plummerdesign Samba Member
Posted: Fri Sep 20, 2013 12:59 am Post subject: Flywheel Dowel Pins |
Interesting...No one seems to stock the Flywheel Dowel Pins for the Vanagon. Is there a good substitute out there?
Cheers,
Jeffery
(Westfalia travel / camping videos at YouTube link below) _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
funagon Samba Member
Posted: Fri Sep 20, 2013 3:19 am Post subject: |
I found a nice variety of dowel pin sizes at Ace hardware. I brought along the one pin I hadn't lost yet, so I could compare and buy the right size. I dont think there's anything special about those pins. I used the hardware store dowel pins when I pulled the engine out for work, six years ago. I've since driven the van 60,000 miles (six years) with no problems. _________________ 1990 GL 7-passenger
2.2 liter WBX
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Sep 20, 2013 5:03 am Post subject: |
Spring pins; a/k/a roll pins:
http://www.mcmaster.com/#roll-pins/=ol6y98
Not sure the size. Measure & match... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
khanb31 Samba Member
Joined: February 03, 2013 Posts: 18 Location: Des Plaines IL 60016
Posted: Sun Sep 21, 2014 8:49 pm Post subject: |
Has anyone found out the size and length of these pins? I am in need of new ones for my Bostig conversion and I cant seem to find out the specs on these. Not to mention no one seems to stock them. |
Posted: Mon Sep 22, 2014 8:37 pm Post subject: |
Bump.
If someone has a flywheel lying round and could give me just the length of the pin sticking out of it along with its diameter, that would be sufficient too.
Thanks!! |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Sep 23, 2014 4:47 am Post subject: |
Roll pins aka tensioner pins are at any hardware store: 6mm x 18mm. I bought 6mm x 20mm, no 18mm available. 40 cents each.
Install them sticking out about 1/8 of an inch. Leave them longer if you're not sure, you can tap them in easier than pull them out. Not a critical measurement, just has to hold the clutch plate. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Posted: Tue Sep 23, 2014 10:51 am Post subject: |
Jim,
The engine build happened last winter and the info was tossed out when done. My help came from an older Samba post. [They are 6X18mm roll pins, and can be made from 20mm ones
http://www.mcmaster.com/#catalog/120/3326/=tubvy9
Get the 20mm steel ones (91611A405) and shave off 2mm]
OR do just like JudoJeff says and procure what is on the shelf at ACE.
Gotta love easy solutions!
Cheers,
Jeffery _________________ It is old and green and it makes me grin.
Posted: Tue Sep 23, 2014 8:49 pm Post subject: |
Wonderful! Thanks very much everyone. I measured everything up with a bore gauge tonight and came up with pretty much the same numbers. I was going to order them tomorrow and its nice to see the numbers correspond.
After that, the trans shall be installed!
Thanks for the help everyone! |
