Window Regulator How-To
Gene Blackman
Gene Blackman is offline
PostPosted: Wed Jan 09, 2013 12:04 pm    Post subject: Reply with quote
Thank you!
I think this is my first post, I'm not sure. I joined in anticipation of my '71 Super purchase. I am glad I did!!!
fergy1008
fergy1008 is offline
PostPosted: Wed Jan 09, 2013 1:41 pm    Post subject: Reply with quote
Holy crap man! Good write up! I was just going to tackle this and you made things way easier. Thanks for the detailed post. Don't be afraid to do more. You did an awesome job.
gooser
gooser is offline
PostPosted: Thu May 09, 2013 5:10 pm    Post subject: Reply with quote
will lithium grease from a tube work as well as that from a spray can? or will that be too thick? incidentally, i just took apart my regulator and no crud. no sign that grease had ever been there. i think lack of lubrication and a little rust is causing my problems.
mnussbau
mnussbau is offline
PostPosted: Thu May 09, 2013 5:26 pm    Post subject: Reply with quote
I don't see any reason why the stuff in a tube wouldn't work just as well as the spray type, or even better. The spray grease tends to evaporate some. I used it out of convenience.
Mike
A nice pair (of '74s)
Parts...
Diego Wolfwood
Diego Wolfwood is offline
PostPosted: Thu May 09, 2013 5:45 pm    Post subject: Reply with quote
Thanks for this useful guide! When I save up the money for a full door rebuild kit (I need all new rubber, ugh.) I'll fix my regulators too Very Happy
Loving my 1970 Beetle.
http://www.thesamba.com/vw/forum/viewtopic.php?t=461402
snailovercello
snailovercello is offline
PostPosted: Sat May 18, 2013 8:07 am    Post subject: Great instruction set Reply with quote
I totally knocked this job out in just a few hours thanks to this post. I had recently picked up some new/used vent windows. Mine were in pretty bad shape. So I went ahead and swapped those out too. Now my windows can be rolled up and down without destroying any more handles!
homeboymi
homeboymi is offline
PostPosted: Wed Sep 04, 2013 3:02 pm    Post subject: Reply with quote
Thank you for your post. The job went well with your instructions and photos. I was wondering after I did the job if the tangs could be bent and the spiral cable taken out and greased without taking the rest of the door apart. Seems like it might fix a lot of the hard rollup problem even though its not as thourgh as your instructions. Just smokin and thinkin.
SDGuero
SDGuero is offline
PostPosted: Thu Oct 10, 2013 10:23 am    Post subject: Reply with quote
I installed a window regulator on the drivers side of my '67 last night. I didn't read any instructions... Great tutorial, only thing I have to offer is that I didn't have to completely remove the vent window. Instead I just took out the top screw and tilted it back. That gave enough clearance to get the regulator in.
Took me about an hour but my car was already missing the door panel and regulator (I have no idea why someone would remove the regulator and put the vent window back without replacing the parts) so I didn't have one to remove initially.
Molly1973
Molly1973 is offline
PostPosted: Thu Oct 10, 2013 10:40 am    Post subject: Reply with quote
This is an excellent post. Pictures are definitely worth a thousand words...or more. Thank you!
Joel
Joel is offline
PostPosted: Thu Oct 10, 2013 3:39 pm    Post subject: Reply with quote
Unless the bottom mounting bolt is missing from yours that can't work.
The winder sits in a recess in between the quarter window frame and the inner door skin and unless you unbolt the quarter window and move it out of the way it can't be installed correctly.
But if you remove the top screw and lower bolt it can be tipped back far enough to get the winder mech in which I suspect is what you have done, your lower mounting bolt was probably just missing.
'69Custom
'69Custom is offline
PostPosted: Thu Oct 10, 2013 8:21 pm    Post subject: Reply with quote
That causes a nasty vibration, let me tell you!
-Tim
1969 Frankenbug
1965 Ford Mustang
#2gunfire F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote:
Why tune a big round again and again????? For me.... 1 hour will solve the case Cool
www.endlesscustomz.com
blangston
blangston is offline
PostPosted: Sat Oct 12, 2013 10:46 pm    Post subject: Reply with quote
Mike, thanks for the fantastic tutorial! I purchased my first bug (71 SB) a few weeks ago and this was my first real DIY project. Pictures and details were perfect. Cheers!
VW Beetle and Ghia
VW Beetle and Ghia is offline
PostPosted: Fri Nov 22, 2013 4:07 pm    Post subject: Reply with quote
So much better than trying to follow my Haynes manual!
But how do I remove my felt channels? They're OG, and very nice, so I don't want to replace them, but I'm putting new my new window scraper and trim assemblies, and they won't go in without the felt channels being out. Any help is greatly appreciated!!! Very Happy
1970VWGUY
1970VWGUY is offline
PostPosted: Sun Nov 24, 2013 5:10 am    Post subject: Reply with quote
http://www.youtube.com/watch?v=eyXcYIyDI58
Goshen
Goshen is offline
PostPosted: Wed Jan 01, 2014 9:14 pm    Post subject: Reply with quote
Make it at sticky
flyboy161
flyboy161 is offline
PostPosted: Thu Aug 21, 2014 4:43 pm    Post subject: Reply with quote
Awesome, I'll be doing this job this weekend! I will definetely be referencing this thread
Skizz
Skizz is offline
PostPosted: Mon Mar 30, 2015 1:37 pm    Post subject: Reply with quote
Another thank you for a great tutorial.
Went off without a hitch, AFTER reading this thread..
Don't wanna mention the before!
Down4Dubs
Down4Dubs is offline
PostPosted: Tue Apr 14, 2015 6:34 pm    Post subject: Reply with quote
Great tutorial! Thank you for taking the time to detail everything. I need to do this, and have been putting it off out of fear until now. Thanks again!
Tim Donahoe
Tim Donahoe is offline
PostPosted: Tue Apr 14, 2015 11:48 pm    Post subject: Reply with quote
Something I might add to this:
I had a hard time re-installing the window because the top of the window was encountering resistance from a horizontal crash brace member that is attached to the outer skin of the door (this brace is located inside, however). Fortunately, there is a large hole just under the lock pull for you to grab the top of the window as it hangs up on this horizontal member and force the top of window toward you, which will get the window "over the hump", so to speak.
And this is fun while trying to pull the padded bottom (you did pad it, right?) vertical end of the regulator, while pushing up on the glass, and also pulling the top of the window away from that horizontal cross brace.
Tim
Let's do the Time Warp again!
Richard O'Brien
tblacky
tblacky is offline
PostPosted: Thu Sep 10, 2015 12:36 am    Post subject: Re: Window Regulator How-To Reply with quote
Hey Mike! First of all, thanks so much for the post. I'll be tackling this on the passenger door for my project '71 Super Beetle (got it 3 weeks ago!) this weekend.
I'd like to do the same for the driver's side, but there's a problem.
7) Remove the single bolt at the very bottom that holds the regulator to the door. Depending how tight the regulator is against the glass you may choose to remove the glass next (at step 9) or remove additional bolts first (step 8 ).
My door is missing the small bracket where the regulator bolts on. The bottom of the regulator is hanging loose. I'll try and post a photo soon.
Do you (or anyone else on this thread!) know where I could get a replacement bracket? I've looked online for the past few days and have yet to find anything.
Thanks in advance!
Tom
Page 4 of 5
