TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Dec 26, 2008 3:55 pm Post subject: Pivot Pin on Brosol fuel pump |
This may be old news, but I figured I would post it. The pivot pin in my new Alt style Brosol fuel pump fell out and of course the engine started running just like crap because it was starved for fuel. Less than 600 mi. on engine and pump. '71 with 1776 Dual Port. Found the pin up next to the Alt stand, so it must have come out the back of the pump. I will put it back in tonight and peen both sides of the pump around the pin so it will stay put. Damn it's cold here!
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Fri Dec 26, 2008 3:56 pm Post subject: |
Yup... it's a know problem.
Options are to peen the end, some JB Weld to hold it in or find a older pump that had the pin with the circlips. _________________ Glenn
Member #1009
#BlueSquare |
jttosh Samba Member
Joined: May 16, 2004 Posts: 451 Location: Cuyahoga Falls,Ohio
Posted: Thu Jul 19, 2018 11:07 am Post subject: Re: Pivot Pin on Brosol fuel pump |
Whats the easiest way to put the pin back in?
Stuck on the side of the road with this problem right now _________________ "listening for the secret,searching for the sound" |
SGKent Samba Member
Posted: Thu Jul 19, 2018 11:21 am Post subject: Re: Pivot Pin on Brosol fuel pump |
if you can get a small screw driver or nail etc into the center of the pivot then you can lever it into position to push the pin back in. Keeping it in may be a problem if it no longer has a C-clip or is no longer a press fit. If it is still tight, you might be able to hold a hammer on one side and gently tap it from the other side to drive it in, once you align the pivot hole. Worst case if you would need to remove the pump (but not the block) to push the pivot back into position so you can put the pin back in. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Jul 19, 2018 3:37 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
The pump rod goes up and down, completing a cycle every TWO rotations of the engine, so rotate the engine slowly while keeping an eye on the hole; you may be able to line everything up.
If not, I would rotate the engine until alignment was closest, then loosen the fuel pump, using both nuts one turn at a time, until the pin and hole line up. Once you're home, pull the pump completely and clean/re-seal the base unless you used a non-hardening sealant like Curil, which might be good for one or two removals if the mating surfaces stay clean.
Good luck!
www.airschooled.com |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Thu Jul 19, 2018 3:48 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
For a quick, on-the-road fix I simply put a dime on either end of the dowel and held them in place with a wrapping of duct tape around the pump body. It held for a trip from Portland, Oregon to Paradise, California with a leisurely return via the coast. Of course I replaced the pump and peened the dowel upon my return when I has time.
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
jttosh Samba Member
Posted: Thu Jul 19, 2018 4:12 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
Got the pin in and got it home. It's a really tight fit and did not move at all on the way.
Is there a way get that pin to not move/come out? Right now it is pretty snug in there. _________________ "listening for the secret,searching for the sound" |
Posted: Thu Jul 19, 2018 5:04 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
jttosh wrote: |
Is there a way get that pin to not move/come out? Right now it is pretty snug in there. |
The bug forum is full of people who have made their own sulutions:
One fellow even makes these:
https://www.thesamba.com/vw/classifieds/detail.php?id=1338517
SGKent Samba Member
Posted: Thu Jul 19, 2018 5:09 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
a machinist could make a rod for you that extends on both sides, then a groove to allow a C-clip on each side. The originals had a hat on one side and a C-clip on the other. If you could find such an old pump maybe you could pull the pin out if it is the same OD. Seems a shame the engineers screwed that one up. It is a really simple solution when manufacturing them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wihr Samba Member
Posted: Thu Jul 19, 2018 5:33 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
I simply used a prick punch and peened the body at the seam with the pin.
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Tcash Samba Member
Posted: Thu Jul 19, 2018 6:53 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
This is a bad example. But the indentations around the pin are made with a pointed chisel and a hammer. This is what is called staking (peening) the pin.
Note how the end of the pin is tapered, what you are doing is deforming the metal on the fuel pump body to lay into the tapered area on the pin.
tom_hd02 wrote: |
Replaced the fuel pump pin with an exhaust clamp bolt.
JB weld job on Brazilian fuel pump to retain the fulcrum pin.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=961195
TimGud wrote: |
Don't know what happened the last couple of years but I had always had good luck with Brosol pumps, that is until they changed the design of the pump arm pin. Two of mine came out with very few miles on them, needed one which is a 75 mile drive for me to buy so made new pins like they were a few years back. I know this is being very cheap but I hate throwing things out that I know have a lot more life in them.
EDIT: I used M6 x 65mm bolts as I couldn't find any 6mm round stock locally.
Overall pin length = 27mm, distance between e-clips = 23mm
wcfvw69 Samba Purist
Posted: Thu Jul 19, 2018 8:02 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
Buy a used German Pierburg pump for $5 dollars and harvest the rocker pin and clips off it.
I have plenty of good used ones with clips. PM if interested. _________________ Contact me at [email protected]
The Samba member since 2004.
d___dles Samba Member
Posted: Sat Sep 11, 2021 6:27 am Post subject: Re: Pivot Pin on Brosol fuel pump |
I've tried looking for the purpose of the pivot pin in John Muir's book, here and google with no luck. Can anyone tell me what it actually does? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat Sep 11, 2021 10:22 am Post subject: Re: Pivot Pin on Brosol fuel pump |
d___dles wrote: |
It holds the operating lever in position, and provides the shaft around which the lever rotates in operation.
There's a good cutaway diagram of the stock fuel pump in the 66-69 Beetle Bentley manual. _________________ '67 bug: seized by the authorities
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Sat Sep 11, 2021 11:15 am Post subject: Re: Pivot Pin on Brosol fuel pump |
For those who live near the sea, chandleries sell clevis pins that will fit.
Also SSP are selling a new rebuildable E10 proof pump. I have one on my bus, the only problem is that it is taller than the stock pump, and it hits a centremount T1 progressive manifold casting. _________________ Ancient vehicles and vessels
Posted: Sat Sep 11, 2021 12:08 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
kreemoweet wrote: |
d___dles wrote: |
There's a good cutaway diagram of the stock fuel pump in the 66-69 Beetle Bentley manual. |
Awesome thank you for taking the time to respond. Will check out the diagram. _________________ 1967 Riveria Camper |
Posted: Sat Sep 11, 2021 1:44 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
For those who want to see the cutaway diagram of the fuel pump:
Posted: Sat Sep 11, 2021 4:17 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
If you buy a replacement rocker pin, make sure it's hardened. Both the original rocker pin and the rocker itself are hardened.
Even with the hardening treatment, I still see a ton of high mileage German Pierburg fuel pumps with worn out rocker pins and rockers. _________________ Contact me at [email protected]
Posted: Mon Sep 13, 2021 8:14 pm Post subject: Re: Pivot Pin on Brosol fuel pump |
This is most likely me being paranoid but I just made a metal thing to hold the pivot pin from popping out(keeps popping out the back if front means front of the bus), looks like the previous owner JB welded it and it cracked.
My question is, what are the odds that the nut holding down the metal plate thing I made loosens, the plate swings around and shreds up the fan belt? I tightened down the nut pretty good but I drive on bumpy roads often and unsure how much the engine rattles around. Again, I'm probably just being paranoid.
Here's a photo:
