67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Aug 04, 2016 10:15 pm Post subject: Re: pertronix electronic ignition. |
pepsiguy78 wrote: |
Considering installing a Pertronic electronic ignition on my 74 super with the Bosch 009 distributor. # 231 178 009. What are some concerns that I should watch out for? What coil should I use? |
don't connect the wires backwards to the coil - red is hot and black is negative! I use standard bosch blue coils and never had any problem. You may have to take a file or similar to clear a few thousandths off your rotor so it doesn't hit the top of the distributor cap.
don't pay much attention to the naysayers of the electronic points modules - pushing 100k on my original pertronix I purchased in 2003. _________________ 67 bug x3
67 ghia
64 bug |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Fri Aug 05, 2016 2:59 am Post subject: Re: pertronix electronic ignition. |
67jason wrote: |
pushing 100k on my original pertronix I purchased in 2003. |
The new ones are not as good as the old ones.
I've tested a few and found a 4* variance from cylinder to cylinder on some. putting magnets in a plastic ring not not very precise. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Aug 05, 2016 11:50 pm Post subject: Re: pertronix electronic ignition. |
Glenn wrote: |
67jason wrote: |
I've tested a few and found a 4* variance from cylinder to cylinder on some. putting magnets in a plastic ring not not very precise. |
the one I purchased last year for my wifes 019 is dead on up to 5500 rpm...thats all she needs outta her baby motor. I have seen accufiure and compufire modules in various good to not so good flavors of 009s that had issues. ive also had a good discussion with clyde berg regarding points modules, he currently swears by the cheapo accufire ones...so to each their own I say _________________ 67 bug x3
67 ghia
64 bug |
pepsiguy78 Samba Member
Joined: February 28, 2015 Posts: 110 Location: Vancouver,WA
Posted: Tue Jun 19, 2018 4:23 pm Post subject: Re: pertronix electronic ignition. |
Hi guys, I finally bought a Pertronix ignitor for my car and I am having "issues" with the install - help please.
I have a 0-231-178-009 distributor on my car and was sold a Pertronix Ignitor 1847V model kit. I think I was sold the wrong one, I think that one is made for a vacuum advance and my dizzy does not have the can on the side. I believe the model I should have received is the 1847A model.
With that being said I am trying to make this work. The grommet on the model I have is round and the opening on my dizzy is square, I was able to coax the round grommet into the square opening and that is fine. I installed the module into the distributor and put the magnet down the shaft, lined up the indents on the cam lobes and pressed in place. Now it is time to put the rotor on and it does not seat all the way down because of the magnet - ugh! What do I do? Is it because I was sold the wrong model or? I have read where some people have to sand or grind on the bottom of the rotor to get it to fit. What do you think? |
vamram Samba Member
Posted: Tue Jun 19, 2018 8:29 pm Post subject: Re: pertronix electronic ignition. |
pepsiguy78 wrote: |
You got it. I don't know why no one makes one for this, so you have to cut it to fit with the module. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Tue Jun 19, 2018 8:39 pm Post subject: Re: pertronix electronic ignition. |
vamram wrote: |
pepsiguy78 wrote: |
You got it. I don't know why no one makes one for this, so you have to cut it to fit with the module. |
What would you recommend to use to cut the rotor down? Grinder, belt sander? |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Tue Jun 19, 2018 11:43 pm Post subject: Re: pertronix electronic ignition. |
pepsiguy78 wrote: |
I used a hacksaw for the rough cut then some coarse grit sandpaper to square it up evenly. Remove the metal tensioner on the underside of the rotor before you saw. You may need to trim the metal tensioner to fit the shorter rotor.
Really it only took like 10min. The plastic is rather soft. _________________ AshMan40
vamram Samba Member
Posted: Wed Jun 20, 2018 3:49 am Post subject: Re: pertronix electronic ignition. |
I use a dremel. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Jun 20, 2018 4:30 am Post subject: Re: pertronix electronic ignition. |
I use a belt sander, but its really not critical. The top of the distributor shaft sets the height. The bottom of the rotor is not spinning against anything, so even if its not level, it doesnt matter. I like to make it square, juts because thats how I am. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Randy in Maine Samba Member
Posted: Wed Jun 20, 2018 6:35 am Post subject: Re: pertronix electronic ignition. |
I used my bench grinder. |
Zundfolge1432 Samba Member
Posted: Wed Jun 20, 2018 6:43 am Post subject: Re: pertronix electronic ignition. |
I used a dental tool |
chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Wed Jun 20, 2018 8:39 am Post subject: Re: pertronix electronic ignition. |
If you can afford it I recommend the full coil pack system that replaces the coil and the distributor... or some replace the distributor cap.
I have one on mine and it's great. |
vamram Samba Member
Posted: Wed Jun 20, 2018 8:43 am Post subject: Re: pertronix electronic ignition. |
chrisarnt wrote: |
What system are you using? Compufire? MSD? Other..? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Wed Jun 20, 2018 9:56 am Post subject: Re: pertronix electronic ignition. |
It really seems like Pertronix should mention in the instructions that trimming the rotor may be necessary. Most people say installation is a simple task and I agree except for this step. I wonder why some rotors simply fit and many need trimming. Time to get the saw out- carpentry tools for my ACVW, my "road side" tool bag is getting bigger - ha. |
Posted: Wed Jun 20, 2018 12:32 pm Post subject: Re: pertronix electronic ignition. |
Update on the Pertronix installation:
After trimming the rotor down by 1/4 inch the rotor slid on and the cap snapped on. With a turn of the key the car came to life and ran smooth.
I used a coping saw to simply trim off the extra length from the rotor and a "side cutter" to shorten the tensioning metal. |
Posted: Wed Jun 20, 2018 1:16 pm Post subject: Re: pertronix electronic ignition. |
My SVDA distributor was an original VW 034/205 ('74 STD Beetle). My electronic points were Compu-Fire which uses a flat large diameter disc w/ four magnets imbedded.
The disc fits snuggly over the top of the square distributor shaft cam. For my SVDA install I added the included small shim to lift the bottom of the disc high enough so it didn't contact the module. This disc and spacer took up some of the space on the shaft and lifted the rotor.
I only realized there was a problem when I started the engine and saw the distributor cap "dancing". The rotor was hitting the bottom of the posts and lifting the cap as it rotated. Craziest thing I've seen. I was amazed the engine was actually running. I think trimming 1/4" from the bottom of the rotor was just right to allow the rotor to clear the disc and fully seat onto the slot at the top of the shaft. I suppose you may want to cut less and fit it so it is pressing down on the disc to prevent it from lifting up over time (though, technically the CW rotation of the rotor should seat the disc further onto the shaft). _________________ AshMan40
