Chain and cables are not designed for shock loads in a recovery situation.
Mounting a Hi-Lift outside the rig is good if you keep it free of debris and grit. If you live here in New England it MUST be bagged or just kept inside.
It does look pretty beefy to run them on the bumper or rack, but you will pay the price when it comes time to use it down the road.
This is coming from my 20+ years involved in Rovers, Cruisers and Jeeps and the recoveries that are always happening. been to many driving schools and taught many seminars on this stuff.
Be SAFE. PLEASE.
Before you just slap that high lift on the Vanagon, please read the manual. Read Bill Burke's Hi Lift How to stuff. Try the jack out on the van. Find out where you are comfortable.
ALWAYS LEAVE THAT HANDLE UP! We actually use Velcro straps to affix the handle to the Jack when between movements with it. I have seen too many accidents.
Be Safe.
Did I mention chain sketches me out? _________________ ...like a young Julie Andrews all whacked out on PCP, kinda fun but kinda scary too
'83 1.6TD
DX 5 Speed
"Whistler"
www.sinisterbikes.com |
Posted: Tue Apr 13, 2010 3:54 pm Post subject: |
So, I decided to mount my hi-lift inside the van. It sure doesn't look as cool as having it on the outside , but it stays out of the elements, away from thieves, and off my van's already laden ass-end. Passenger seat can slide/recline all the way back and curtain operates normally.
It's about as simple as I could make it (although it took my feeble mind a lot of Home Depot time, staring blankly in the parts isle to figure it out). Just a couple of basic corner braces, some hardware, and a little cutting/drilling.
The base of the jack is cupped by the braces on the floor, and then a 1/2" bolt/spacer through the standard secures it quite solidly.
It's very unobtrusive. Plus next to it is normally a tool box (or porta-potty if GF is along), so it was otherwise unusable space.
Gave it a nice test run last weekend in the desert and it never moved… inadvertently or purposely .
Posted: Wed Apr 14, 2010 7:33 am Post subject: |
"recovery" can mean yanking, but it can also mean winching
"pull" can mean yanking, but it can also mean towing
When using the HiLift as a Winch I think you will agree, you DO want chain or winch line, that does NOT stretch..
And when towing you also want chain or winch line that does NOT stretch.
The time for a stretchy pull with a snatch or recovery strap is when you are jerking the load, like when one vehicle connects a snatch strap to another, leaving the strap slack, and then takes a running start to yank the stuck vehicle out.. stretch is your friend there..
But stretch is not your friend when using a HiLift to winch or pull.
notice they use Chain, you do NOT want to use a Hi Lift with a recovery strap that stretches.. only with a non stretching Tow strap.. or sometimes you use a tree strap to anchor the HiLift, tree straps do not stretch like recovery straps
tozovr Samba Member
Posted: Wed Apr 14, 2010 7:54 am Post subject: |
Jon_slider wrote: |
http://www.youtube.com/watch?v=CPmu7fsqC6w
http://www.youtube.com/watch?v=iQTVO6-LNXc
notice they say "chain or tow strap", a tow strap does not stretch like a snatch strap or "recovery strap" (however in the video they say tow strap one time, and then misuse the term recovery strap later.. you do NOT want to use a Hi Lift with a recovery strap that stretches.. only with a non stretching Tow strap |
I would never use a chain to winch...using a Hi-Lift or an actual winch. Use an approved cable or Poly rope.
As an aside, anyone who actually winches using their hi-lift must be in dire straights...or have a TON of time on their hands LOL. _________________ ...like a young Julie Andrews all whacked out on PCP, kinda fun but kinda scary too
'83 1.6TD
DX 5 Speed
"Whistler"
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sun Jan 29, 2012 9:02 pm Post subject: HI lift |
On my syncro I cary the jack in my roof rack hold it down with 2 yakima straps works good! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
