buzzboy Samba Member
Posted: Wed Dec 17, 2008 4:55 pm Post subject: More brakes and MCs |
My Master cylinder decided to go retarded. All of a sudden my floorpans were wet and not with water. Blew that seal. So I got a new MC and replaced the old one and now a problem arises. Before this I didn't really have good brake light switches. I had to be pretty hard on the brakes to make the light come on. Now I just about have to have them locked up to get any light. New switches? I cleaned the old ones out with brake fluid but no use.
Also I have a wheel that's acting up. My front passenger wheel decides to lock up very quickly. This happened with both MCs, before and after brake adjustment and after brake bleeding. And both right/left have the same amount of brake left on the shoe. Where do I go next? |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Wed Dec 17, 2008 5:17 pm Post subject: |
You need new switches and new ones are crappy.
The locking up may be due to the rubber lines. Old ones swell up inside reducing the diameter so when you apply the brakes the high pressure from the MC squirts it through but the lower return pressure takes a while to release the brakes.
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
Posted: Wed Dec 17, 2008 6:47 pm Post subject: |
The rubber lines are all new so I don't know what's up there.
So what do I do a out the switches? Biuy working used ones? |
execk2 Samba Member
Joined: April 30, 2005 Posts: 1359 Location: Quebec City
Posted: Wed Dec 17, 2008 6:51 pm Post subject: |
Check the play in the pedal rod. There should only be about 3/4" before you feel the pedal (by hand) touch the rod in the MC. Adjust if necessary. _________________ Mike
www.mikeandjosee.com |
ts88 Samba Member
Joined: March 11, 2008 Posts: 269 Location: Eugene, Oregon
Posted: Wed Dec 17, 2008 9:30 pm Post subject: |
The brake light switches that I got from Auto Zone are working ok, the ones from BAP were crap. Pat _________________ I would rather be a Conservative nut job, than a Liberal with no nuts and no job
There is no sense in being stupid if you can't prove it.
"To call an illegal immigrant an "undocumented alien" is the same as calling a streetcorner drug dealer an "unlicensed pharmacist". |
