Judson Advice?
fanbelt
fanbelt is offline
PostPosted: Thu Dec 18, 2008 4:24 pm    Post subject: Judson Advice? Reply with quote
Im thinking about building a judson powerd 36. Now with being said is there anything I could or should do while putting said motor together that would complement the judson? After speaking with George Folchi I understand a hotter cam is not a good idea but what about head porting or longer stroke crank and are any of these even available?
Also Im concerned about my or any old 36 case being usable. How can I tell? What are bearing retainers? Who can I trust for machine work? Who can rebuild my heads? And so on and so on..... Frankly its giving me a headache. If anyone can help with one or all of these question i would appreciate it.
Braukuche
Braukuche is offline
PostPosted: Thu Dec 18, 2008 8:49 pm    Post subject: Re: Advice? Reply with quote
I've been going through the same thing. I live in So Cal and could find only one machinist in the whole city who was recommended for VW work and who would work on 36 horse stuff. The other machinist in town known for VW work wouldn't touch 36 horse stuff saying "there's no money in it" (Don from The Bug Patch).
Its getting to the point where its getting to hard to find anyone who works on air cooled stuff period let alone vintage stuff. Rimco went under, but has since come back under new management, and there might be others but it would require sending stuff off which makes me nervous when it comes to rare vintage parts. I guess there is no good answer to your question other than look for recommendations you trust and then cross your fingers and hope you don't get screwed.
--Dan
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Dec 18, 2008 9:14 pm    Post subject: Reply with quote
Hello-
Last year I sent some time researching superchargers. With a 36HP engine, there are two major issues you have to contend with. The first is that the 36HP engine isn't the best foundation to work with. They'll run forever if you leave them stock, but they have a reputation for having very weak cranks. To remedy this situation you'll either have to baby the engine, have a custom crank made ($2K+), or buy the Pre-A Porsche crank from NLA Parts for $1K.
The second issue is how to deal with all the extra heat. You'll probably want to run cooler plugs, install a 40hp fan, use stainless steel valves, install slightly stronger springs to compensate for the higher compression, and lower the base line compression. If you have the money, you could install aluminum cyldiners from LN Engineering, but that will cost you 3.2K for the cylinders, pistons, and studs.
In the end I decided to go the Okrasa route. Admittedely, it's going to be as expensive, if not more, than a Judson, but at least I know it will fit under my decklid. Wink
To answer your questions:
All things being equal, a longer crank will increase your compression, and that's not what you need. If you went that route, you would either install a Porsche 356 crank, or one of the 69mm Okrasa cranks.
Regarding you case, you'll need to have it inspected by a credible machine shop for cracks, wear, etc..
Thanks,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
oval-55
oval-55 is offline
PostPosted: Fri Dec 19, 2008 3:29 am    Post subject: Reply with quote
Why is it bad idea? Think
For example "mr okrasa" sells in "vwjudsonregister site" 36hp cams!
This is what he writes in his ad:
"Judson 36hp performance camshafts are here!!
I use these camshafts all the time when I build my Judson Supercharged engines. They pull great throughout the entire RPM range. Many, MANY satisfied customers so far."
Klick this: http://vwjudsonregister.tripod.com/buyandsellpage.htm
I am going to use one in my Judson engine with ported "bigvalve" heads!
But I am not going to over rev that engine!!! I belive that these parts will give some extra ponies vs. stock judson engine Dancing
fanbelt
fanbelt is offline
PostPosted: Fri Dec 19, 2008 7:22 am    Post subject: Reply with quote
Gimmesome this is the first time hearing about 36 cranks being weak. Granted i havent had much xp with them but but the judson only puts out 4 to 5 lbs of boost. Is that really going to be an issue ? Seems people have been useing them with stock cranks for 50 someodd years and still are. Not that a stronger/counterbalanced crank isnt a good idea . It just seems like over thinking it.
gimmesomeshelter
PostPosted: Fri Dec 19, 2008 9:46 am    Post subject: Reply with quote
Oval-55
Before you purchase a cam from Mr. Okrasa, I suggest you contact Dema Elgin to see what he can do. First, my understanding is that cam for a supercharger is quite a bit different than a cam for a standard performance engine. Second, my machinist frequently has Elgin create custom grinds to fit a particular customer's engine/trans/driving style.
Thanks,
Paul
Richard Feynman
John Moxon Premium Member
John Moxon is offline
PostPosted: Sat Dec 20, 2008 4:54 am    Post subject: Reply with quote
You know, fitting a Supercharger to a 30hp VW engine is the most straightforward Vintage Speed enhancement you can make. It requires neither special skills to fit nor special knowledge to get running correctly, you just follow the instructions supplied. You see the supercharger isn’t an engineering solution to getting more from your engine, it’s a bolt on accessory designed to overcome the shortcomings of the normally aspirated.
If you bought any supercharger kit “back in the day” they were simply a bolt on and go solution. Be it Judson, MAG, Pepco, or Shorrock, designed to be used without the need to open the case.
Unless you have specialised knowledge of supercharging and its pricipals don't think about modifying you engine to suit.
That's not to say you can't take advice but the average aircooled VW workshop will have very limited practical experience...if they tell you it will break your crankshaft, then walk away.
Crankshafts
Crankshaft failure is a product of overrevving...cranks in stock engines fail but in all the time I've run my Judson website (8 years+) I've never had anyone tell me their crank had failed.
So does running a supercharger protect you from crankshaft failure? It would be a brave man who claimed that but supercharging produces its increase in power in a different way from multiple carb applications. Supercharging produces extra power (torque) at the same revs over the stock configuration; i.e. it doesn't need to spin the engine faster to produce the gains. Infact Judson tell you to make all your gearchanges in all the same places as before.
Judson's "A Few Facts on Supercharging
Camshafts
The ultimate in performance, of course, is achieved by building a motor specifically for the blower. Using a "blower" cam that optimizes the breathing characteristics of the blower can improve both low speed torque and high-speed power. A long duration cam with a lot of overlap isn't good with a blower because the boost pressure goes in the intake valve and right out the exhaust port at low speed. What works best is a cam with little overlap, a lot of lift and duration but more lift and duration on the exhaust valves (since the blower does nothing to help evacuate the cylinders).
I don't know the characteristics for the Joe Ruiz Cam (I just carry his ad) but knowing he has been building Judson Supercharged and Okrasa engines for a long time I think they will display the required lift and duration needed. However I'm sure he would be willing to answer any questions you have about them.
So you see you can do nothing or you can start tinkering with the formula. In my experience the tinkering will give you minor gains but if that's what you like to do, fine I wouldn't discourage you.
If you don't want that hassle, just follow the instructions and stop worrying about broken crankshafts. Wink
John.
