Reproduction OT Pulley's
HerrLowlight Premium Member
HerrLowlight is offline
PostPosted: Sat Aug 15, 2015 7:33 am    Post subject: Reply with quote
Answering my own threads:
http://www.thesamba.com/vw/classifieds/detail.php?id=1400128
Trevor
1967 SO42
1959 Karmann Ghia
1959 Karmann Ghia Convertible
gatorwyatt
gatorwyatt is offline
PostPosted: Sun Aug 16, 2015 2:14 am    Post subject: Reply with quote
Those look nice!
www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine.
Barndoor Safari disconnects
10k date code Bosch VJ4BR8 distributor
Bengt H
Bengt H is offline
PostPosted: Sun Aug 16, 2015 12:28 pm    Post subject: Reply with quote
I have bought one from Stefi, looks very good Very Happy
PostPosted: Sun Aug 16, 2015 12:36 pm    Post subject: Reply with quote
Hi Bengt,
Is Stepan's the same size a stock VW pulley, or smaller?
Thanks
Trevor
1967 SO42
1959 Karmann Ghia
PostPosted: Thu Aug 20, 2015 8:12 pm    Post subject: Reply with quote
ok, does anybody know if this pulley will bolt on to a stock 36hp motor? This is 18cm across.
Wondering about any oil seal issues?
Thanks
Trevor
1967 SO42
1959 Karmann Ghia
PIMPPRIDE
PIMPPRIDE is offline
PostPosted: Fri Aug 21, 2015 9:38 am    Post subject: Reply with quote
HerrLowlight wrote:
I'm interested in one for my 36hp motor, so it needs to be the right size and needs to be bolt on.
Anthony?
Trevor
were talking about doing another run of these, anyone that wants, can please send me a PM or e-mail and ill put you on a list to guarantee you get a one from the next batch
Anthony / ISP WEST
facebook = http://www.facebook.com/pages/ISP-WEST-INC/212843163005?ref=nf
twitter = http://twitter.com/ISPWEST
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Gallery Classifieds Feedback
PIMPPRIDE
PostPosted: Mon Nov 23, 2015 12:58 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
new run is done.. . these are black finished. ..
Anthony / ISP WEST
sparkleplenty
sparkleplenty is offline
PostPosted: Thu Dec 10, 2015 10:40 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
Are you making any that have been cut for sand seals?
'56 European Oval Ragtop-Stock
'56 Karmann Ghia Coupe-Stock
'59 Italian Series I Li150 Lambretta-Stock
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime."
"Only when the tide goes out do you discover who is swimming naked."
gatorwyatt
PostPosted: Mon Feb 01, 2016 5:06 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
Some friends and I started discussing why the engines wanting higher timing ranges and it dawned on me that the asthetics of the pulley would lead you to believe the timing mark is at 0 degrees because it lines the OT directly up top. But in fact just like a stock pulley ranging from 7.5-10 degrees BTDC and hence there may be some confusion.
I put a call into Alex to see what the mark is set at when the pulley is made and he was going to look into it and remark back here on this thread.
www.blastserv.com
wanted:
56reddy
56reddy is offline
PostPosted: Tue Feb 02, 2016 5:31 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
The mark on the top of the OT pulley is the TDC mark.
1953 Zwitter 3 fold ragtop.
gatorwyatt
PostPosted: Tue Feb 02, 2016 7:10 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
scvw in his typical "make it the nicest possible" fashion, machined a device that can be screwed in to the #1 plug hole and has a center pin that slides in and out to decide when TDC is.
A micrometer was placed on the end of the pin and the engine was rolled over and decided this was the results.
The rest of the story on this engine was that the exhaust had a very strong smell of raw hydrocarbons and was set assuming the mark was zero and timing set at what was thought to be 34 degrees @3200-3500 rpms
www.blastserv.com
wanted:
56reddy
56reddy is offline
PostPosted: Wed Feb 03, 2016 6:29 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
Very interesting results Todd.
I have the last run of OT pulleys. My pulley is at TDC when the timing mark is aligned with the case seam. I know when Joe sends an engine out, he leaves it at TDC on #1 cylinder. When I put my pulley on it was perfectly aligned with the case seam.
rtroy
rtroy is offline
PostPosted: Thu Aug 18, 2016 1:47 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Hello-
Nla Parts sells a repro, but it isn't inexpensive.
http://www.nlaparts.com/store/front-crankshaft-pulley-4hole-p-1786.html
Paul
That's the wrong one!
THAT "4 hole pulley" is for the three piece crankcase introduced in ... October 54, I think.
The earlier one is the one that works on a VW...
Richard
Karmann Ghia and Porsche 356 enthusiast
Founder, The Karmann Ghia Club of N. America
rtroy
rtroy is offline
PostPosted: Thu Aug 18, 2016 1:51 pm    Post subject: Reply with quote
Braukuche wrote:
fanbelt wrote:
So whats the advantage of this pully over a stock vw pully?
Spins the fan slower, less drag on the engine, less horsepower used.
--Dan
In so far as that's true, it's not the reason it was done.
The stock fan cavitates (or otherwise stalls) at around 4300 RPM; Porsche went to the smaller diameter to prevent overheating for continuous operation above around 4500.
Regards,
RT
Richard
rtroy
rtroy is offline
PostPosted: Thu Aug 18, 2016 1:52 pm    Post subject: Reply with quote
Glenn wrote:
--Dan
And less cooling.
Nope - or, rather, depends on at what RPM you're talking about!
The stock system can't handle high RPM, simple as that. Slowing the fan down helps the cooling system to continue to work at 6000 RPM.
Rgds,
Richard
Richard
johnny d
johnny d is offline
PostPosted: Sat Nov 26, 2016 4:55 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
Hi Gents,
did someone actually use those ISP OT Pulleys?
if so, can someone tell me if these work or not?
I have one but still have not the chance to get the engine running, and i know wondering about the measures of the rear. All OG VW-Pullys are 49,90mm, but the OT pulley is 49,29mm
so i´m now worried about to getting a oil leaking problem with the OT Pulley.
It would be nice, if someone can help me out here..
Thanks
GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007
rtroy
rtroy is offline
PostPosted: Sat Nov 26, 2016 12:59 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
johnny d wrote:
...snip...
...snip...
Hi Johnny, you are incorrect about all VW pulleys being 49.9 as there were oversize pulleys available for worn cases.
If you have a worn case, here's how you can fix it:
http://356coachworks.com/share/engines/CrankcaseRepair_FixingWornPulleyBore.html
Or, send it to them, I'm sure they can do it for you, too!
As for worrying about a leak, yes, that's a smart thing to do! FIRST thing I would check is if that measurement tool is calibrated correctly! ;-)
Richard
johnny d
johnny d is offline
PostPosted: Mon Nov 28, 2016 12:53 am    Post subject: Re: Reproduction OT Pulley's Reply with quote
Thanks.
So is someone running these ISP Pulleys and can tell me if they work.
GermanRestoKommando
grailoc
grailoc is offline
PostPosted: Mon Nov 28, 2016 8:37 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
johnny d wrote:
Hi Gents,
Just measured my OG pulley and had 49.9mm exactly.
My 59 low light ghia: http://www.thesamba.com/vw/forum/viewtopic.php?p=7852268
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
Check my blog: http://us-road-trip-vw-bus.skynetblogs.be/
and my garage build thread: http://www.garagejournal.com/forum/showthread.php?t=199438
My other vehicles
KG 64
vespa 1961 Acma & spanish GT 160
2 Lambretta LI 150
2 1971 Honda CT70
johnny d
johnny d is offline
PostPosted: Tue Nov 29, 2016 2:13 pm    Post subject: Re: Reproduction OT Pulley's Reply with quote
grailoc wrote:
johnny d wrote:
Hi Gents,
your OG OT Pulley or OG VW Pulley?
GermanRestoKommando
Page 4 of 5
